Jeff Hurd Samba Member
Posted: Tue Apr 20, 2004 7:08 pm Post subject: Camo paint for thing |
Anyone use this product from Rapco, (Gillespie Coatings Paint). Working on a off road thing and would like to go camo. Any ideas or suggestions.
Thanks,
Jeff
http://www.rapcopartscompany.com/paint.html _________________ Jeff |
Old and Grey Samba Member
Joined: April 21, 2004 Posts: 33 Location: Winnemucca, Nv
Posted: Wed Apr 21, 2004 6:11 pm Post subject: |
Wal-mart here is carrying Krylon paint, that they are putting out as a kit.
They list on the cans what colors are needed to do 3 different types of Camo paint jobs.
I plan on getting them to order me enought to do a Desert Camo Job _________________ From the last vestages of the Old West
Where the Men are Men
And the Sheep are nervous |
nthang Sambassador
Joined: February 05, 2003 Posts: 158 Location: Up Stream
Posted: Thu Apr 22, 2004 1:21 pm Post subject: |
I used the Gillespie paints from Rapco to do a camo job on my car about a year and a half ago. I used a gallon to hvlp spray the entire car in a base semi-gloss olive drab. Then, I used four different colored rattle can to do the camo patern, all "lusterless" military spec color.
You want to know what? If Gillespie is good? Rapco? Both are good, imho. I recommend it. Good luck. _________________ NTHANG, LLC |
Posted: Thu Apr 22, 2004 6:40 pm Post subject: |
Thanks for the info. Have the entire Thing covered in POR15 should be ready to paint soon. Is your car in side or out side?
Thanks,
Jeff _________________ Jeff |
nthang Sambassador
Posted: Fri Apr 23, 2004 8:20 am Post subject: |
The Thing stays outside these days. The Gillespie coatings (so far) are holding up well. Its hard, tough stuff that sticks to anything metal and doesn't let go. The rattle can tips spray in a wide vertical pattern.....better than the kraylon tips. I think that you will have good luck with Gillespie and Rapco....its better than anything that I found at the flaps....by far. _________________ NTHANG, LLC |
