coolwind57 Samba Member
Joined: February 17, 2008 Posts: 79 Location: S. Indiana
Posted: Sun May 04, 2008 5:34 pm Post subject: Hey Diesel guys: WVO? |
Anyone currently doing WVO?
I'm setting up for it now. _________________ 1983 Vanagon Diesel L
NA 1.6, 5-speed Manual
Burning Waste Vegetable Oil, baby!! |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sun May 04, 2008 7:08 pm Post subject: |
Several from the yahoo diesel Vanagon list are.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Sun May 04, 2008 7:13 pm Post subject: |
I'm doing biodiesel. It's a little more work processing the WVO, but I like the fact that I don't need an aux. tank, heaters, switches...etc. Who doesn't love a little garage alchemy? _________________ -Kerry
1982 turbo diesel Westfalia |
the caveman Samba Member
Joined: August 09, 2004 Posts: 885 Location: island state of Montreal
Posted: Sun May 04, 2008 8:38 pm Post subject: |
been on WVO for about 2 months now. Had to do a service call about 90 kms /55 mi away the other day. left town with my diesel fuel gauge at the last white pin before empty. beautiful. |
Posted: Wed May 07, 2008 4:07 am Post subject: |
the caveman wrote: |
Boy, I sure am curious about your setup.... Is it a custom job, or did you purchase a kit?
I'm building mine from scratch. If you find the time, would you be willing to share a description and maybe some pics? I'll do the same.
Nice to hear of another Vanagon WVO guy. _________________ 1983 Vanagon Diesel L
Posted: Wed May 07, 2008 4:27 am Post subject: |
Truth be told i'm a dealer /installer for Plantdrive although i use components from several sources to make my kits. I will post some pics soon however just to tell you i use a tank that i got from Dieselveg in the UK although it's Italian made. The best tank i sell. Tough and solid. A Hotfox heat exchanger for the tank, a Vegemax fuel filter/heater, some triple bypass hose from Golden fuel systems, then 2 Hydraforce valves,and finally a Vegetherm heater and temp sensor.I had to use some nicer components because i need a vehicle to showcase and you wouldn't have to use some of the stuff i did. You'll be able to use a cheaper tank , some regular coolant and fuel hose and a single 6 port valve. The 2 things i wouldn't skimp on would be a good quality fule filter with a water seperator and the vegetherm fuel heater and sensor. That heater is a cheap effective way to assure the VO is up to the right temp before it runs into the injection pump. I will try to take pics later today. |
Posted: Wed May 07, 2008 3:23 pm Post subject: |
Sounds great. I have purchased several components, including a fuel filter with electric heater and built in hand pump for priming newly installed replacement filters. I picked it up from E-bay. I've also bought a supplementary fuel pump to assist the WVO getting to the IP.
I'm presently fabricating the tank. It is an aluminum square tank that looks to hold about 40 gallons, but I'm cutting it down a bit as I install 1/2" copper tubing inside for the heat exchanger. I'm still debating HIH (actually tube inside hose) versus HOH.
Where exactly did you tap into your coolant? I'm removing my rear heater coil and I'm thinking of tapping in to the stock hose there.
My plan is to heat the oil within the tank via the copper tubing heat exchanger. I'll then pump the fuel via HIH or HOH to the engine near the IP where I'll have the electric heated fuel filter. The guy that sold me the filter says the heated filter will bring the temp up another 50-75F.
Anyhow that's the basic plan. I haven't yet decided upon a fuel selector valve yet. I've heard Pollack is not very durable and I'm still a bit confused on whether to use a 6-way or two 3-ways. I'd prefer not to send return diesel back to the WVO tank and vice versa upon purge cycle. Any thoughts?
I did see one idea of simply corking the return line at the diesel tank an tapping your return line back directly into the supply line. That seems kind worrisome to me, though.
Anyhow, thanks for your input. If you have an ideal valve for me, I'd be happy to buy it from you if you're a salesman there. _________________ 1983 Vanagon Diesel L
Posted: Wed May 07, 2008 4:06 pm Post subject: |
Okay here's some pics. But before i start, i hate to tell you-DON'T USE COPPER in a VO tank. It will corrode . Not right away but in a year or 2 it will hit critical mass and rot within weeks or days and then you will have coolant in your fuel and then you'll have to dish out for a new pump and injectors.
My wonderful transporter
tank behind seat
heated 5 micron VO fuel filter
double 3 way hydroforce valves
components in engine bay
vegetherm and sensor |
Posted: Thu May 08, 2008 4:02 am Post subject: |
Great shots, man, thank you.
I've seen tons of pictures of guys using copper tubing inside their tank. Would you suggest aluminum perhaps? I do have a local source for aluminum tubing, no problem.
What's causing the corrosion...the oil (not the coolant)?
How exactly did you route your fuel returns? Would you recommend the double 3-ways over a 6-way then?
Excellent project. That's too cool. _________________ 1983 Vanagon Diesel L
Posted: Thu May 08, 2008 8:13 am Post subject: |
aluminum would be okay even better would be stainless.
They corrode due to some electro chemical reason [ i forget exactly what], but the problem is how it degrades fine day ,bad the next.
I would suggest one 6 way valve, keeps it simpler and easier to attache to the body. The Pollack brand is nice because it has 3/8 " fittings on the feed side and 5/16 "on the return, makes it a little easier to plumb. |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Thu May 08, 2008 12:29 pm Post subject: |
coolwind57
I helped i guy out with a home vw diesel gen. system running on oil. I found a SAAB 900 with a auto tranny cooler that was part of the lower radiator hose. It had an in put for 3/8 or 1/4 hose that ran thru a coil inside the Coolent/radiator hose. The diesel had to be started on diesel then a coolent temp switch fliped it over to oil when hot .
Ill run thru the wrecking yard and see if i can find one and post some pics..
jcl |
Posted: Thu May 08, 2008 4:10 pm Post subject: |
is it 50 - 75 F or C ? it should be about 80-100 C for it to be close to diesel viscosity. You need an extra heater with some kind of thermostatic control. That's why a vegetherm works so great. Very simple, hose on one end, one out, 2 wires with 2 more to control the relay with the sensor.135 bucks or less with the sensor. Using your heater connections will be perfect.
Pollack valves are very reliable when mounted properly-no hanging off the engine with a tye-wrap.
I've only seen one fail.They are Ford standard equipment on trucks with 2 tanks. |
Posted: Mon May 12, 2008 4:17 am Post subject: |
Sorry for the delay in answering.
The guy who sold the heated filter says it'll increase the temp another 50-75 degrees Fahrenheit. I'm sure that depends on many variables.
I am a bit concerned about not having this thing on a thermostat. I'll have to look into this more. _________________ 1983 Vanagon Diesel L
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2329 Location: Southeast Kentucky
Posted: Mon May 12, 2008 8:11 pm Post subject: Veggie oil... fuel tank |
It would seem to me that the tank should be located mid-way underneath between the two chasis beams. There is a lot of space there!
Has anyone considered such an installation? _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
johntyberg Samba Member
Joined: March 28, 2008 Posts: 13 Location: Long Beach, CA
Posted: Tue May 13, 2008 4:37 am Post subject: |
I briefly considered installing mine there, but I'd prefer to have optimal insulation. I'm looking at having my tank installed directly behind the two front seats. It'll be enclosed within a sort-of entertainment cabinet.
I'm looking to be pretty creative: I'll finish in maybe a cool exotic wood (I work in the wood flooring business). I'm going to have a DVD player in the center and maybe speakers on the outer edges. The tank will be inside and well insulated. I'm actually looking at having a blower push heat from the top of the tank for circulation during the winter, so I'll have vents that I can shut off in the summer. Filling and observation of the tank will be accomplished via a hinged door or two.
Sounds ambitious? Well, this all is the plan in my head for now -- subject to change one I get going on it. _________________ 1983 Vanagon Diesel L
tencentlife Samba Member
Posted: Tue May 13, 2008 9:22 am Post subject: |
Reiney built the tank at my shop several weeks ago, but he went East for awhile, took the Dodge (with 100 gal of WVO in the back, almost enough for the one-way trip!) so his Vanagon WVO project waits at home. Pretty heavy-duty tank, though.
Reminds me, I gotta email that dude. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Tue May 13, 2008 9:34 am Post subject: Re: Veggie oil... fuel tank |
AndyBees wrote: |
Has anyone considered such an installation? |
I've seen them done, some else mentioned the guy who has them
ready to slap one under on the right side.
Only problem is filling it. One customer fills her's by using another fuel pump into a 3/8 " line while driving. But she also had a filler neck right behind the r/f wheel and dirt managed to work it's way in and we had to remove the tank to clean it. I'm not saying his will be the same ,just keep it in mind. |
