don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2829 Location: West Palm Beach, FL
Clara Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Clara Samba Member
Posted: Tue May 20, 2008 9:50 pm Post subject: |
EverettB wrote: |
I think 81/82/83 are for the center pivot point? |
er... ya.
It's been a long time since I've changed an accelerator cable.
(Watch out, now three will break in a week) _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed May 21, 2008 8:04 am Post subject: |
That link never works for me...I wonder why? Hmmm....here's another way from a '67. I guess you older bus guys don't put it inside or they only stay on the outside of the little flap. I always add a washer to the pedal link 'cuz that little crush always wears away anyway.
62Baido Samba Member
Posted: Wed May 21, 2008 8:23 am Post subject: |
My bus used to be setup like this until the bracket broke off!
Now it's all better of course! I set it up like my 67.
My 67 was setup like the one EverettB posted.
BarryL wrote: |
_________________ 1962 Kombi Bus - My rolling project!
http://www.norcalaircooledgroup.org/ |
BarryL Samba Member
Posted: Wed May 21, 2008 10:19 am Post subject: |
You shouldn't have to open the eye unless it's been smashed shut. It's a tight fit and you must put it on the ell bracket before installing the bracket. The outermost hole is lower "geared" than the closer hole for foot-to-gofastness. |
Posted: Wed May 21, 2008 11:00 am Post subject: |
Thanks for the responses.
BarryL, doesn't your mounting method limit "pedal to the floor" travel? (Pedal to the metal) so to speak. _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Wed May 21, 2008 12:54 pm Post subject: |
Barry, I think why Clara's website don't work for you is because it has bandwith limitations being a free hosting site.
As soon as a post is made on the samba linking to the freeweb site, lots of people go looking at it, (probably big pictures) exceeding the bandwith limitations, then the site temporarily shuts off that page. _________________
BarryL Samba Member
Posted: Thu May 22, 2008 9:48 am Post subject: |
d_ville wrote: |
BarryL, doesn't your mounting method limit "pedal to the floor" travel? (Pedal to the metal) so to speak. |
You got me worried so I went and looked and tried the gas pedal to see if it hits. Panic: no travel! Then I remembered the engine is removed temporarily so the pedal is already sitting on the metal and hence the picture like that. I've already given myself the Waldo Award so no making fun of me. |
Ian Samba Moderator
Posted: Thu May 22, 2008 9:52 am Post subject: |
I had mine setup like BarryL and then the J-shaped metal hanger that is welded on to the body broke! It was hooked up this way since before I owned it. It is still working but it is weaksauce.
I'm going to fix the hanger and put the L-shaped bracket on the outside like EverettB posted, my Truck and the others I've looked at recently have it on the outside.
My Kombi is a late 66. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
Posted: Fri May 23, 2008 9:29 am Post subject: |
My Factory Service manual shows the L-shaped bracket in the middle of the J-bracket, not on the outside as Ev has shown. Why the difference? |
Posted: Fri May 23, 2008 10:17 am Post subject: |
chrisflstf wrote: |
I always wondered that too. I know on one of my Buses I tried that and the U-shaped piece that connects to the pedal was totally crooked so it felt wrong. _________________ How to Post Photos
BarryL Samba Member
Posted: Fri Aug 01, 2008 11:07 am Post subject: |
Ok. Now I'm concerned. Is there a change in years when this got moved to the outside? The '67 Westy has that crookedness being mounted on the inside and I want to move it back before I put the pan back on. Was there a gas pedal link that was "s" shaped? Sheesh, before hitting "submit" I went and looked at my unrestored one-owner (before me) '67 Kombi and it has it on the outside. If nobody replies then I'm moving the Westy's to the outside. The Bentley shows it on the inside. |
mattoreg Samba Member
Posted: Fri Aug 01, 2008 11:40 am Post subject: |
What purpose does the coiled wire (spring?) serve? _________________ 62 Turkis DC |
Aaron Samba Luddite
Posted: Fri Aug 01, 2008 12:18 pm Post subject: |
Holds it on, there's a notch the closed end of the spring locks in. |
Ragman The Sambinator
Posted: Fri Aug 01, 2008 1:18 pm Post subject: |
BarryL wrote: |
I think that says it all right there....unless someone can reason otherwise. |
