Best/ correct way to lower a 64 split on a budget...??
Tom1964bus
Tom1964bus is offline
PostPosted: Thu Jun 12, 2008 1:02 pm    Post subject: Best/ correct way to lower a 64 split on a budget...?? Reply with quote
im a total novice with my bus but i was wondering if i can get it looking cool without spending a fortune!? thanks.
Nor_AL_67
Nor_AL_67 is offline
PostPosted: Thu Jun 12, 2008 1:07 pm    Post subject: Reply with quote
You have a split bus, you're already cool.
http://www.thesamba.com/vw/forum/viewtopic.php?t=66927
sled
sled is offline
no, not really..lowering a bus can be costly however you look at it.
read the FAQ at the top of this forum...it will tell you everything you need to know. If it doesnt...use the search function for all your unanswered questions.
drive your split.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Jun 12, 2008 1:31 pm    Post subject: Re: Best/ correct way to lower a 64 split on a budget...?? Reply with quote
Load it up! Razz
Tom1964bus
PostPosted: Thu Jun 12, 2008 2:51 pm    Post subject: Reply with quote
ok so....dropped spindles and beam adjusters up front? straight axle coversion at the back? this will not be cheap! OUCH!!
Andrew
Andrew is offline
PostPosted: Thu Jun 12, 2008 3:04 pm    Post subject: Reply with quote
Best advice I can give. Whenever you're working with either the suspension or the brakes on your bus. Don't ever try to do it skimp on it and do it on a budget. Spend the money and do it right. When you do the suspension, it'll only hurt once.
-Andrew
AGUILAR3
AGUILAR3 is offline
PostPosted: Thu Jun 12, 2008 4:19 pm    Post subject: Reply with quote
Once I get rid of my Mango,Im getting a Single Cab and hopefully,dropping it the right way.
Im guessing $1000 for the rear,$500 for the front and you cant forget about $500 for Safaris.
Am I way off??
the.fordhams
the.fordhams is offline
PostPosted: Thu Jun 12, 2008 4:52 pm    Post subject: Reply with quote
On a budget dropped spindles are good, straight axle (SA) is right too but you could do it cheaper with an SA kit if you shop for a transmission or even (gasp) re-using your own transmission with a flipped diff. But like Andrew said if you're in there you may as well do it right.
63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender
VWAdam
VWAdam is offline
PostPosted: Thu Jun 12, 2008 4:56 pm    Post subject: Reply with quote
As far as the front end, it really depends on the condition of your suspension parts right now. I was lucky with mine, my spindles were in great condition when I had them flipped. After new tie rod ends and a drag link the Bus drives nicely.
The straight axle kit isn't too bad if you find a used trans for a good price.
Of course, if you're really on the cheap, you can use the RGBs for a while, just not very low.
All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
my65vert
my65vert is offline
dropped spindles $150
offset springplates $150
68 bug trans ??junk yard $150??
total $450
plus wheel cylinders and shoes for the rear possibly?
OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment.
VWAdam
VWAdam is offline
PostPosted: Thu Jun 12, 2008 4:58 pm    Post subject: Reply with quote
Oh, I forgot to add, if you are a total Bus (and VW) novice, I would advise to just make sure your Bus is running and driving safely as it is and get your feet wet with it before you get into something like lowering.
rockettdoggie
rockettdoggie is offline
PostPosted: Thu Jun 12, 2008 10:50 pm    Post subject: Reply with quote
total $450
I'll take 2 sets of those spindles if they are any good at that price.
57 Oval
my65vert
my65vert is offline
PostPosted: Thu Jun 12, 2008 10:55 pm    Post subject: Reply with quote
email [email protected] send your spindles.
http://www.thesamba.com/vw/forum/viewtopic.php?t=293953&highlight=southern+suspension
OGJHC
Kombisutra;
malachai
malachai is offline
PostPosted: Fri Jun 13, 2008 2:42 am    Post subject: Reply with quote
I think I paid about 1300 quids for hayden at panelkraft to lower my bus, I have a something welded into the front beam and a SA kit with a 1500 beetle box at the back.
I don't know his number but if you are anywhere near Letchworth near stevenage then you wont find anyone better, hes the guy with the slammed yellow german post panel van which seems to win awards just for driving into a show
http://www.facebook.com/groups/175509642524184/
rockettdoggie
PostPosted: Fri Jun 13, 2008 11:10 pm    Post subject: Reply with quote
Thanks for the info. I have an extra set of spindles that will go out in a bit Applause
57 Oval
purplepeopleeater
purplepeopleeater is offline
PostPosted: Sat Jun 14, 2008 1:14 pm    Post subject: Reply with quote
Dang, Ill have a set! is that with kingpins too?
Erik G
Erik G is offline
PostPosted: Sat Jun 14, 2008 1:29 pm    Post subject: Reply with quote
you can do drop spindles in the front, and readjust your rear springplates a couple notches to match the front end, even with redux boxes. total cost about $200 and some time
provision962
provision962 is offline
PostPosted: Sat Jun 14, 2008 1:31 pm    Post subject: Reply with quote
trade your front end for mine. I have a 64 delux split that is lowered and I want it raised up. Where are you located?
Desijae
Desijae is offline
PostPosted: Sat Jun 14, 2008 3:09 pm    Post subject: Reply with quote
I got a pair of Travis's spindles. With everyday hard driving they haven't broke yet..and he installed them for me. Very Happy
64 Beetle 2275/Garage Whore
64' Panel Daily Driver/State explorer RIP 11.18.11
http://www.thesamba.com/vw/forum/viewtopic.php?t=488872&highlight=panel+dead
63' Single Cab/Daily
my65vert
my65vert is offline
PostPosted: Sat Jun 14, 2008 4:39 pm    Post subject: Reply with quote
John, you have our offset springplates too!!!
Leave us some feedback in the feedback forum for southern suspension
OGJHC
Kombisutra;
