Bus Won't Start? Starter? =/
rudygetz
Guaperia Ful Tine
rudygetz is offline
PostPosted: Mon Jun 16, 2008 10:34 am    Post subject: Bus Won't Start? Starter? =/ Reply with quote
I had something plugged in to the 12v Cig and left it running when the bus was off.
I had to push start it...
The battery doesn't seem to recover or recharge.
I have a two battery set up that powers radio, sub, etc.
The second battery is fine...but the bus won't start off either battery.
Is it the starter?
1965 Ragtop Bus
1967 Beetle
panic311
panic311 is offline
PostPosted: Mon Jun 16, 2008 11:04 am    Post subject: Reply with quote
Give this link a try:
http://www.type2.com/bartnik/starter.htm
Also, this book has an entire chapter dedicated to trouble shooting "engine won't start" problems. It is written in a format that any man can understand. Hope that info helps.
http://www.amazon.com/Keep-Your-Volkswagen-Alive-Anniversary/dp/1562614800
"You don't need a weather man to know which way the wind blows"
1974 Westfalia (The Treehive)
1.8L running a single Weber Progressive and a 009 dizzy
