bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Thu Jun 19, 2008 5:38 am Post subject: |
mynameismud wrote: |
When I installed the new wiring harness last year, everything was hooked up..Now I'm miffed as why the 3 aren't.. I have done no major cleaning under the speedo- to pull them loose. Regardless, I will re-hook them back up (always a fun task to get under there)..and re-install my battery, which I had dropped off this am to get the charge checked - completely drained, and go from there.
Another question- When installing a new starter (12V) do you have to pull the engine to install the new bushing? I would assume it would make it easier.
Changing my ID very soon to :KursedKombi.. |
an alternator will not charge if dash bulb is burnt out or in your case if bulb housing is not in speedo. a generator can charge tho'.
answer to bushing: usually the bushing needs to be changed when installing a new starter. i use an auto stick rather than stock starter as no bushing is required. usually auto stick is only $5 more at kragen or auto zone than a normal bushing supported one.. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5928 Location: Middle of a corn field
Posted: Thu Jun 19, 2008 6:10 am Post subject: |
bill may wrote: |
answer to bushing: usually the bushing needs to be changed when installing a new starter. i use an auto stick rather than stock starter as no bushing is required. usually auto stick is only $5 more at kragen or auto zone than a normal bushing supported one.. |
Thanks Bill - Yes, I am aware a new bushing need to be changed with a new starter- I was wondering if it required an engine-pull (especially, since I just pulled it this past week to install a new fan, that came loose). I'll keep the auto-stick starter in mind, next time. _________________ Even YOU can prevent FIRES!
Click to view image |
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Thu Jun 19, 2008 6:26 am Post subject: |
bill may wrote: |
Thanks Bill - Yes, I am aware a new bushing need to be changed with a new starter- I was wondering if it required an engine-pull (especially, since I just pulled it this past week to install a new fan, that came loose). I'll keep the auto-stick starter in mind, next time. |
to do it the proper way, Yes. But it can be done engine in. use a tap and get it to bind and pull it out. the problem however is if it is a tight fit which it should be, might be difficult to re-install. In summery if your starter is bad, get a damn auto starter and be done. |
Posted: Thu Jun 19, 2008 5:34 pm Post subject: |
Just reattached the 2 pulled wires to the idiot lights - the 3rd one is from the dome light harness (one red connected to the dome light switch on speedo pod) the other shorter one goes to where? Not the wiper switch?
So, I reinstalled my battery, hooked up ignition switch and the starter turned over- but wouldn't go to run- like it was stuck. So, I took off the ignition switch and hotwired it. After a few seconds it caught and fired up, and idled fine. Looks like the culprit was a faulty repro ignition (less then 6 months old... ) which replaced my orginal one, that got smoked..Maybe I need to order 2 and keep one as a spare. _________________ Even YOU can prevent FIRES!
Ollie W Samba Member
Joined: May 20, 2004 Posts: 801 Location: Portland, OR
Posted: Thu Jun 19, 2008 9:00 pm Post subject: |
If you can find an original switch, gabriele can rekey it to match your doors. That's what I did. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Jun 19, 2008 9:24 pm Post subject: |
Just reattached the 2 pulled wires to the idiot lights - the 3rd one is from the dome light harness (one red connected to the dome light switch on speedo pod) the other shorter one goes to where? Not the wiper switch? |
One goes to the wiper switch, the small red one goes to the domelight switch. |
Posted: Fri Jun 20, 2008 3:59 am Post subject: |
Ollie W wrote: |
yah- i hade him do that too- then i proceeded to smoke the original swtich.. bad thing is the OG switches are pretty pricey even w/o keys. _________________ Even YOU can prevent FIRES!
Posted: Fri Jun 20, 2008 4:00 am Post subject: |
campingbox wrote: |
thanks greg- i assumed so, since it was shorter - and looked like it goes there but connecting the domelight wire to the wiper switch, seemed odd in my head. _________________ Even YOU can prevent FIRES!
