hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Jul 03, 2008 8:52 am Post subject: 40hp idling question |
40hp engine. 30pic carb,010 dizzy, valves adjusted,timing correct etc. car idles at 825rpm at operating temp. Here s my question . When the car is cold I have to stay on the gas pedal to warm up the engine for the car to idle. after the warm up the car idles fine and theres no cutoff. No popping,no issues. is this normal where I have to just warm up the engine for the car to idle or should the car idle when cold as well I mean was this normal from the factory where you had to warm up the engine or should I just raise the rmp to 850-900 _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Thu Jul 03, 2008 8:59 am Post subject: |
Adjust the choke.
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Thu Jul 03, 2008 9:03 am Post subject: |
X2..and/or make sure its even working? |
hsosa1 Samba Member
Posted: Thu Jul 03, 2008 9:04 am Post subject: |
Thanks, How do you adjust it which way do u turn it and do u adjust the choke when the engine is at operating temps _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
KTPhil Samba Member
Posted: Thu Jul 03, 2008 9:07 am Post subject: |
Engine must be stone cold. Loosen 3 mounting screws just enough you can rotate the housing. Hold the throttle open, and rotate the housing first clockwise all the way (but don't force it), then slowly counterCW until the throttle arm screw is on the highest step of the fast idle cam when you let the throttle close. Tighten the three screws.
Start it up, and after five minutes blip the throttle and check that the choke has opened enough you are now on the lowest step of the cam. If not, shut off the motor, loosen the 3 screws, open the throttle, and slightly rotate the housing clockwise until it's on the low step. |
hsosa1 Samba Member
Posted: Thu Jul 03, 2008 9:18 am Post subject: |
ok , when u say hold the throttle open do u mean all the way down. also when u say highest step of the fast idle cam your referring to the upper top step not bottom correct. Ok sounds easy enough . thanks and I thought I was done messing with the car. its always something coming up. thanks _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Thu Jul 03, 2008 9:28 am Post subject: |
And what about the heat riser on the intake manifold, carb pre-heat tube, and cooling flaps? Even though you're in California, they are still helpful... |
hsosa1 Samba Member
Posted: Thu Jul 03, 2008 10:38 am Post subject: |
Thanks guys . I adjusted the choke and the car now idles when cold. and hot. now I need to install my judson. never ends . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
KTPhil Samba Member
Posted: Thu Jul 03, 2008 10:52 am Post subject: |
hsosa1 wrote: |
I thought I was done messing with the car. its always something coming up. thanks |
It's an old VW. You will NEVER be done messing with it! |
