pushticat Samba Member
Posted: Thu Jul 17, 2008 1:42 pm Post subject: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
This is the fuse box in my 1985 Wolfsburg Westfalia Vanagon.I want a cover for it.I have been told that the cover below should fit it but I don't see how.Can anyone confirm that this is so,or if not point me in the direction of the correct fuse cove(if any)-part no.etc.?Perhaps someone will recognise this particular box.
Thanks.Alan
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Thu Jul 17, 2008 1:46 pm Post subject: |
The fuse cover that fits yours will be a clear, plastic cover that snaps in place over your fuses. The cover in your pic is for an 86+.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D937%2D555%2DM
Spend enough time and money, and you can make anything fit.... For eight bucks, I wouldn't dream of wasting any time trying to retrofit that newer one. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
Posted: Fri Jul 18, 2008 4:52 pm Post subject: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
Thank you ,much appreciated.
Alan |
Terry Kay Banned
Posted: Fri Jul 18, 2008 9:14 pm Post subject: |
Here's another one of them deals where VW mixed & matched parts.
The fuse box cover pictured is brown and fits an 84 or 85 Vanagon--fit mine as well as a bunch of other's.
The fuse box pictured must be a left over from and earlier model that some disgruntled worker fit into an 85.
I have never seen an 85 with the ealy fuse box pictured--an early 84 possibly could have been fit with a left over 83 fuse box---
Strange stuff ---- _________________ T.K.
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Fri Jul 18, 2008 10:58 pm Post subject: |
TK, so when was this change made? 85 seems to be a bit of an oddball year. Mine was built 20 Dec 1984, has the late slider, cast lower control arms, and the early fuse box. WTF? _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
Terry Kay Banned
Posted: Fri Jul 18, 2008 11:17 pm Post subject: |
Clark,
There are so many oddities to a 85 Vanagon, it's difficult to pin point when VW did anything to any specific vehicle--and from what I have seen there is nothing definate.
Like this fuse box cover--
In the VW parts bok from 84 to 85 they allegidly had a full fuse box cover.
Nothing off the wall like a snap on clear cover is even mentioned.
I have never seen that fuse box pictured here other than in real early ( 80 to 83 ) Van's.
The parts number for all brown 84 & 85 fuse box cover's is;
251 937 90V
And thats it.
The Back late model cover is;
251 937 01C
The Brown cover's are all now NLA--I bought them all from VW and I have depleted my stock of them--they are all gone forever.
It's real heard to pin point the cut off dates of old inventory, and when or where VW switched parts to current parts number's available part number's.
It's pot luck with what they used in production at any given time. _________________ T.K. |
r39o Samba Polizei
Posted: Sat Jul 19, 2008 11:54 am Post subject: |
To make that cover fit, you need more parts.
Early 85 had early wiring.
Late 85 (Wolfsburg models) had the later wiring which had the cover.
You need to look at a later van to see what you need. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Terry Kay Banned
Posted: Sat Jul 19, 2008 12:45 pm Post subject: |
<<Early 85 had early wiring.>>
& some late 84's had later wiring & later model fuse boxes.
<<Late 85 (Wolfsburg models) had the later wiring which had the cover.>>
So did some of the GL's, & Westfalia's.
I don't think VW had any set rules of the road with parts placement.
There are too many inconsistencies and off the wall odd, parts installation's at near the end of a year or change of model's.
Like brown interiors for example.
I've seen brown interior's in 86 Vanagon GL's that should have grey.
Some folks say they've seen 87's with brown interior's--
It's just another crazy VW thing. _________________ T.K. |
r39o Samba Polizei
Posted: Sun Jul 20, 2008 11:38 am Post subject: |
So the point here is you need to see what parts you need to make the fuse box cover work. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Terry Kay Banned
Posted: Sun Jul 20, 2008 8:14 pm Post subject: |
The fuse box cover pictuerd is for an 83.5 to 85 later style fuse box.
The fuse box pictured is an earlier vintage that somwhow got built into an 85.
How?
I'm not sure, but I sure haven't seen anything quite like this before.
An 80 to early 83 fuse box cover would be a direct fit in this case. _________________ T.K. |
Bills85Westy Samba Member
Posted: Wed Sep 14, 2016 5:05 pm Post subject: Re: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
My December 84 (85 model year) Vanagon Westfalia has the same fuse box. The cover is clear plastic.
The Westfalia owner's handbook shows this fusebox and has the description of fuses. With all due respect, I think it's correct for what it is. My Westfalia also has a smaller "add on" fuse block to the right of the fuse box which is also factory.
If desired, I can scan and post copies of the handbook
This is the correct cover:
http://www.thesamba.com/vw/classifieds/detail.php?id=1583897
(not my ad...just pulled from the classifieds as an example) _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Thu Sep 15, 2016 4:13 am Post subject: Re: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
(Slightly off tonic) I reverse engineered that bigger cover a while back and 3D Printed it. With a couple of more tweaks it should work... |
kerryc Samba Member
Joined: October 25, 2017 Posts: 1 Location: British Columbia
Posted: Wed Oct 25, 2017 6:37 pm Post subject: Re: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
Hello,
Unibagel, any chance I can try to print your STL?
Cheers.
Kerry |
under_sky1 Samba Member
Joined: March 18, 2020 Posts: 2 Location: South Africa
Posted: Wed Mar 18, 2020 9:23 am Post subject: Re: 1985 Wolfsburg Westfalia Vanagon fuse box cover |
unibagel wrote: |
Hi would you be able to share your STL file, my dad has asked if i can help him with the fuse box cover and from the images above that were posted. Your help would greatly be appreciated
Reagrds |
Posted: Wed Mar 18, 2020 9:42 am Post subject: |
Have you otherwise go the dimensions of this cover above and i will try 3D draw it then share it with the community ? |
