Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10365 Location: Sunshine Coast B.C.
Posted: Thu Jul 24, 2008 3:22 pm Post subject: Correct? Incorrect? PIC (spare tire parts orientation) |
Hi all.
Kinda like the subject says. Sucha lame question coming from a guy who has his conversion running....
I'm hoping this is the right way though I suspect it may not be.
Installed the other way, the rad hose is in the way. (it's a FLAPS equivalent)
Thanks!
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
need2boat Samba Member
Joined: November 13, 2007 Posts: 123 Location: North Jersey
Posted: Thu Jul 24, 2008 6:03 pm Post subject: here what it looks like on mine. . . |
I happen to have these pics on my mac. It should give you a good idea.
JFF _________________ 1987 Syncro Adventurewagen: Vincent Van-Go
1998 SAAB 900 SE Coupe: Black Swan |
Posted: Thu Jul 24, 2008 6:32 pm Post subject: |
Thank you for posting those images JFF.
That makes sense. The curve of the rod more or less follows the sidewall on tire. I did end up installing it that way. I kinda shoved the hoses around til it fit.
On mine, there seems to be a *hair* of pressure on the "upper" rad hose. Cutting/welding to drop the clamshell a little may be the solution.
This water cooled stuff is still new to me.
(Jetta engine into my air cooled Westy)
Cheers,
VE7TBN |
Posted: Fri Jul 25, 2008 10:27 am Post subject: right on! |
no problem, Do you see the valve to turn off the coolant/heat to the front for use in the summer. It's nice to have and cost about 4.00 with parts from Home depot.
Posted: Fri Jul 25, 2008 10:48 am Post subject: Re: right on! |
need2boat wrote: |
JFF |
Yup. I noticed it.
I installed a new heat control valve as the cooling system is almost 100% new.
That valve makes good sense though. Especially since the cables tend to f up and the valve itself will f up eventually too.
VE7TBN |
