Paint is done!
Bleyseng
Bleyseng is offline
PostPosted: Fri Jul 25, 2008 6:52 am    Post subject: Paint is done! Reply with quote
Finally I can now reinstall the engine as the painting rust repairs are done. I'll clean it up this weekend as time allows and install the newly recovered seats too.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
camit34
camit34 is offline
PostPosted: Fri Jul 25, 2008 6:59 am    Post subject: Reply with quote
w00t
must be a good feeling...
In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
cc79westie
cc79westie is offline
PostPosted: Fri Jul 25, 2008 7:00 am    Post subject: Reply with quote
Ahhh fresh sage green paint.. looks great! Post pic of interior when you finish.
1979 Westfalia (Sage Green)
1966 Pontiac GTO
1977 Chevy Monza 5.0 V-8
1984 Datsun/Nissan 300ZX
1989 Plymouth Reliant K
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Jul 25, 2008 7:47 am    Post subject: Reply with quote
A quick painting question (since mine is going to going to the paint shop in October)....
I want to make sure that my painter doesn't clog up the "weep holes" a tthe bottom of the flat body panels. He does nthis for a living so he should know what he is doing but how do you keep those open?
I am just trying to prevent future rust.
2VWs1BMW
2VWs1BMW is offline
PostPosted: Fri Jul 25, 2008 9:08 am    Post subject: Reply with quote
sweet! mine's going in for paint on monday.
viva la sage green! Cool
- Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi
1977_L63H_P27
1977_L63H_P27 is offline
PostPosted: Fri Jul 25, 2008 3:17 pm    Post subject: Reply with quote
Let me ask; you did this outside with no covering of any kind? I'm just wondering. I need to paint two buses, and have been thinking of building a temporary paint booth.
Your's looks great. Congratulations!
busdaddy wrote:
...and try a few chubby ones until you find one you like.
1977 Westfalia P27 Green Bay Bus
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
Herbst '71
Herbst '71 is offline
PostPosted: Fri Jul 25, 2008 5:44 pm    Post subject: Reply with quote
Randy,
Would it be possible to stick golf tees in the weep holes or maybe the plastic part of the cue tip? I don't think it is safe to say shaft on the samba.
Rik
'71 Deluxe/1600 DP
"Fortunately my mistakes are serving as a warning for others."
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Jul 25, 2008 7:26 pm    Post subject: Reply with quote
randy~
unless your painter is using some crazy technique (like a roller) drains and such should not be affected by painting. the only thing that would plug something like that up would be too much material (paint) or a run/sag on the panel. you should have nothing to worry about Very Happy
Randy in Maine
PostPosted: Fri Jul 25, 2008 8:02 pm    Post subject: Reply with quote
No, he will be spraying a single stage in his booth and will be doing interior and exterior.
I don't think it will be an issue, but I will ask him how he does it.
ccpalmer
ccpalmer is offline
PostPosted: Sat Jul 26, 2008 6:08 am    Post subject: Reply with quote
You could put some non-paintable silicone caulk in the holes, then after painting remove the silicone - I've done that a few times to keep holes from shrinking...
'71 Westy
Bleyseng
Bleyseng is offline
PostPosted: Mon Jul 28, 2008 6:20 am    Post subject: Reply with quote
Yes, I painted outside in the early evening when there isn't a breeze. Any bugs that do land brush off as its been in the high 70's when I paint and it dry fairly quickly.
I used a single stage PPG Concept Urethane, nice paint but pricey.
Lots of epoxy primer and sanding primer was used before the final coat as I sanded out and sandblasted rust spots. I didn't need to used much bondo as the body was fairly straight.
Its pretty easy to shoot the final color, its a bitch to get there doing all the prepwork.
