Which Year Rear Hatch Is Interchangable?
Vwman55
Vwman55 is offline
PostPosted: Thu Jul 24, 2008 1:06 pm    Post subject: Which Year Rear Hatch Is Interchangable? Reply with quote
Which year rear hatch is interchangable with a '91?
devesvws
devesvws is offline
PostPosted: Sun Jul 27, 2008 10:52 am    Post subject: Reply with quote
i think they all fit
morymob
morymob is offline
PostPosted: Sun Jul 27, 2008 1:29 pm    Post subject: Reply with quote
earlier ones button sticks out then they went flush-dont know when change made.84 out/86flush,if original lids.
?Waldo?
?Waldo? is offline
PostPosted: Sun Jul 27, 2008 2:49 pm    Post subject: Reply with quote
My '84 has a flush button, my '83 pops out.
Andrew
I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site.
Captain Pike
Captain Pike is offline
PostPosted: Sun Jul 27, 2008 3:31 pm    Post subject: Reply with quote
Slight external differences,some have wipers, some don't, raised lock or not. All bolt up and with paint http://www.gti16v.com/vwcolors.htm only you will know.
LEARN TO SELF RESCUE
....Bad Sneakers....
Vwman55
Vwman55 is offline
PostPosted: Mon Jul 28, 2008 7:51 am    Post subject: Reply with quote
Thanks for the replies. My '91 has the lock the pops out, must have been replaced once. I have a replacement from a '85 has the larger flush opening for the lock. Don't have the lock yet. The seal(grommet) for the lock is there, is the lock all I need or is there another seal/grommet?
Thanks Again!
Wellington
Wellington is offline
PostPosted: Mon Jul 28, 2008 9:39 am    Post subject: Reply with quote
Don't later version have a round VW emblem in the middle that the earlier ones don't have?
mr_vanagon
mr_vanagon is offline
PostPosted: Mon Jul 28, 2008 2:28 pm    Post subject: Reply with quote
My '89 has the round VW badge in a recess in the middle of the rear hatch.
One word of advice. If you have the hatch off and the new hatch will have a wiper and defroster, might as well replace the rubber boots that cover the wiring and hose for the wiper, washer and defroster. It isn't required that the hatch be off for this but it makes it easier and you'll have to pull the wires and washer hose out anyway. Also be advised that there are left and right versions for the boots so be sure to get the right parts.
'68 Autostick Bug Mom bought new
'89 Tintop Vanagon Dad bought new
devesvws
devesvws is offline
PostPosted: Fri Aug 08, 2008 7:01 pm    Post subject: Reply with quote
will the 1980 lock tumbler fit in a 1991 lock?
