jazzed Samba Member
Joined: August 03, 2002 Posts: 628 Location: Eugene, OR
Posted: Tue Jul 29, 2008 2:15 pm Post subject: Brake Job Problems |
Finally got all new wheel cylinders and linings installed and bled the lines, but have found that I need to vigorously pump the brakes to make the vehicle ('61) stop. On first pump, the pedal goes to the floor and it takes about 6 pumps to get reasonable braking. I did not replace the master, as it was working fine before I started tearing things apart. Doesn't appear to be any leakage in the lines as the level in the master has remained constant. Any ideas where I might have gone wrong here? |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Tue Jul 29, 2008 2:28 pm Post subject: |
if you don't notice any leaking, then i think you still got air in your lines... _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
aggri1 Samba Member
Joined: February 17, 2006 Posts: 380 Location: Melbourne, Australia
Posted: Tue Jul 29, 2008 3:00 pm Post subject: |
Is the pedal firm when it does finally start to brake? If so, it's likely in the adjustment (you need to adjust the brakes). If it never gets firm, then air in the lines is more likely.
Cheers, A. |
pblanco10 Samba Member
Joined: February 14, 2007 Posts: 671 Location: South Hialeah (Kendall)
Posted: Tue Jul 29, 2008 3:30 pm Post subject: |
Sure sounds like air in the lines. I just recently did my brakes in my 66 SC, I ended up going to auto parts store and buying the 1 man brake bleeder for 7$. Worth every penny. I had so much air in my system (didnt know it) that I could provide life support under water for about 1 hr )
Bleeding brakes takes time and patience. I was close to buying disc brakes for my SC until I took my time to bleed the brakes correctly.
I still want discs though. _________________ Original Miami VDUB member
66 Type 2 SC |
