orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Thu Sep 13, 2007 7:49 pm Post subject: rim size problems |
so we have a chance to up-grade the rims on the bus since it doesn't have the og matching ones and we're thinking about getting some from a guy close in CT. The problem is the size. two are 15x5.5 and two are 15x4.5. Now the question is if we put the 4.5 up front and the 5.5 in the rear will there be any problems that might show up since its a stock heigh bus? Extra wear and tear the could happen from having smaller tires in the front, along with handling? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
mikey1two Samba Member
Posted: Thu Jul 31, 2008 12:58 am Post subject: |
what is the deal with the 5.5x15? I thought that the 15" rims were 4.5"
Did the make those? |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Thu Jul 31, 2008 6:26 am Post subject: |
Its an old post, but I think they are talking about stock because the mention correct dates! But stock 5.5"? |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Thu Jul 31, 2008 6:33 am Post subject: |
mikey1two wrote: |
But stock 5.5"? |
Porsche style chromies are 5.5" wide. _________________ Some people are so busy being clever they don't have time enough to be wise. |
von Heimlich Samba Member
Joined: December 26, 2004 Posts: 83 Location: Arizona City
Posted: Thu Jul 31, 2008 9:15 am Post subject: |
I've got two 356 chromies on the front of my stock height '61. They rub the rear fender lip even with 165's on them.
Hey, what color should stock 15" bus rims be?
I saw a set at a show once that were painted/powdercoated a light almond color. _________________ Drive it. |
Posted: Thu Jul 31, 2008 10:27 am Post subject: |
What is the offset on those chromies and how wide are they to make them rub in back? |
Clara Samba Member
Posted: Thu Jul 31, 2008 11:02 am Post subject: |
mikey1two wrote: |
I had some 356 chrome rims and was going to put them on my '61.
They were Lemertz and dated sometime in '65 or '66. (Ie these were not new or repro)
IIRC, the width of the rim was the same as 15" bus rims.
They fit fine on the front, but did not fit the back because the offset was different. The tire hit the rear wheel well. Totally bogus for buses.
I sold them to David Mayes about ten years ago.
I have been running 15" bus rims for my bus. I finally got a set powdercoated and installed June 2007, after having ugly 15" bus rims for years.
Feb 2006:
April 2006:
Dec 2007:
(hubcap clips will happen sometime) _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Jul 31, 2008 5:45 pm Post subject: |
were you running 5.5 wide in the back with the chromies? |
Clara Samba Member
Posted: Thu Jul 31, 2008 9:27 pm Post subject: |
IIRC the Porsche chromed wheels were 4.5" wide.
As I said, the offset was different than stock bus 15" wheels, so they did not fit. With the 356 rims, the tires were farther out from the center.
Other styles of chromed wheels may well have different specs. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Fri Aug 01, 2008 8:07 am Post subject: |
My 356 chromies are the same width, just offsett too far to fit the rear. They have an extra step on the hubcap side. I'd say the offsett is about an inch or so more than stock bug rim.
My bus 15's are very ugly. They need paint and tires before I can get them mounted. _________________ Drive it. |
