Autostick starter in a manual tranny?
74superTN
74superTN is offline
PostPosted: Fri Aug 01, 2008 7:55 pm    Post subject: Autostick starter in a manual tranny? Reply with quote
So i keep reading people saying "Just put a autostick starter in it!" but they never say if you have to change anything else...
I have a 1600 cc engine, original starter just died on me and i'm having a big PITA with my starter bushing coming out..I've already bought my new starter from autozone but its for an manual tranny because thats what I have..Does a autostick starter work the same? Can i just leave the bushing in if I install the autostick starter?
73 Thing
80 Vanagon Westy
bugninva
bugninva is offline
PostPosted: Fri Aug 01, 2008 9:06 pm    Post subject: Reply with quote
yeah, the autostick starter is "self-supporting" meaning it's housing extends to the other end of the starter shaft... there is no need for the bushing....
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
texasbuggy's
texasbuggy's is offline
PostPosted: Fri Aug 01, 2008 9:07 pm    Post subject: Reply with quote
If ya use one, just knock out the old bushing.
DrDarby
DrDarby is offline
PostPosted: Fri Aug 01, 2008 9:37 pm    Post subject: Reply with quote
You don't need to touch the bushing the auto stick starter has nothing to do with it.
Midwest Autosavers, Inc. Crystal Lake, IL
74superTN
PostPosted: Sat Aug 02, 2008 6:11 am    Post subject: Reply with quote
so the autostick starter will fit right in with the bushing still installed?
73 Thing
80 Vanagon Westy
DrDarby
DrDarby is offline
PostPosted: Sat Aug 02, 2008 7:14 am    Post subject: Reply with quote
Absolutely. I routenely install an A/S starter whenever replacing a starter and use them exclusively on conversions
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sat Aug 02, 2008 7:46 am    Post subject: Reply with quote
Here is what one looks like...
And here is the stock style that needs the bushing... don't mind the chewed up gear LOL Shocked
Yessirie.... the autostick starter never comes in contact with where the bushing is...
74superTN
PostPosted: Sat Aug 02, 2008 3:02 pm    Post subject: Reply with quote
ok so i replaced it...was your autostick starter way louder than the manual starter? mine's freakin loud!
Also...think a battery could die in about 5 months if all I've been doing is trying to start my bug with no progress made..meaning, she doesnt run for longer than a few seconds
73 Thing
80 Vanagon Westy
Bashr52
Bashr52 is offline
PostPosted: Sat Aug 02, 2008 3:05 pm    Post subject: Reply with quote
The autostick starter also has slightly more torque than a manual starter. It is a good cenversion for the bigger engines with more compression than stock, and cheaper than a high torque starter.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Aug 02, 2008 3:07 pm    Post subject: Reply with quote
Not that much cheaper these days. And the IMI has double the torque and a lot less weight.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
wvmedic
wvmedic is offline
PostPosted: Sun Sep 21, 2008 3:21 pm    Post subject: Reply with quote
I too am reading about autostick starters. I have a '67, manual. Do I simple buy a autostick starter for lets say...a '68 auto. and it will bolt right in and work without any problems?
Jeckler
Jeckler is offline
PostPosted: Sun Sep 21, 2008 4:16 pm    Post subject: Reply with quote
Yes, it really is THAT simple.
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
bon2198
bon2198 is offline
PostPosted: Sun Sep 21, 2008 4:55 pm    Post subject: Reply with quote
yeah, now that i think about it when i went to buy a new starter for my 70 the guy at Advanced never asked about what tranny i have. but the new starter came with a new bushing so i'm assuming the starter i have is for a manual. but reading this post the starter i have in there now is a whole lot louder and more torque than the original i had. but than again the original died. but my bug starts better than ever before!!!!
1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it.
ashman40
ashman40 is offline
PostPosted: Sun Sep 21, 2008 5:27 pm    Post subject: Reply with quote
74superTN wrote:
... Also...think a battery could die in about 5 months if all I've been doing is trying to start my bug with no progress made..meaning, she doesnt run for longer than a few seconds
If you can't get the charging system going for more than a few seconds at a time your battery will eventually die.
The primary function of the battery is to hold a charge so you can crank the engine. Once the engine is running the charging system takes over and provides most of the electricity for the car and "replenishes" the lost charge used to crank the starter. The starter load is the biggest power drain on the battery, well ahead of the wiper motor, horn and headlight on most cars.
You must have a pretty good battery to go 5 months w/o a charge before she died.
Note: "running down" the battery and recharging it will eventually "wear out" most batteries, reducing their ability to hold a charge.
AshMan40
wvmedic
wvmedic is offline
PostPosted: Sun Sep 21, 2008 7:10 pm    Post subject: Reply with quote
What is up with the autostick starter being "louder" than the starter for a manual? Is this a problem? Of course you only hear it when starting the vehicle...right?
wanta60sbug
wanta60sbug is offline
PostPosted: Thu May 03, 2012 4:55 pm    Post subject: autostick starter Reply with quote
OK, I have a 64 bus, So do I ask for a 68 bug autostick Bosch starter at Advance auto parts
ashman40
ashman40 is offline
PostPosted: Thu May 03, 2012 7:04 pm    Post subject: Reply with quote
The '68 starter was meant to mate with a 200mm flywheel/flexplate. Does your '64 bus have a 180mm or 200mm flywheel (sorry I don't know which year the type 2 switched to 200mm)? The teeth are different between the two flywheels.
AshMan40
supermanbidder
supermanbidder is offline
PostPosted: Sun May 19, 2013 10:33 pm    Post subject: What year for 74 bellhousing Reply with quote
What year autostick starters fit my type 1 74 bellhousing .?
Thanks tom
drs1023
drs1023 is offline
PostPosted: Mon May 20, 2013 11:46 am    Post subject: Reply with quote
Autostick starters from '68 and up is what you need.
supermanbidder
PostPosted: Mon May 20, 2013 11:54 am    Post subject: Reply with quote
Yup just bought a bosch thanks
