KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Thu Aug 14, 2008 7:17 pm Post subject: |
56_in_714 wrote: |
Did ovals come with Seat belts??? |
Nope. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
SluggerKelsey Samba Member
Posted: Thu Aug 14, 2008 8:43 pm Post subject: |
i have seatbelts in my 1965 bug. |
Posted: Thu Aug 14, 2008 8:53 pm Post subject: |
SluggerKelsey wrote: |
Congratulations, so do I! Even my '63 has seatbelts.... What's your point? Since a '65 precedes a '67, you know that they were installed after the car left the factory. Nobody said that seatbelts didnt exist prior to '67, only that they were not factory installed prior to '67.
Sorry, Tinkerbell, not trying to bite your head off, just reiterating a previous point. _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
frankobrad Samba Member
Joined: November 04, 2006 Posts: 4 Location: Fullerton, California
Posted: Thu Aug 14, 2008 9:36 pm Post subject: 1964 B-Pillar Seat Best mounting holes |
OK, can i ask this, should a 1964 Beetle have B-Pillar Seat Belt mounting holes for a three point seat belt set=up or was that feature added on later models? |
Posted: Thu Aug 14, 2008 9:43 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
frankobrad wrote: |
VW put mounts into the body in '64, they just didnt include the actual seatbelts. That was a dealer installed option that was made easy by the factory mounting points. _________________ -Kent (BaT "daleallen")
Posted: Thu Aug 14, 2008 9:46 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
67 Florida Deluxe wrote: |
frankobrad wrote: |
VW put mounts into the body in '64, they just didnt include the actual seatbelts. That was a dealer installed option that was made easy by the factory mounting points. |
How far up from the Botton of the rear window are the holes located on the B-Pillar? About half way? I cant feel them through my upolstry and i want to cut pretty near where they might be to look for them if i can.
Thanks |
Posted: Thu Aug 14, 2008 9:54 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
frankobrad wrote: |
Thanks |
The shoulder harness (if you opted for one) would be mouned were the top of the rear interior panel met the bottom of the rear quarter window. Here, you can see a large plastic plug on my '63.
For the bottom mount, the dealer would drill a hole through the pan and tack weld a nut onto a backing plate to accomodate the "eye" bolt to which the lap belt would be fastened.
Posted: Thu Aug 14, 2008 9:59 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
frankobrad wrote: |
Thanks |
The shoulder harness (if you opted for one) would be mouned were the to of the rear interior panel met the bottom of the rear quarter window. Here, you can see a large plastic plug on my '63.
OHHHHHHH, I thought it was higher up the pillar, I had not even looked in that area. I though the seat belt mouting hold was way up the B-Pillar because of photos I have seen but that must have been Beetles with High backed seats. Thanks very much. I would have never even considered the mounting hole to be that low. |
Posted: Thu Aug 14, 2008 10:02 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
frankobrad wrote: |
The shoulder mount was higher starting in '65. If you look under the assist strap at the top of the B pillar in '65s, '66s, and '67s, you will find the shoulder harness mount (the plastic plug). however, unlike previous years, the lower lap mount was already factory installed in '67, but not prior
petrol punk Samba Member
Joined: August 21, 2007 Posts: 977 Location: Las Vegas, NV
Posted: Thu Aug 14, 2008 10:26 pm Post subject: Re: 1964 B-Pillar Seat Best mounting holes |
frankobrad wrote: |
Thanks |
Personally I would not bolt the seat belts into the floor pans. In later cars they were bolted into the bottom of the B pillar and the transmission tunnel. I suggest you weld up some reinforcement metal in those areas and bolt the seat belts in there. Someone added lap belts onto my '56 that bolted to the floor pans, not a great idea. The bolts caught on something and tweaked the pans, and thanks to rust I could rip my seat belts right out of the floor, and I ain't even a big guy. _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Fri Aug 15, 2008 12:07 pm Post subject: |
My 66 had factory seatbelt mounts in the original floorpans, in my 67 they had been moved to the lower B pillar. In one of my owner's manuals for 66 they show a picture of a shoulder belt that has no lap belt. I think VW's early attempts for seat belt provisions weren't always the safest and not real well thought out. |
Atlantic Samba Member
Joined: July 24, 2008 Posts: 704 Location: Kalifornien
Posted: Fri Aug 15, 2008 12:11 pm Post subject: |
.. my 63 ragtop came with it and it looks original (the mounting screws). _________________ _______________________
"If we believe absurdities, we shall commit atrocities." [Voltaire] |
Posted: Fri Aug 15, 2008 12:15 pm Post subject: |
In my old 63 in order to use the bolts that came with seatbelts and actually fit through the holes in the seatbelts I had to buy some screw in adapters since the holes in the floorpan, tunnel, and body were too large. I think I bought them from Wolfsburg West or someone like that. |
