TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Thu Jul 11, 2002 2:22 pm Post subject: Whats the correct stock tire size? |
I need tires for my 74 thing with the factory steel wheels and have no idea what size tire to put on it. Anyone know? |
58Type2 Samba Member
Joined: June 15, 2002 Posts: 636 Location: Hell's Soup Kitchen
Posted: Thu Jul 11, 2002 2:27 pm Post subject: Whats the correct stock tire size? |
I may be wrong here, but as far as I knew...unless these are 14 inch rims, that the tires would be 165R15...I think that is right. I think that is almost every VW I know for stock tire size.
Jax |
TimGud Samba Member
They are 14" wheels like the later(68-70) bus. |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Thu Jul 11, 2002 6:36 pm Post subject: Whats the correct stock tire size? |
correct size is 185/14 |
Posted: Thu Jul 11, 2002 10:02 pm Post subject: Whats the correct stock tire size? |
The original tires were Metzler Monza in 185-14 |
TimGud Samba Member
Posted: Fri Jul 12, 2002 8:29 am Post subject: Whats the correct stock tire size? |
Thanks! |
Posted: Sat Jul 13, 2002 3:02 am Post subject: Whats the correct stock tire size? |
oops, new. |
Posted: Sat Jul 13, 2002 3:16 am Post subject: Whats the correct stock tire size? |
Sorry, now I know something knew. Thank you for informing me here as well. |
lastsafari Samba Member
Posted: Thu Feb 27, 2003 8:31 pm Post subject: Whats the correct stock tire size? |
most original tires were 185 14 m/s BF Goodridge. |
edgy Samba Member
Joined: January 22, 2003 Posts: 424 Location: Bel Air, Maryland
Posted: Fri Feb 28, 2003 7:15 pm Post subject: Whats the correct stock tire size? |
We run 185x65R14 Uniroyal. See a trend here? |
Joined: August 07, 2002 Posts: 53 Location: Houston, Texas
Posted: Fri Feb 28, 2003 8:17 pm Post subject: Whats the correct stock tire size? |
the first tires were Metzlers, then Continentals later in production became standard. All were 185 SR 14 M+S
I even think they has studded snow tires without the studs installed in some markets. |
Posted: Mon Mar 03, 2003 8:26 am Post subject: Whats the correct stock tire size? |
The 14 INCH wheels from 73-83 are NOT bus wheels, but 181 specific. Bus wheels will rub on the front upper control arm from incorrect offset. |
TimGud Samba Member
Posted: Mon Mar 03, 2003 9:10 am Post subject: Whats the correct stock tire size? |
Thanks for trying to let me know that. I should have made it clearer that they are "like" the bus wheel but not the same. I went to great lenghts to come up with the correct wheels from a good man in Canada.The way to tell if they are thing or bus easily is the bus has slots where the center part of the wheel meets the rim and the thing does not. Of course the offset is didderent as well. |
ChrisM181 Samba Member
Posted: Mon Mar 03, 2003 10:56 am Post subject: Whats the correct stock tire size? |
Kubelken, so when I go to get some centerline wheels, Douglas wheels or some other kind of 15 inch offroad wheel what offset do I need to get???
And does the offset only really matter in the front because of the upper control arm rubbing? |
