Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Posted: Wed Sep 05, 2007 10:58 pm Post subject: I need help finding some parts for my '66...Are they NLA? |
I need the following parts for my '66, but I haven't been able to find them yet. The guy at the vw shop where I have been buying parts said that he has no idea where I would be able to find these items...
1. Vent Hose? I guess that is what it is anyway...
2. Rubber grommet for where the hose passes through the engine tin.
3. Rubber grommet for where the air hose attaches to the heaterboxes...
4. 6V Electromagnetic choke element.
Thanks for the help... _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
1978 Westfalia Camper
Transmissions For Dummies |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Wed Sep 05, 2007 11:06 pm Post subject: |
Wolfsburg West has all four of those. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
FireBug1966 Samba Member
Posted: Wed Sep 05, 2007 11:58 pm Post subject: |
might also try bughaus.com and aircooled.net
all of those parts should be readily available from numerous vendors |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Thu Sep 06, 2007 12:49 am Post subject: |
1 and 2: That's called 25mm (or 26mm) pre-heat hose. Do you have the fitting it attaches to, underneath the tin, by the way?
Or is it just "floating" there not attached to anything?
Hose:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211255359
Other companies have them too, I'd get the 3-ply style like you have now, not the solid aluminum style
that it appears that CIP1 sells:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16%2D211%2D255
Rubber Grommet:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113119585A
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D119%2D571
WW even sells the spring clip for up top:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113255737
3. Air hose grommet:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113119571
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16%2D111%2D586
4. 6V Choke Element. Now, what you have is a PICT-1 style top half of your carburetor.
Wolfsburg West does NOT have that style of choke in 6V. They only have the early, smaller choke
in 6V,and that one won't fit your carb. You can try the Classified ads here on theSamba,
(they come and go on there, I'm sure there are plenty of good used ones around,
I probably have one somewhere or other myself) For new, CIP1 does have them, but I don't know
if the quality is any good, they have the KAFER brand name on them, which I think is made in China.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D129%2D191%2DH
Those sure are some tiny little numbers you used to label your picture!
I almost didn't even see the numbers!
(I always use nice large friendly road-sign typefaces myself)
Hope that helps some
-Andy |
Posted: Thu Sep 06, 2007 11:55 am Post subject: |
Thanks for the help guys, especially to Andy for providing the links to the parts and saving me from having to try to find them on the web sites. There was no fitting on the bottom of the pre heat hose, have you got a picture of it or can you describe it to me and tell me what it does exactly?
EDIT* Never mind about the pre heat hose...I searched for it and I know where it hooks up now... _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Thu Sep 06, 2007 12:49 pm Post subject: |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Tue Aug 26, 2008 9:13 am Post subject: |
Digging up an old thread.
Where the pre-heat hose hooks up in this pic, I just have a hole in the cylinder tin, what is that piece that the hose hooks up to? Is it available?
Thanks! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Posted: Tue Aug 26, 2008 9:36 am Post subject: |
Only used, look in the Classifeds or post a WTB ad there. |
BWD Samba Mailman
Posted: Tue Aug 26, 2008 9:41 am Post subject: |
glutamodo wrote: |
Thanks Andy, um... does it have a name?? _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Tue Aug 26, 2008 9:46 am Post subject: |
Ah... preheat elbow, or preheat pipe I guess. Only fits like mid 1963-1967 models there on the left side. |
BWD Samba Mailman
Posted: Tue Aug 26, 2008 9:47 am Post subject: |
glutamodo wrote: |
OK, thanks! _________________ BWD
JHC
member #2850
1966 Beetle
