RATTRP Samba Member
Joined: October 16, 2006 Posts: 53 Location: Haslet, TX
Posted: Fri Sep 12, 2008 10:56 am Post subject: Seat Removal??? |
Alright folks...
I have been working out in the garage in hotter than he!! temps trying to get my passenger seat out of my 69' SQB! With no luck, I am turning to all of the gurus here at The Samba. The rail closest to the transmission tunnel look fine and are not rusted at all, however the rail facing the passenger door is all rusted and will not slide! To boot, the lever to slide the seat back/forth has busted loose from the other side. Thus, I am having to hold it manually from under the seat while trying to slide/beat it with a rubber mallet.
Does anyone have any tricks to getting the seat out? Secondly... does the seat come out by sliding all the way back towards the back seat or the opposite? This has been a real nightmare to say the very least! All I wanted to do was remove the seats so I can do the low back conversion on these 69' highback seats. Any tips/tricks on doing this is much appreciated as well! Thanks to all - RATTRP _________________ You laugh cause I'm different...
I laugh cause I just farted!!!
69/67 SQB's... That's all I got. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Sep 12, 2008 11:01 am Post subject: Re: Seat Removal??? |
RATTRP wrote: |
Alright folks...
Does anyone have any tricks to getting the seat out? Secondly... does the seat come out by sliding all the way back towards the back seat or the opposite? This has been a real nightmare to say the very least! All I wanted to do was remove the seats so I can do the low back conversion on these 69' highback seats. Any tips/tricks on doing this is much appreciated as well! Thanks to all - RATTRP |
http://www.thesamba.com/vw/forum/viewtopic.php?t=318100 _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
RATTRP Samba Member
Posted: Fri Sep 12, 2008 11:08 am Post subject: |
Thank you very much... I think I looked through every friggin thread except for this one! I will give this a try and see what happens. Much Thanks!!! _________________ You laugh cause I'm different...
