linearone Samba Member
Joined: April 21, 2008 Posts: 158 Location: Wappingers Falls, NY
Posted: Fri Sep 19, 2008 4:43 am Post subject: Best Porsche engine swap for type I |
What is the best Porsche engine to swap into a VW beetle in terms of ease of swap? I was told the 80 HP vw914 engine drops right into place, no mods necessary, would a 911 engine fall into place without brain surgery?
I feel like if I were to buy another bug just to have a hot rod (I might) I wouldn't try to hot rod a 1600 block , rather Id swap an engine designed to do this from the factory.
Id love to just drop in a complete porsche engine.. what should I use? |
scott s Samba Member
Joined: January 04, 2005 Posts: 1122 Location: Rock Hell, SC
Posted: Fri Sep 19, 2008 5:01 am Post subject: |
Do a search for TIV into T1. Or Type Four into Type one.
It's not a "drop-in" procedure.
Also, check out Jake Raby's stuff...he's the TIV guru around these parts. _________________ Nothing screams "poor workmanship" like wrinkles in the duct tape. |
Mark33563 Samba Member
Joined: November 13, 2005 Posts: 1667 Location: Tampa Bay. FL
Posted: Fri Sep 19, 2008 5:35 am Post subject: Re: Best Porsche engine swap for type I |
[quote="linearone"]...I was told the 80 HP vw914 engine drops right into place, no mods necessary...quote]
If it were that easy EVERYBODY (exept the purists) would be running T-IV gear.
Completely different cooling gear. Yes, it will bolt up to the tranny, the ease of install stops about there. In its stock form (with cooling, etc.) it will not fit in the engine compartment. It will work in a baja but you will need a special flywheel (kennedy comes to mind) and a rear engine support for starters.... _________________ -—--------—-------
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24 |
whutdidyousay Samba Member
Joined: May 11, 2006 Posts: 1621 Location: Forest Grove, OR
Posted: Fri Sep 19, 2008 5:40 am Post subject: |
Just start with one of the special new cases on the market and add a nice turbo.... That'll get your hair standing on end.... Keep it a VW an you don't have to pay Porsche prices for parts and you get more power. _________________ '68 bug (Sadie)
danke meine Freunde
I'm tryin to build a dream one piece at a time, just bear with me. |
Randy in Maine Samba Member
Posted: Fri Sep 19, 2008 10:15 am Post subject: Re: Best Porsche engine swap for type I |
linearone wrote: |
Actually the best "Porsche" engine to use is a modified type 4 bus engine. Many have been done very well.
At least buy the video to see what is involved.
http://www.aircooledtechnology.com/store/product.php?productid=16466&cat=317&page=1 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Fri Sep 19, 2008 10:18 am Post subject: Re: Best Porsche engine swap for type I |
linearone wrote: |
Use a performance Type 1. Unless you already have the "Porsche" engine for free it's cheaper to stay with a VW engine. _________________ Glenn
Member #1009
#BlueSquare |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Fri Sep 19, 2008 10:22 am Post subject: Re: Best Porsche engine swap for type I |
Glenn wrote: |
linearone wrote: |
Use a performance Type 1. Unless you already have the "Porsche" engine for free it's cheaper to stay with a VW engine. |
and more reliable, and cheaper to fix when it brakes and parts are more readily available |
westcoast-paul Samba Member
Joined: January 31, 2006 Posts: 822 Location: CanadaYaHoser
Posted: Fri Sep 19, 2008 1:44 pm Post subject: |
has anyone ever squeezed a 911 engine in a type I ? i can almost get a fairly complete 911 motor from a budy's buddy.. just a thought |
69 bugin Samba Member
Joined: September 01, 2008 Posts: 332 Location: electra,texas
Posted: Fri Sep 19, 2008 4:16 pm Post subject: |
the older type 4 engine in the 1960-69 porshe is allmost a drop in
but you would have to buy a up right kit and do some mods to the engine
bay of your bug it has been done with the 911 conversion but looks stuppid to me i just would stick with your type 1 and build it bigger |
Posted: Fri Sep 19, 2008 4:23 pm Post subject: |
Besides, you don't want to be one of those guys (or gals) to say "I've got a porsche engine in my bug". ... We've heard about those...lol _________________ '68 bug (Sadie)
danke meine Freunde
Posted: Fri Sep 19, 2008 5:12 pm Post subject: |
Serious money any time that you have to do anything to a 911 engine.
A well built type 4 or a well built type 1 engine would give you significant kick in a beetle.
Performance does indeed cost money. How much you got? |
Glenn Mr. 010
Posted: Fri Sep 19, 2008 5:13 pm Post subject: |
linearone wrote: |
911 is a 6 cylinder and quite a bit longer and heavier.
Not a good option. _________________ Glenn
Member #1009
#BlueSquare |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Sep 19, 2008 5:45 pm Post subject: |
Here is a 911 in a Type 3. T-3 has a much bigger engine compartment, and they still had to do a lot of cutting.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
73BuzzBomb Samba Member
Joined: December 14, 2003 Posts: 895 Location: Baldwin/Smyrna, GA
Posted: Fri Sep 19, 2008 7:31 pm Post subject: |
69 bugin wrote: |
bay of your bug |
_________________ '73 Super
2270 type IV |
Glenn Mr. 010
Posted: Fri Sep 19, 2008 7:33 pm Post subject: |
69 bugin wrote: |
the older type 4 engine in the 1960-69 porshe is allmost a drop in |
You mean the 356/912 engine. The Type 4 wasn't put in a Porsche until late 1969 when they debut the 914. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Sep 20, 2008 5:09 am Post subject: |
If I recall correctly, the 912 basically used the Porsche 356 Super 90 engine until 912 production was discontinued in 1969.
When the 912e was built in 1976, it did use the basic type 4 2.0 engine that was being used in the 914-4 at the time.
It was a nice car and they actually made a fair number of them. |
Glenn Mr. 010
Posted: Sat Sep 20, 2008 5:11 am Post subject: |
The 912E (aka 923) was a stop gap so that Porsche had a low cost model after they stopped the 914 and before the 924 was ready.
Do some work the the engine and it was faster than the 911 of the same year. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Sep 20, 2008 7:27 am Post subject: |
linearone wrote: |
If you are hell bent on sticking a porsche engine in the car, get the tranny along with it and graft in the whole assembly. No need to worry about flywheels and clutch compatibility.
I am trying to convince my father to let me stick this 914 gear (tranny and engine) into a '69 ghia vert he has parked in his barn. Would suprice the crap out of robert-ricer burner on the street If not, I'll see about scoring a ghia sedan for the project... _________________ -—--------—-------
Posted: Sat Sep 20, 2008 9:30 am Post subject: |
69 bugin wrote: |
They didn't start making the T-4 style engine until 1969. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
