squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3690 Location: San Jose, CA
Posted: Tue Oct 07, 2008 7:20 pm Post subject: I know you have them...release them into the wild!!! |
So, I'm looking for some front 5 lug drums for my '65 squareback. i want some 5 lug BRMS but my fronts are 4-lug. any adapters? i've seen 4-lug to 5-lug adapters but i'm pretty much retarded when i think any further than that. yes, i know how hard 5 lug drums are to find. i also know how much meat needs to be left on... if you have some, let me know. if not, comment anyway. give me some free advice. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Oct 07, 2008 7:22 pm Post subject: |
I have the drums, and I have the backing plates, but I do not have the drum brake spindles. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Tue Oct 07, 2008 9:28 pm Post subject: |
do i need specific spindles for these drums? what will work? condition of your drums? 'nuff room for the lathe? price? my zip code is 92865 |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Wed Oct 08, 2008 9:57 am Post subject: |
Adapters will push the wheels out and if you're lowered you'll have rubbing issues. The offset on the BRMs is not the best for T3 installs and the adapters would make it worse. _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Posted: Wed Oct 08, 2008 2:55 pm Post subject: |
i c... |
lowindO Samba Member
Posted: Wed Oct 08, 2008 3:33 pm Post subject: |
you sound rich just go ahead and get some wide 5 discs up front. or hell all the way around. _________________ Why don't you have a narrowed beam yet?
My Squareback's Video |
Posted: Wed Oct 08, 2008 3:55 pm Post subject: |
that's actually not a bad idea...ya see, told you guys i'm retarded when i start thinking to much...or retarded when i don't think enough. good place to get those wide five discs? |
Posted: Wed Oct 08, 2008 4:01 pm Post subject: |
anyone have any problems with wide 5 discs? sounds pretty smart to me, but then again... |
Posted: Wed Oct 08, 2008 4:13 pm Post subject: |
cheapest is probably latest rage. check out their ones that say NO ADDED clearance. ads can be seen in any hot vws magazine. _________________ Why don't you have a narrowed beam yet?
Posted: Wed Oct 08, 2008 4:31 pm Post subject: |
thanks a lot! |
Posted: Wed Oct 08, 2008 4:35 pm Post subject: |
69SquareGuy wrote: |
thanks a lot! |
are you gonna lower it? you should go ahead and invest in a kcw type 1 style beam and dropped spindles before you buy the wide 5 discs.
it doesn't say specifically for type 3 spindles but some deeper digging would probably find out which bearings to get to make them work.
i know right now i am using type 1 link pin dropped spindles and stock type 3 discs. _________________ Why don't you have a narrowed beam yet?
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Wed Oct 08, 2008 4:50 pm Post subject: |
doesn't airkewld make a t3 disk kit?
I know not everyone likes them (the guys at airkewld) but they've got good stuff if you've got the money... _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
EdW Samba Member
Joined: January 13, 2005 Posts: 2385 Location: Unemployment Office
Posted: Wed Oct 08, 2008 5:03 pm Post subject: |
lowindO wrote: |
thanks a lot! |
i know right now i am using type 1 link pin dropped spindles and stock type 3 discs. |
I'm new to T3's and have a question to add here. If you go with the type 1 style beam, will you lose the luxury of the type 3 suspension? I'm just dying to slam my notch and if I can get away with slapping on type 1 beam and not lose driveability, I'll be all over it. _________________ 20‰
Quote: |
I would call him a dick, but a dick has a head on it |
Posted: Wed Oct 08, 2008 5:35 pm Post subject: |
EdW wrote: |
I'm new to T3's and have a question to add here. If you go with the type 1 style beam, will you lose the luxury of the type 3 suspension? I'm just dying to slam my notch and if I can get away with slapping on type 1 beam and not lose driveability, I'll be all over it. |
Ed, KCW makes/sells a T1 beam that is supposed to be able to go into a T3. Honestly, I don't know what's involved but have read in past threads that A)some modification is needed B)no mods are needed.
Something about cutting the frame horns to mount it. If you do a search it's been covered and some guys have made their own so I'm sure someone will chime in that's actually made the swap. There is some debate as to why one would want to do it, the T3 beam is superior to the T1 etc...but to each his own. _________________ One man's "patina" is another man's cancer...
Posted: Wed Oct 08, 2008 5:37 pm Post subject: |
This would be the cheapest, easiest way to mount BRMs on a four lug car.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6629 _________________ One man's "patina" is another man's cancer...
Posted: Wed Oct 08, 2008 6:30 pm Post subject: |
man those 4 lug BRM replica's are fugly. |
taydog Samba Member
Joined: January 16, 2008 Posts: 83 Location: Eugene, OR
Posted: Wed Oct 08, 2008 7:28 pm Post subject: |
I think they look pretty good, although with so much space in between the spokes you'd see a lot of brake.
Cheaper than the 5-bolts too! Although narrower.... |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Oct 08, 2008 7:37 pm Post subject: |
EdW wrote: |
lowindO wrote: |
thanks a lot! |
Go for the dropped spindles from BerT3 instead. You'll thank yourself after every drive. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Posted: Thu Oct 09, 2008 3:36 pm Post subject: |
EdW wrote: |
lowindO wrote: |
thanks a lot! |
the difference is minimal. its like the difference between a stock type 3 and a slightly lowered type 3. You feel it if your looking to feel it. But you gotta go with the dropped spindles. _________________ Why don't you have a narrowed beam yet?
