hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Mon Oct 20, 2008 5:31 pm Post subject: Master or Servo or ? |
Hi Guys
All of a sudden this started to happen,I put my brakes on and my pedal sticks down. I have to lift back up with my foot , it doesn't happen all the time. It will really brake hard. Is it my master or servo or something else. By the way it is a 72.
Thank you
Karl |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Oct 20, 2008 5:48 pm Post subject: |
Your servo is hurting, I'd search for you but I'm too busy right now, try keywords like "servo AND itself" or "booster AND itself". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Desertbusman Samba Member
Posted: Tue Oct 21, 2008 2:56 am Post subject: |
Sounds like it could be a bad pedal return spring. _________________ 71 Superbug
71 Westy |
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Tue Oct 21, 2008 9:20 pm Post subject: |
i fought this problem on my '77. I believe the seals in the servo are going dry.
my temp fix was to carefully pry back the accordian tube from the servo towards the front, and spraying some lube around the piston that enters the servo. Putting accordian tube back in place.
it works for a bit better, but eventually you'll want to have your servo rebuilt by Ron the rebuilder in Texas.
H & R Auto Parts Rebuilders
10328 Oakwood Dr, Dallas, TX 75217
Phone: (972) 286-5516
good luck
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
