Bay Window Steve Samba Member
Joined: July 13, 2006 Posts: 280 Location: Van Alstyne, Texas
Posted: Thu Aug 07, 2008 7:05 am Post subject: Body metal question (w/pics) |
Okay, I searched for this, but I'm wearing my flame suit just in case. Where can I find replacement metal for the rear bumper bracket area (where the bumper actually mounts) and the area behind the drivers wheel? (Pictured) I can't seem to locate them anywhere, and I don't have a parts bus to cut up.
That part is bad, as its now rusted into the passenger area.
_________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Thu Aug 07, 2008 7:43 am Post subject: |
CIP has those pieces:
http://www2.cip1.com/ProductDetails.asp?ProductCode=TAB%2D402%2D101
If the area (frame) where the bumper mounts is rusted, just weld in metal of the same thickness.
For areas you can't find after market replacement pieces, just use 18-20 gauge sheet metal, it's what I did on my friends bus:
http://intervest.ca/vdub/waynes_bus.html _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
rcnotes Samba Member
Joined: July 09, 2005 Posts: 641 Location: Ann Arbor, MI
Posted: Thu Aug 07, 2008 7:44 am Post subject: |
If other parts of that bus are as badly corroded as the area you show in the pics, you might consider finding a bus with less rust and making the one in your pics the parts bus. Sometimes things are too far gone.
Rust repair in that area is very difficult. If you don't have the skills and the tools to make that kind of repair, it will be very difficult and expensive to do it right. I suspect the only parts you'll find would be from a donor bus.
If the rest of the bus is good, safe and drives well, it might be better to drive it until it drops instead of throwing good money after bad. |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Thu Aug 07, 2008 8:55 am Post subject: |
I have a '72 parts bus with excellent rear corners, and the rear bumper bolts came out without any problems. Pretty dry bus really, how much rear frame area do you need? _________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Deuxdiesel Samba Member
Joined: July 31, 2006 Posts: 32 Location: Whitmore Lake MI
Posted: Thu Aug 07, 2008 10:36 am Post subject: |
I just had a bunch of metal work done to my Bus using Klokkerholm (sp?) metal from OEVeeDub. The parts looked good coming out of the box, but they are just nowhere near the fit that original sheet metal offers. If you can find donor metal, even if it needs a little help, it will fit much better and not be so cobbled together. |
mango.split Samba Member
Posted: Thu Aug 07, 2008 10:23 pm Post subject: Re: Body metal question (w/pics) |
Bay Window Steve wrote: |
You can cut and splice metal in there that you buy at the hardware store... Why do you need metal from a bus?? It is not like you are replacing a nose, corner, or any other painted body panels. |
Posted: Fri Aug 08, 2008 7:21 pm Post subject: |
Okay, I'll try to answer all the questions. No, the rest of the bus is not cruddy like that. That is the only rusty spot I can find with any rust through. That link for CIP1 is only up to 72. This bus is newer than that. I only need a small area where the bumper mounts. I thought it would be hard to repair, so I guess I need to patch it.
Dammit. _________________ '73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
grandfatherjim Samba Member
Joined: April 23, 2007 Posts: 172 Location: near Ottawa, Canada
Posted: Wed Oct 29, 2008 8:53 pm Post subject: Gauge of frame - '72 |
56ovalbug wrote: |
I need to fabricate new rear sections of frame in the area where the bumper brackets mount i.e. the area with the nuts inside the frame.
Anyone know what gauge metal the frame was? I would like to start making the new sections before hacking out the old, so it's not easy to get a caliper in to check.
Thanks,
Jim |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Thu Oct 30, 2008 7:09 am Post subject: |
my best guess would be 14, but mine isrotted its hard to tell. more than 10, less than 16 _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Posted: Thu Oct 30, 2008 7:20 am Post subject: |
Thanks; I have some 14 around (and some 10) so I'm in the ballpark.
Jim |
