bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Mon Nov 03, 2008 11:34 pm Post subject: Fabricating `62-`63 Westfalia Formica door panels |
This one is for the hardcore westy nuts out there. I am missing the formica door panels from my `62 so-33. These were found on
so-33,34,35s in the `62-`63 era.
These are a fake birch wood grain formica panel cut for the cargo and some front doors. Here is a picture of a set of originals.
I have found a nice match formica but curious if anyone has made door panels out of this and what methods they have used if so? I have seen it installed on cabinets but this is a far different thing.
The Formica is about 1mm thick and the og formica ply panels are 2mm. I was pondering installing the laminate onto 1/8 birch panels but they would be too thick. Same with using the laminate alone...too thin.
I thought about doubling the formica sheets and glue them together.
If I did this it would be dead on for the og thickness.
The thing is I have never worked with formica laminates. How easy does this stuff cut, saw etc? Any experts out there care to comment on my doubling the laminate up idea?
T _________________ Samba Member #95
sled Samba Member
Posted: Mon Nov 03, 2008 11:44 pm Post subject: |
I know it may not be cost effective, but if the formica is 1/16 and you need 1/8, could you just glue two layers together?
formica can be tough to cut and machine because it is often brittle. use sharp tools. _________________ drive your split. |
Posted: Tue Nov 04, 2008 12:01 am Post subject: |
sled wrote: |
formica can be tough to cut and machine because it is often brittle. use sharp tools. |
That is exactly what I was wondering? Any formica experts out there care to chime in? _________________ Samba Member #95 |
Jeff Power Samba Member
Joined: October 13, 2004 Posts: 1170 Location: with any luck, in my garage building bass guitars.
Posted: Tue Nov 04, 2008 5:58 am Post subject: |
Formica also comes in thinner dimensions, ask your supplier it may even come thicker.
If your wanting to glue 2 pieces together glue them back to back with a quality contact adhesive, solvent based. The other stuff is cleaner and easier to work with but won't last.
To cut to size I would rough cut the pieces with a pair of sheet metal scissors, then glue them together and then use a template and a router bit to trim to the exact size.
If you have a table saw you can cut it on that you just need to create or buy a zero clearance insert, and use a high tooth count blade. Also your gonna want to make sure the mica can't slip under the fence.
Hope this helps. _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
jerry wrote: |
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Tue Nov 04, 2008 6:48 am Post subject: |
wood template and router is the best way to cut the stuff! you have to cut the wood template a little maller than the finsihed piece to allow for the shoulder of the router bit. It will say on the package, usually 1/8". You get a router bit with a bearing on it for tracing/template work.
Good luck! |
Clara Samba Member
Posted: Tue Nov 04, 2008 6:59 am Post subject: |
It was also used on the board under the seats on some flipseats.
This is a '64 SO-35:
here are some cargo door panels pics
Back of a laminated panel. It looks like there are only two thin plies of wood, while the 1/8" plywood has three plies.
Yes you have to be careful and use sharp tools or you can chip it. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
travelvw Samba Member
Joined: February 15, 2004 Posts: 913 Location: Ozarks
Posted: Tue Nov 04, 2008 7:09 am Post subject: |
Bastardbus, where did you find the formica with the similar pattern. I was planning on using formica in my bus, too, but never imagined finding anything other than an off white. Thanks,
K _________________ 1963 SO-34 camper
1969 sunroof beetle
1963 Adam's parts gilla |
Posted: Tue Nov 04, 2008 8:28 am Post subject: |
There is a 1/32" Mica that you could glue to 1/8" ply or hardipanel.
Also here is the router bit I was talking about. No need to over or undersize your template.
http://www.grizzly.com/products/Flush-Trim-Bit-1-4-Shank-3-8-Dia-/C1079 _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
jerry wrote: |
Posted: Tue Nov 04, 2008 9:13 am Post subject: |
I found the match at the local plywood shop, it is made by Wilsonart and I have the number but not on hand right this second, I will post that later. In fact there was 3 companies that made almost dead on matches to the og. They were all basically Birch copies, which makes sense as the westys of that era had birch panels on the walls and ceiling.
I was checking last night and the og panel is SUPER thin. The og is way thinner then 1/8 inch so I think installing the formica on a 1/8 inch panel would make it way too thick. Glueing two pieces of formica samples I have together gives the exact thickness about 2mm. Now if they have this in bigger thickness it might be the darn correct size even.
Thanks for the added pics Greg, my so-34 is tucked in storage and I can barely open the doors too take pics.
Sounds like cutting this stuff cleanly is gonna be VERY tricky when it is so thin that is what I was worried about. _________________ Samba Member #95 |
Posted: Tue Nov 04, 2008 10:02 am Post subject: |
This stuff isn't that tricky to cut. Your local cabinet shop should be able to show you the tools and what not.
Remember to always practice on scrap first to get the feel. _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
jerry wrote: |
P-Dub Samba Member
Joined: October 17, 2002 Posts: 1064 Location: Oh, hi!
busdaddy Samba Member
Posted: Tue Nov 04, 2008 10:26 am Post subject: |
You can get birch plywood in 1.5mm (1/16"), try an aircraft supplier like Aircraft spruce and specialty. Not cheap but primo stuff and waterproof too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mark Henry Samba Member
Joined: November 24, 2005 Posts: 251 Location: Port Hope, ON, Canada
Posted: Tue Nov 04, 2008 10:40 am Post subject: |
There are two types of P-lam (plastic laminate its proper name, Formica is a trade/brand name) post form (PF) and and general purpose (GP). GP is the thicker of the 2, PF is the stuff you see on PF countertops with the rolled edge.
If you glue 2 pieces together, you better have any curve (form) right, as contact cement is very unforgiving, use a table saw to rough cut the P-lam and you would need a template and a trim router to do a nice job finishing it up _________________ '74 914, back on jackstands for a 3.0/6
'67 Bus 2007cc, Berg engine
'67 EMPI GTV bug w/ 102mm Nickies, massIVe bottom end, SDS FI, 2.6L T4 monster in the works |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Nov 04, 2008 11:07 am Post subject: |
What I would do is make a template of heavy paper, then transfer those measurements to a piece of MDF which you will need for the router's guide bit to ride on.
I have the correct bit that I would be happy to loan you for the cost of postage. No sense in buying it unless you're going to use it again.
Shears will work to cut it but it could crack. I think you'd be happier scribing it, as you will be able to get very close to the finished size. You do not want to be oversize by more than a third the diameter of the router bit. A scribe is cheap, too. They sell them at home depot. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Nov 04, 2008 11:10 am Post subject: |
bastardbus wrote: |
Clara posted those while I was asleep in the bus. Flash! WTF!
Have you tried seeing if Getalit in Germany still has the stuff available?
Tlaama could use that stuff for his So-35, so if you find a nice match be certain to share the source with him. |
Posted: Tue Nov 04, 2008 6:13 pm Post subject: |
busdaddy wrote: |
You can get birch plywood in 1.5mm (1/16"), try an aircraft supplier like Aircraft spruce and specialty. Not cheap but primo stuff and waterproof too. |
Wow! That would be EXACTLY what is needed to make these correctly!
Thanks a bundle I will do some searching. Is there anyplace online that sells this stuff?
Also thanks for all the helpful info folks, the information has far surpassed what I thought I would get. This is REALLY what the samba forums and bus community should be all about!
I am going to get the number for the Wilsonart match I found, but intersting what someone said about the gloss or textured finish. The piece I have is Matte finish and that does not look right. I figured the gloss would be dead on but guess I need to check that too.
I will update info I find!
Thanks!
Todd _________________ Samba Member #95 |
Posted: Wed Nov 05, 2008 6:38 am Post subject: |
^^^ Saved that link in my favorites! _________________ I build complete Westy Style camping interiors check them out here > www.rjcampers.com
jerry wrote: |
tlaama Samba Member
Joined: March 05, 2004 Posts: 289 Location: Sarasota ,Florida
Posted: Thu Nov 06, 2008 5:02 pm Post subject: |
Todd, good to see the so-33 coming along. I did a half hearted search for that formica match a while back and and found the pattern well enough but not the color so well. It seemed a good match would be out there somewhere.
I hope you found something nice as I will piggy back on your knowledge.
The first time I saw that stuff on an old junk so-33 cargo door I was convinced it was repro junk and about threw it away. Later I learned it was the real deal .
It is probably bread and butter to a cabinet man to cut. Tom |
Clara Samba Member
Posted: Wed Nov 12, 2008 3:00 pm Post subject: |
Found a pic of the laminate on the front doors:
pic by slowlow
by the gas guage and the headlight bucket I'd say this is a '62 or early '63.
I believe the wood grained laminate was used about 62 ish.
A number of original looking 61s have the real wood panels on the front doors.
A number of 64s have the beige vinyl over hardboard. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
