John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Fri Nov 07, 2008 5:02 am Post subject: |
so to complete the list a bit, here my datas:
- 36hp engine 1433ccm
- 78,5mm (third oversize) pistons kolbenschmidt/ machined
- 74mm porsche 356 crank
- 356 rods (poished, custom bushings for 20mm bolt)
- flywheel porsche 356 8 dowel 4,25kg after machining
- cam aircooled research stage II bolt on gear
- valfes 36/28mm
- carbs 34PCI dual (venturi 26mm, 138,5/180)
- manifolds riechert welded and ported
- heads 36hp, some porting and welding
- compressionratio 8,8:1
- spacers 11mm
- headvolume 39cc / ball shaped
- exhaust stock, TDE pipes
- ignition Bosch BR25
Datas:
- corrected din power engine 70PS (nearly same as HP), @ 4223
- 50ps on wheels
- torque 126Nm @3282 upm _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
J Samba Member
Joined: September 15, 2007 Posts: 126 Location: Sus&Wis-town,BelGIam
Posted: Sat Dec 06, 2008 11:12 am Post subject: |
1192cc (64x77) pepco supercharged (28 pci) comp: 6.6-1
Hp: 59,8 hp (rear wheels)
Torque: 93 nm |
TomSimon Samba Member
Posted: Thu Feb 25, 2010 10:56 am Post subject: |
Did any of you guys see the vintage film (converted to digital by Aussie Dubbers) of Dick Bieth back in 1961 at Bonneville with his 36hp powered Beetle LSR (complete with bicycle chain-driver Pepco roots blower on top)?
It's great classic stuff, email Burly for a digital copy... |
Posted: Thu Feb 25, 2010 11:26 am Post subject: |
TomSimon wrote: |
Hi Tom, Yes Burly has sent a copy and "wiggy" is converting it for inclusion in "The History of Vintage Speed" sticky here.
BTW if you want to add any of your experiences to the history topic...short and concise or long and rambling, you'd be most welcome. _________________ John.
Boonies Samba Member
Joined: November 30, 2005 Posts: 816 Location: Chicago
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
