Joined: March 18, 2002 Posts: 593 Location: Peterborough, Ontario, Canada
Posted: Sun Nov 30, 2008 7:05 pm Post subject: my 36hp new pic |
I have been messing around with my 36hp, doing mock up on dual carbs, made a cool tailpipe (for my bus) plug wire tube, manifolds, distributor clamp and some cool buggy exhaust velocity stacks... anyone have some old tin, and a pulley layin' around?
Any comments or tips or other cool, not overly hurtful comments welcome!
Don't mind the vise grips, studs are nuked! I will fix that soon, manifolds need "tweaking" anyway...
I don't know how to post the pic on here... I tried! Here's a link...
http://i456.photobucket.com/albums/qq286/vwlownslo/DSC04127.jpg
Last edited by [email protected] on Thu Jan 01, 2009 4:13 pm; edited 1 time in total |
fredy a Samba Member
Posted: Sun Nov 30, 2008 8:05 pm Post subject: |
_________________ sorry for the spelling |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Sun Nov 30, 2008 8:07 pm Post subject: Re: my 36hp |
[email protected] wrote: |
Any comments or tips or other cool, not overly hurtful comments welcome! |
Dump the OO9 and put in a VJ4BR25 or 0 231 129 010 distributor. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Nov 30, 2008 8:46 pm Post subject: Re: my 36hp |
Glenn wrote: |
Dump the OO9 and put in a VJ4BR25 or 0 231 129 010 distributor. |
O.k, I wasn't sure what I was looking for... Is that far better then the 009 or? I am fairly new to the 36hp world.
Thanks for posting the pic fredy a |
Glenn Mr. 010
Posted: Sun Nov 30, 2008 8:50 pm Post subject: |
Besides looking "period correct" they offer better performance over a OO9.
The VJ4BR8(019) were originally on 36hp Bus engines and and the VJR4BR25(010) were on Bastard 40hp Bus engines. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Nov 30, 2008 8:52 pm Post subject: |
yeah, as soon as I put it in I thought it didn't seem right... |
Glenn Mr. 010
Posted: Sun Nov 30, 2008 8:53 pm Post subject: |
Bosch 010 in a 40hp Bus with vintage dual carbs.
Member #1009
#BlueSquare |
Posted: Sun Nov 30, 2008 9:00 pm Post subject: |
Thanks Glenn |
Posted: Mon Dec 01, 2008 7:36 am Post subject: |
looks cool man
the manifolds home made?? _________________ sorry for the spelling |
Posted: Mon Dec 01, 2008 3:58 pm Post subject: |
fredy a wrote: |
looks cool man
the manifolds home made?? |
Yeah, I used the stock end castings for the base and the top flanges are made off of the og manifold center(s). I spanned the distance in between with a scrap bit of tube off of an old pipe clamp... To that I added a little heat and bend... They turned out great, but I still have to tweak them a bit more.
Anyone point me in the right direction as far as a camshaft?
I plan on doing some very mild port work to the otherwise stock heads and run stock displacement (for now) yet still want a bit more lump at idle...
I love thesamba!
Last edited by [email protected] on Mon Dec 01, 2008 7:13 pm; edited 1 time in total |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Dec 01, 2008 7:12 pm Post subject: |
Those intakes are l-o-o-o-n-g! Have you thought about shortening them to help the carbs against potential icing problems? _________________ www.zwerks.ca |
Posted: Mon Dec 01, 2008 8:05 pm Post subject: |
The manifolds are 12 1/4" tall from head to top of carb. not stacks but carb. So maybe they are a bit tall... but they can't be to much taller then an okrassa manifold, can they? |
Posted: Mon Dec 01, 2008 8:14 pm Post subject: |
The top of the carb, is near the same height as the top of the genorator backing plate on my engine. It appears to be fairly close height wise to the beaty in this pic... Is icing going to be a concern?
Mark Samba Member
Posted: Mon Dec 01, 2008 8:24 pm Post subject: |
Not sure, I wish I had a set of Okrasas in my hands to confirm this!
Either way, ambitious project you have there. Something similar to what I want to do when I have more time in the shop. _________________ www.zwerks.ca |
Freeform Metal Samba Member
Posted: Mon Dec 01, 2008 9:34 pm Post subject: |
It looks like the the Okrasa are 8.125". Bottom of flange to top of flange. I might be a hair off because it is hard to measure exactly w/ them installed. I hope this helps.
Rob |
Posted: Mon Dec 01, 2008 10:57 pm Post subject: |
Freeform Metal wrote: |
Rob |
With that being said, my measurement was 12 1/4" including a 28 pict, so providing a 28pict is approx. 4" tall, I am close.... |
Posted: Tue Dec 02, 2008 6:30 am Post subject: |
this is my first test need some work stiil.
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Tue Dec 02, 2008 11:22 am Post subject: |
the length is a good thing,you get more of a ram effect,but you should fab some preheater tubes and a balancing tube between the 2 intakes,have fun _________________ Have a great day! |
Posted: Tue Dec 02, 2008 12:00 pm Post subject: |
hugheseum wrote: |
the length is a good thing,you get more of a ram effect,but you should fab some preheater tubes and a balancing tube between the 2 intakes,have fun |
any ide on have to do the preheater ??
balangsing is no problem
thanks _________________ sorry for the spelling |
Posted: Tue Dec 02, 2008 2:58 pm Post subject: |
hugheseum wrote: |
I have balancing tubes on mine... they wrap around the back of the shroud. I will mock-up some preheater action tonight. As soon as I fix my intake studs, I want to start making the linkage...
Still gotta weld up my ex-towel bar bumper tailpipe... To bent to save IMO, so I recycled it!
Need a pulley, and some tin.... soon enough!
Thanks all! |
