tk76 Samba Member
Posted: Fri Dec 26, 2008 7:28 am Post subject: Broken Diff lock Knob |
Hi all, I managed to pull one of the diff lock knobs on my syncro a bit too hard and its come right off the lever, any ideas what i can do or from where i could get a spare one? thnx |
Mofus Samba Member
Joined: February 21, 2008 Posts: 369 Location: San Diego
Posted: Fri Dec 26, 2008 9:16 am Post subject: |
I got a replacement from the dealer this year. It was a bit pricey. Around $80 I think for the valve/switch. _________________ '87 Syncro passenger w/ 2.2L Subaru
'10 Passat Wagon (keeps Mrs. Mofus away from my van) |
Dogpilot Samba Member
Posted: Fri Dec 26, 2008 9:49 am Post subject: |
Did you kill the mechanism or just pull off the knob? If the knob is what died, then you essentially pulled the threads out of it. You can fill the hole with epoxy like JB Weld re-drill and tap it. OR you can do the cheap method, which does not always work, of putting a light film of oil on the threads, filling the hole with the epoxy and pushing the knob on and letting it set. In theory, the oil acts like a release agent, letting the knob unscrew. In practice it works to varying degrees. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
tk76 Samba Member
Posted: Fri Dec 26, 2008 1:21 pm Post subject: |
Thanks for the replies. Its just knob that came off... What do you mean re-drill and tap it? |
Posted: Fri Dec 26, 2008 3:14 pm Post subject: |
You essentially stripped out the threads in the knob. You can fill the hole with an epoxy like JB weld. Then dill out the appropriately sized hole with a drill that corresponds to a tap with the shaft's thread pattern. Tap the hole with the tap and it should work as before.
The really cheesy way to do it is put a matchstick in the hole, grab the shaft with a set of padded pliers to keep it from turning. Then try to screw the knob back on with the matchstick as a jam piece in the hole. This works by filling the hole with a soft wood and kind of jams the threads tighter.
Ok I am now fresh out of dumb ideas. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Mofus Samba Member
Posted: Fri Dec 26, 2008 3:22 pm Post subject: |
Sorry, I misunderstood . My whole shaft pulled out, so I needed a new one. _________________ '87 Syncro passenger w/ 2.2L Subaru
tk76 Samba Member
Posted: Fri Dec 26, 2008 6:05 pm Post subject: |
Dogpilot wrote: |
Ok I am now fresh out of dumb ideas. |
How do I know what corresponds to the shaft's thread pattern |
Posted: Fri Dec 26, 2008 8:15 pm Post subject: |
Most tap sets, I would assume this one is metric, have a thread gauge. You use the gauge to determine the thread for the tap you need.
Try the matchstick method first. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
tk76 Samba Member
Posted: Fri Dec 26, 2008 9:12 pm Post subject: |
Thanks Dog |
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1242 Location: Portland, Or
Posted: Sat Dec 27, 2008 2:12 am Post subject: |
find a bay window headlight switch knob, they're the same. all you need to do is take out the center of the headlight knob and replace it with the black center of your old knob.
The thread is the same, it will simply screw right on.
_________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
tk76 Samba Member
Posted: Sat Dec 27, 2008 5:22 am Post subject: |
Tristar Eric wrote: |
Hi Eric, thanks for the advice. I'm wondering though.. the thread in the center of my old knob has been damaged, will the bay switch screw on as it is without having to replace the center part? |
tk76 Samba Member
Posted: Thu Jan 15, 2009 12:18 am Post subject: |
Dogpilot wrote: |
Did you kill the mechanism or just pull off the knob? If the knob is what died, then you essentially pulled the threads out of it. You can fill the hole with epoxy like JB Weld re-drill and tap it. OR you can do the cheap method, which does not always work, of putting a light film of oil on the threads, filling the hole with the epoxy and pushing the knob on and letting it set. In theory, the oil acts like a release agent, letting the knob unscrew. In practice it works to varying degrees. |
I eventually tried the epoxy and drilling a hole back in - worked fine, as good as new! Thanks Dogpilot |
