Clarky Samba Member
Posted: Thu May 08, 2008 11:55 am Post subject: How to verify you have correct Oval front wings? |
Hi,
I have a pair of wings that came with my old '54 Oval but I stashed them in the loft of my garage until last week.
On closer inspection I think one may be an original wing, the other I think not.
How do I confirm for sure that they are/are not oval wings?
_________________ www.vwoval.co.uk |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Thu May 08, 2008 2:35 pm Post subject: |
Does it have the metal wire conduit for the headlight wires? |
Clarky Samba Member
Posted: Thu May 08, 2008 2:37 pm Post subject: |
They were still attached to the body rather than the wings hence it adds to my confusion. _________________ www.vwoval.co.uk |
cyberdyne systems 101 Sambanator
Joined: September 03, 2004 Posts: 415 Location: in my own little world
Posted: Fri May 09, 2008 2:24 am Post subject: |
look at the mounting area of the wings, it should have pressings between the bolt holes - that will confirm its genuine VW, but not correct age.
Next look at where the running board attaches, does it have a contoured area to match the shape of the running board, or does the wing just smoothly carry on down as normal?
Where the tube for the lights wiring joins the wing, you should see evidence that its been removed (these pieces should remain attached to the wing, being unbolted from the inner wing).
CS 101 _________________ When I think of something to say - I'll be the first to know
56' Oval
71' Westy |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Fri May 09, 2008 5:16 am Post subject: |
cyberdyne systems 101 wrote: |
CS 101 |
Only the rear fenders had the ribbing between the bolt holes IIRC. From his pics, I think he is talking about fronts. Were used up through '59. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Sunroof53 Samba Member
Posted: Fri May 09, 2008 9:23 am Post subject: |
The grey wing is a repro ,The brown wing is origianal us spec.Grey one is a good shape but does not curve over the wheel as much.
Headlamp bowl
repros have a distict crease in the shape and no conduit.
Very distinct curve here
This shows a right hand wing and the curve from the mounting face up to the headlamp bowl.Repros tend not to have this or curve is the other way.
Flange showing some press marks.Rears have a distict indent
curve over the wheel.
From the top.look how far the headlamp appears forward of the wing
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri May 09, 2008 1:33 pm Post subject: Re: How to verify you have correct Oval front wings? |
Clarky wrote: |
Hi,
Take a measurement across the widest part of the fender................if there is a difference...........one of them has been replaced. None of the reproduction fenders are an exact match for the OG one. A tape measure will point out the difference very easily. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Clarky Samba Member
Posted: Fri May 09, 2008 2:07 pm Post subject: |
Cheers guys,
Will measure tomorrow to get a better idea, I am thinking the lhs is an oval the rhs a repro. _________________ www.vwoval.co.uk |
Andrew oval Samba Member
Joined: February 06, 2008 Posts: 78 Location: Oxford, UK
Posted: Fri May 09, 2008 3:48 pm Post subject: |
Sinbad wrote: |
Headlamp bowl
I hope it's okay to jump in and ask a semi-related question...
Should the wiring tubes for the headlights butt against the headlamp bowls or should they go into the headlamp bowls? _________________ 1954 Deluxe oval 'Gertie' - barn stored for 20yrs, work in progress. |
Posted: Sat May 10, 2008 4:42 am Post subject: |
Personally i think there was a short piece tube welded to the bowl and the conduit is over the top of that .hard to say if it was welded or has just rusted in place.
Posted: Sat May 10, 2008 6:54 am Post subject: |
That looks original |
vwmadeinireland Samba Member
Joined: October 31, 2003 Posts: 44 Location: Cork, Ireland
Posted: Mon Jun 02, 2008 3:53 am Post subject: |
Don't want to hyjack the topic, but as many others I am in the same situation. I've been offered this set of front fenders, but am unsure whether they are correct for oval or not. Note that they are not US spec. As they are not cheap, I rather know in advance. Any help is very much appreciated.
Bruce Samba Member
Posted: Mon Jun 02, 2008 10:35 pm Post subject: |
The pics of the yellow wings do not show the details of an original oval wing. Pics showing the rear end where it meets the running boards, the flange by the headlight bucket, and the flange at the front bottom by the bumper mount will tell the story. _________________
66 dormi Samba Member
Joined: September 06, 2006 Posts: 607 Location: Ontario Canada
Posted: Fri Jan 09, 2009 9:39 pm Post subject: |
Also weight an original fender is a lot heavier _________________ DORMOBILE TOP WANTED!!!!
1978 westy daily driver
1960 panel camper project
Mini R53 bob the tomato |
fitz57 Samba Member
Joined: January 05, 2009 Posts: 22 Location: Houston Tx
Posted: Mon Jan 12, 2009 5:39 pm Post subject: |
an oval front fender has a place that sticks up where the running board meets the fender...i tried to find a pic hope you can tell by this
jooles Samba Member
Joined: August 29, 2008 Posts: 235 Location: Bulgaria / France
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Mon Aug 03, 2009 2:31 am Post subject: |
As far as I can see in these threads, my 56 oval have the same front fenders as until 11. august 59 ( 2 539 142).
And that make sense, since one of my fenders is from a 58, the other one is probably original. And they messure the same (34 cm, ref. the link above). The fenders fit the wheels perfectly.
Many people refer to oval fenders, but we have to be aware that it is early and late oval fenders (which includes late 50').
Or do some have other information?
Edit:
This link shows the difference :
http://forums.pre67vw.com/Default.aspx?g=posts&t=16493
Luckily my car have two correct oval fenders, even though one of them was taken from a 58. It is a different pressing betveen oval and big windows in the light bucket. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
valentinesr Samba Member
Joined: June 30, 2008 Posts: 749 Location: Ontario, California
Posted: Mon Aug 03, 2009 3:19 am Post subject: |
I had asked the same information and started a thread on fenders, cause I to wanted to know more about them.. Heres the link of that information that might help..
http://www.thesamba.com/vw/forum/viewtopic.php?t=307483&highlight=front+fender
Heres some pics to help some of the comments from above...
Drivers Side Front (some were saying to look at the pressed nut on the back, here are two different styles.
The flare where it meets the running board...All four fenders I have..
I do have an extra set off a 1953 I picked up last year..but I get home in December..and the drivers side has to get an OG sheet metal donor repair in the headlight bucket area..then off to the body shop for final TLC, then back on TheSamba for a fellow in need of a pair of OG front fenders.. _________________ Valentine, Ray J Sr.
Ontario, California
thebucket wrote: |
I gave my oval a nasty look. Money hungry bitch.... |
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Fri Nov 06, 2009 9:08 pm Post subject: |
Are 58 and 59 fenders the same as a 56/57 Fender up front with the exception of lack of bullet indicators? I found a set I think might be worth getting, and can add in the bullets and shave the top mount signals.
Are the rears the same? |
AlteWagen Troll
Posted: Fri Nov 06, 2009 10:56 pm Post subject: |
rears are the same from 56-60. Identified by pressings between bolt holes. |
