carat springs?
vw8716v
vw8716v is offline
PostPosted: Tue Jan 20, 2009 5:34 pm    Post subject: carat springs? Reply with quote
does anyone know the different lengths in springs for a vanagon/carat/westifalia
the reason is i have a set of springs i want to put on my westly but if they are the same ones i really dont want to pull them out and find that out. if i could just measure these before hand i verify which ones these are.
thanks
insyncro
Banned
insyncro is offline
PostPosted: Tue Jan 20, 2009 5:36 pm    Post subject: Reply with quote
The different size springs have different color paint marks on them so you can identify them.
vw8716v
vw8716v is offline
PostPosted: Tue Jan 20, 2009 8:23 pm    Post subject: Reply with quote
kind rusted so that wont help thanks
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Jan 20, 2009 11:44 pm    Post subject: Reply with quote
Carat springs are shorter than a Westfalia, have a different spring rate, along with a different part number.
Westy springs are longer and stiffer.
T.K.
vw8716v
vw8716v is offline
PostPosted: Wed Jan 21, 2009 4:54 am    Post subject: Reply with quote
i kinda new that already but i would like an actual measurementso im not doing a bunch of work just to compare the two and see they are the same. thanks
[email protected]
mdetro4660@aol.com is offline
PostPosted: Wed Jan 21, 2009 5:51 am    Post subject: Reply with quote
I still have my stock 88 westy set out in the shed, If there not too much stuff piled on top of them I'll pull them out and measure them later on when it warms up, unless somebody beats me to the punch.
That must be why my wife liked the van better before I lowered it Very Happy Of course I did make up for the length with some more Girth when I added the 9' wheels Wink
Markus
Terry Kay
Banned
PostPosted: Wed Jan 21, 2009 6:43 am    Post subject: Re: carat springs? Reply with quote
<<the reason is i have a set of springs i want to put on my westly but if they are the same ones i really dont want to pull them out and find that out.>>
OK---
They are not the same springs.
But you kinda knew that. (??)
T.K.
joetiger Premium Member
joetiger is offline
PostPosted: Wed Jan 21, 2009 8:15 am    Post subject: Reply with quote
Does anybody sell an OEM-type spring for Vanagons anymore? The only ones I've seen are Weitec & H&R (lowering) and syncro.org and GoWesty (lifting).
Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com
a914622
a914622 is offline
PostPosted: Wed Jan 21, 2009 9:25 am    Post subject: Reply with quote
The brickwerks has a set made by AVO. 30MM is the same as stock Carat springs.
The brickwerks does not send them over the pond BUT if you email them you will get a contact for AVO direct.
Jcl
PDXWesty
PDXWesty is offline
PostPosted: Wed Jan 21, 2009 10:18 am    Post subject: Reply with quote
Even though they're rusted, you may be able to find the paint marks if you take the springs out and clean them up. That's the only way I could find my marks. They're very hard to see. I have an 89 Westy that has brown springs in the front and bluse springs on the rear. That's consistant with the chart. Clean the springs well and you might find some paint marks. According to this chart, the front springs for Carat and Camper were the same. I don't know if you can tell much by measuring the length of the spring, they could have very different spring rates but be the same size. I know that the Syncro.Org springs are close to stock, based on the measurements from my van, and should level you out at 17" ride height.
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/springs.htm
According to the Brick Yard, the springs are as follows:
Front Springs:
Blue=Normal
Brown= Carat, Camper, Ambulance
Green=Increased payload
Yellow=30mm lower than normal
Violet=Syncro
The rear spring colors are as follows.
Yellow=Yellow - Normal and for increased payload or heavy duty shocks
Brown=Ambulance (UK)
Blue=Passenger vans
Green=30mm lower
2X green=Syncro
Here's a link to the Brickwerks springs.
http://www.brickwerks.co.uk/index.php?option=com_v...p;Itemid=6
Christopher Schimke
PostPosted: Wed Jan 21, 2009 11:16 am    Post subject: Reply with quote
Carat spring overall free length =
247mm - rear
310mm - front
Gauche1968
Gauche1968 is offline
PostPosted: Wed Jan 21, 2009 11:21 am    Post subject: Reply with quote
Van Cafe sells a set of stock height springs. Not OEM, but supposedly stock height, for mucho dinero. Shocked
1984 Vanagon GL
1984 Vanagon Westy
PDXWesty
PDXWesty is offline
PostPosted: Wed Jan 21, 2009 12:27 pm    Post subject: Reply with quote
Loogy,
Do you know the length of the Syncro springs? It's my understanding that they're actually shorter than 2wd springs. Is that true?
hiram6
hiram6 is offline
PostPosted: Wed Jan 21, 2009 2:49 pm    Post subject: Reply with quote
The spring color chart is a great tool, thanks for looking that up and posting it.
At the same time, how can my 85 Westy have the infamous nose-up attitude that 85 Westy's have if the spring length/rate are the same year-to-year??
It's not rear-end sag, either, it 's good old nose up in the air snooty 85 Westy attitude!!!
Shouldn't I have the same "blue stripe" springs as listed above, same as every other year??
(currently about 1/2 a country away from my van, or else I'd just go look)
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
vw8716v
vw8716v is offline
PostPosted: Wed Jan 21, 2009 3:50 pm    Post subject: Reply with quote
247mm - rear
310mm - front
finally this is what i was looking for. thanks.
as for the color chart thats great but it so happends that my springs are all black no strips that i can tell
PDXWesty
PDXWesty is offline
PostPosted: Wed Jan 21, 2009 4:04 pm    Post subject: Reply with quote
As said earlier, the color stripes are small and very hard to see. I was only able to find them after taking out the springs and cleaning them. Then they were barely visible.
vw8716v
vw8716v is offline
i measured mine and they are 235 rear and 275 front looks like maybe and aftermarket lowering set?
Christopher Schimke
PostPosted: Wed Jan 21, 2009 4:25 pm    Post subject: Reply with quote
If they are black, they are probably the CIP1 springs. Toss them in the trash if they are.
Christopher Schimke
PostPosted: Wed Jan 21, 2009 4:28 pm    Post subject: Reply with quote
PDXWesty wrote:
Loogy,
Yes, the Syncro front springs are shorter than their 2wd counterparts. By how much, I don't know exactly. Syncro rear springs are taller than 2wd rears.
vw8716v
vw8716v is offline
PostPosted: Wed Jan 21, 2009 4:33 pm    Post subject: Reply with quote
why? i got them with a set of bilisten shocks (slightly used)
they cant be that bad could they?
