BearBroth Samba Member
Joined: May 11, 2004 Posts: 142 Location: San Antonio TX. (just north of Hades)
Posted: Wed Jan 28, 2009 8:13 pm Post subject: Another Dizzy Question... |
I've been going through the piles of parts I've accumulated over the years and I came across a non-vac advance distributor with the numbers 013 on it. What's this for? I've searched and found nothing on it. Can someone help identify what it belongs to? Thanks in advance.
_________________ "It is possible to store the mind with a million facts and still be entirely uneducated."
- Alec Bourne |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Wed Jan 28, 2009 8:14 pm Post subject: Re: Another Dizzy Question... |
eviljedi25 wrote: |
I've searched and found nothing on it. |
Quote: |
Type 3 1966 * 1600
Distributor: VW 311-905-205F, Bosch 0231 137 013
Replacement: VW 311-905-205Q, Bosch 0231 137 033
Condensor: 02 007
Rotor: 04 006
Cap: 03 001
Coil: 00 001 (Blue Coil 00 016)
Vacuum Can: 07 016 (NLA)
Ignition Wires: 09 003
Spark Plug: W8AC
Timing Set At:: 10deg BTDC Static or @ 800-950rpm w/strobe w/vacuum hose disconnected and plugged
Advance/Retard Range: Unknown |
_________________ Glenn
Member #1009
#BlueSquare |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Jan 28, 2009 9:18 pm Post subject: |
While we have a photo of it, what is the purpoe of the plug on the bottom? The one with the three-sided clasp in the middle.
Posted: Thu Jan 29, 2009 1:50 am Post subject: |
Thanks alot Glenn! Can you "teach a man to fish" and tell me where to look up this info so I don't have to bug you guys if necessary? (I have a few more distributors I don't know the origin of)
Also, since it is not a vac advance dizzy, is this a good dizzy to run on a dual carbed (34ICT) mild motor? Thanks a lot. _________________ "It is possible to store the mind with a million facts and still be entirely uneducated."
- Alec Bourne |
Aaron M265 Samba Member
Joined: March 31, 2008 Posts: 656 Location: Adelaide, South Australia
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Thu Jan 29, 2009 6:08 am Post subject: |
I have always been under the "speculated" impression that those plugs that look like inverted snap rivets are vents to allow condensation and oil vapor to drain out. Ray |
Glenn Mr. 010
Posted: Thu Jan 29, 2009 6:34 am Post subject: |
eviljedi25 wrote: |
Thanks alot Glenn! Can you "teach a man to fish" and tell me where to look up this info so I don't have to bug you guys if necessary? |
http://www.oldvolkshome.com/ignition.htm
Aaron Britcher wrote: |
That distributor is actualy a vac advance type but the can is missing- see that rectangular slot- thats where the can goes. Not an uncommon distributor to get bits for still. |
Yes... the can is missing so the distributor is not usable.
raygreenwood wrote: |
Actually they are vents for ozone. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jan 29, 2009 7:06 am Post subject: |
Again, thanks for your help. You've been a great help. That link has everything I need. _________________ "It is possible to store the mind with a million facts and still be entirely uneducated."
- Alec Bourne |
Posted: Thu Jan 29, 2009 7:35 am Post subject: |
I knew they were vents.....logic should have told me it was for ozone. I learn something every day. Thank you Glenn! ray |
