Notch wheels
TimGud
TimGud is offline
PostPosted: Sat Jun 22, 2002 3:00 pm    Post subject: Notch wheels Reply with quote
Does anyone know which wheels go on a late 65 notch ? Ive seen early type 1 wheels and 66-67 slotted on them. I have both styles but need to know which to paint. Any help is appreciated. Tim.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sun Jun 23, 2002 9:17 am    Post subject: Notch wheels Reply with quote
Tim, maybe try the type 3 gallery area on this site and look for original pics or at the owners manuals and you can determine it that way? I'm with you I've seen both, I think for sure they were supposed to have the 4.5" most early bugs came with 4"....But being a 65 I would think they were solid...????
ibjack
ibjack is offline
PostPosted: Mon Jun 24, 2002 11:22 pm    Post subject: Notch wheels Reply with quote
Neither of those. The 64-65 type3 wheel is it's own thing. They're solid like the bugs but there are no hubcap clips. The bug ones will work though. jack
Paul Knight
Paul Knight is offline
PostPosted: Fri Jun 28, 2002 7:19 am    Post subject: Notch wheels Reply with quote
it had a wheel very similar to the 66/67 bug in hub cap fitting but visually more like an early bus wheel. unique offset, too.
wheel is solid looking with 4 long slots like the bus wheel and a flat, push-on hubcap
ibjack
ibjack is offline
PostPosted: Fri Jun 28, 2002 10:54 pm    Post subject: Notch wheels Reply with quote
Only the early '61-'63 had the slots with 5 lug. Again it's unique to the t3. J
TimGud
TimGud is offline
PostPosted: Sat Jun 29, 2002 9:31 am    Post subject: Notch wheels Reply with quote
Ok. Does this make sense; Three of the wheels on it are smooth like the pre 66 wheels of the beetle and no hub cap clips but instead it has the bumps for a 66-67 style beetle hub-cap. Looks like I can take a beetle early wheel,remove the hub-cap clips,mig-weld the bumps on them and shape them to hold the66-67 hubcaps and that will give me the fourth wheel. I believe the offset is the same but I haven't measured it yet.
Nancy08
Nancy08 is offline
PostPosted: Mon May 08, 2017 10:17 pm    Post subject: Re: Notch wheels Reply with quote
His 61 different lip as a 62 or 63 wheel i have a slotted wheel but the one as a smaller lip its about. 1/2 and the ither is like One inch
PostPosted: Tue May 09, 2017 8:36 am    Post subject: Re: Notch wheels Reply with quote
I don't think so but post a photo so we can see what you are talking about.
Is the wheel dated 1961? They have a date stamp on the face between 2 of the lug nut holes
Nancy08
Nancy08 is offline
PostPosted: Tue May 09, 2017 10:04 am    Post subject: Re: Notch wheels Reply with quote
Has u could see the lips are different
I can see the date one the white rim can any one tell me if this is a 61 rim because of the lip
PostPosted: Tue May 09, 2017 5:17 pm    Post subject: Re: Notch wheels Reply with quote
I don't know but I can't see the difference in that photo either.
Nancy08
Nancy08 is offline
PostPosted: Tue May 09, 2017 5:48 pm    Post subject: Re: Notch wheels Reply with quote
U can see the lip
Nancy08
Nancy08 is offline
PostPosted: Tue May 09, 2017 6:08 pm    Post subject: Re: Notch wheels Reply with quote
Has u can see the lip ends at the valve stem hole and the white rims. The lip is different
Nancy08
Nancy08 is offline
PostPosted: Tue May 09, 2017 6:34 pm    Post subject: Re: Notch wheels Reply with quote
The lip is 1 inch
The lip is 1/2
