ThatVWGuy Samba Member
Posted: Thu Feb 05, 2009 8:53 pm Post subject: Quiet exhaust that doesn't hang low |
I'm looking for an exhaust that 1) Is quiet. 2) Doesn't hang low. 3) Flows well enough to go on a 2017. Getting two of the three is easy. Any suggestions for an exhaust that addresses all three? |
volksworker Samba Member
Joined: October 30, 2004 Posts: 309 Location: Arizona
Posted: Thu Feb 05, 2009 10:52 pm Post subject: |
Well, SandS used to make a single turbo that tucked up on the right side for a bus............unfortunately they only make the thing header any longer. I used a Thing header [same height as bottom of case, no lower] and used a Bugpack Turbo hideaway and modified it slightly [turned the flange and rewelded] and it works nicely. The Turbo muff is plenty big and will give great results............ I also used this setup on my 2054 powered thing and sacrificed no ground clearance. Kymco now makes that turbo hideaway for the Thing and maybe they make something for a bus....check it out. |
mightymouse Samba Member
Posted: Fri Feb 06, 2009 1:01 am Post subject: |
A1 sidewinder. done deal. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
21-window Samba Member
Joined: March 23, 2004 Posts: 248 Location: out planting
RobzKombi Samba Member
Posted: Fri Feb 06, 2009 5:55 am Post subject: |
2027cc here with an A1 sidewinder at 1.5" But I removed that bis ass turbo muffler the A1 comes with and had it replaced with a smaller and wayyy quiter one. |
6D2 SBS Hit Squad
Joined: August 04, 2004 Posts: 1039 Location: Tampa, Floriduh
Posted: Fri Feb 06, 2009 6:12 am Post subject: |
I like my A1 1 5/8 header... sounds soo nice... nice low rumble... _________________ Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com |
Posted: Fri Feb 06, 2009 6:15 am Post subject: |
Anyone have a wav file or similar so I can hear it?
Looks like you have to take off the muffler to adjust the valves on the passenger side. Is that correct? |
Posted: Fri Feb 06, 2009 6:49 am Post subject: |
with the stock A1 muffler it has a low rumble.
doesn't really sound like a bug motor anymore, more even. |
dlc_b0z Samba Member
Joined: February 23, 2006 Posts: 801 Location: Bradenton, FL
Posted: Fri Feb 06, 2009 7:13 am Post subject: |
How low is your bus? Sidewinder is the best bet but I hear they still hang too low if your slammed. Anybody (whose really low) have pics of the clearance they have with a sw? _________________ Boz
dirtylawnchair |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Fri Feb 06, 2009 9:31 am Post subject: |
ThatVWGuy wrote: |
That is correct, but it really doesn't take very long to take the muffler off. It takes all of 5 minutes, if that.
And the exhaust does have the low rumble; but with a 2017, I'm guessing you'll probably have a set of webers or dells on the motor? You'll hear those over the exhaust at just about all RPM's, so it's not really going to be a big issue. _________________ -Andrew |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Fri Feb 06, 2009 10:59 am Post subject: |
Make your own!
_________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Fri Feb 06, 2009 3:51 pm Post subject: muffler |
A1 sidewinder........they are the best........if you have 600.00 bucks. They arent all that quiet. I assumed money was an issue. If it is, use an existing high clearance header [Thing or "Euro tuck"] and a hideaway turbo and have an exhaust guy do a little fabrication for you. less than half the cost [maybe 1/3] with the right balance between backpressure and noise. |
sled Samba Member
Posted: Fri Feb 06, 2009 4:09 pm Post subject: |
you should contact Krusher here on the samba. He can set you up with anything.
it is in this bus.
_________________ drive your split. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Fri Feb 06, 2009 4:25 pm Post subject: |
Mmmm. Muffler porn |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Fri Feb 06, 2009 5:30 pm Post subject: |
Wow, that set-up of Krusher's looks pretty damn noice... _________________ (O\U|U/O) Top Vw (o\UU/o) |
6D2 SBS Hit Squad
AGUILAR3 Samba Member
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Sat Feb 07, 2009 7:49 am Post subject: |
sled wrote: |
you should contact Krusher here on the samba. He can set you up with anything.] |
you beat me to it. Krushers set up has everything you want. It's got a nice sound too. Not loud. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sat Feb 07, 2009 7:56 am Post subject: |
Will a sidewinder clear a stock apron? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Andrew Samba Member
Posted: Sat Feb 07, 2009 6:16 pm Post subject: |
Riff Raff wrote: |
Will a sidewinder clear a stock apron? |
Yep. Tiger at A1 would have a hard time selling them if they didn't. _________________ -Andrew |
