yellowvan Samba Member
Joined: April 24, 2007 Posts: 127 Location: portland, or
Posted: Mon Feb 23, 2009 2:08 am Post subject: Rear tire carrier |
I would like a rear tire carrier to bold my 15" spare but don't want to pay $600 or more. Has anyone tried adapting one from a junked Pathfinder or other car and has it worked well? I've seen burly ones on old broncos and others on jeeps and sportages that might work with some cutting and welding back together..... |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
jfarsang Samba Member
Joined: August 27, 2008 Posts: 177 Location: Vancouver, BC
Posted: Mon Feb 23, 2009 8:56 am Post subject: |
Bronco's, Jeeps, they all work with little to no modding _________________ '86 Westy 2.1
'94 TD Delica spacegear
'86 TD Syncro camper - gone to a good home
'72 Baja bug (project) - can't seem to leave us
'92 TD Delica camper - gone to a good home |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Feb 23, 2009 8:58 am Post subject: Re: Rear tire carrier |
yellowvan wrote: |
The only ones I'm familiar with are the Broncos - two different types but the mounting brackets are very close to the vanagon contours. Need a little shaping to fit perfectly. I have two in waiting but haven't installed yet. McVanagan's link is to Eric's past project where he installed one. |
Posted: Mon Feb 23, 2009 9:50 am Post subject: |
thanks guys, sounds like the Bronco 2 is the way to go. I was thinking Pathfinder cause I believe it is a bit wider across the back and may be able to accomidate a big fuel can as well. Time for a little junk yarding! I will report back if I find a pathfinder carrier and how it would fit- it would be nice to stow a can back there like the RMWesty carrier (their $600 carrier!). |
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Mon Feb 23, 2009 9:57 am Post subject: |
also one from a kia sportage will work only needs a little reinforcement around a 00 I heard. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Mon Feb 23, 2009 10:15 am Post subject: |
The Pathfinder unit fits very closely to the curve of the corner. You can modify the mounts if you'd like, I wasn't too worried as the body on my old van is already rough and you can see the small deformity anyway. I did have to fabricate a reinforcement plate inside the corner to support the bolts, and another inside the rear lid to support the latch, but this thing is bomber! I can stand on it and it doesn't give--super heavy duty. I also cut the original studs (6-lug) and welded in three for the Vanagon pattern. Then added some angle iron for a fuel can holder. Total cost? $75 + time.
[/i] |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Mon Feb 23, 2009 11:56 am Post subject: |
Thx Karl! Any chance of getting a pic or 2 of the the mounting?
I am in the same boat. I've tried to make the VanCafe spare tire carrier work but I can't get it to stop rubbing on the steering column. I think it's time for plan B. As much as I'd like one of the Gary Lee racks or carriers, my "financial advisor" (i.e. wife) is rather reluctant at this point.
Thx! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Mon Feb 23, 2009 12:23 pm Post subject: |
If I were to do it over, I would have mounted the hinges about 3/4" higher--you see where the latch plate ended up going! No worries, that rear lid is dented and rustyed out anyway.
Last edited by westyventures on Mon Feb 23, 2009 12:27 pm; edited 1 time in total |
Posted: Mon Feb 23, 2009 12:24 pm Post subject: |
@gwtwtlw |
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1242 Location: Portland, Or
Posted: Mon Feb 23, 2009 12:54 pm Post subject: |
That looks like it fits really well. Is there another bolt besides the two visable ones on the sides of the anchors?
I like the extra wide, the Bronco carrier is only good enought to carry a tire. _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
Posted: Mon Feb 23, 2009 1:09 pm Post subject: |
Tristar Eric wrote: |
I like the extra wide, the Bronco carrier is only good enought to carry a tire. |
Yes, there is a bolt from behind as well, you can almost see the recess in the top hinge photo. So three bolts on each hinge. There was a fourth but that is the part that gets cut off. |
Posted: Mon Feb 23, 2009 1:16 pm Post subject: |
ebay sales of pathfinder spare tire carriers just doubled. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
mblotz Samba Member
Joined: February 25, 2004 Posts: 296 Location: D-town, at base of the rocky's
Posted: Mon Feb 23, 2009 2:07 pm Post subject: |
which vehicle will give a Driver side swing? or can the pathfinder one be flipped to swing on the driver side? |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Mon Feb 23, 2009 2:17 pm Post subject: |
mblotz wrote: |
Many Pathfinders have been flipped, but usuallly due to driver error.
Thanks, I'll be here all the week. Try the veal!! _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
Crughy Samba Member
Joined: July 12, 2004 Posts: 576 Location: Montreal, Qc
Posted: Mon Feb 23, 2009 5:10 pm Post subject: |
mblotz wrote: |
The generation 1 Kia Sportage is on the driver side. it's a common one too.
JP |
Posted: Mon Feb 23, 2009 6:46 pm Post subject: |
Love it! |
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Mon Feb 23, 2009 7:54 pm Post subject: |
Has anyone tried a full size Bronco? _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
vinnyvango Samba Member
Joined: March 15, 2007 Posts: 74 Location: Clinton, MS
Posted: Mon Feb 23, 2009 8:35 pm Post subject: |
Awesome Karl! I saw 2 at the pullapart (I went to pull a complete EJ22 turbo.....that got crushed the day before...DOH!).
You say you wished you had mounted it a little higher. When you get a chance would you mind measuring from, say, the bumper to the bottom mount so I can get an better idea of fitment.
Thanks.
Shawn
84/90 Westy/EJ22 sadly non-turbo |
Bruce Wayne Samba Member
