215/70/16 on a syncro with tire chains???
markmc90
markmc90 is offline
PostPosted: Mon Feb 23, 2009 3:56 pm    Post subject: 215/70/16 on a syncro with tire chains??? Reply with quote
Does anyone have 215/70/16 tires and run chains in the snow. I'm planning on buying this size tire but want to make sure there is clearance for chains. I have a stock height syncro, using MB wheels, I think ET 37.
87 Syncro
agreendaya
agreendaya is offline
PostPosted: Mon Feb 23, 2009 4:00 pm    Post subject: Reply with quote
Why have a syncro and not snow tires? I'd been under the impression that they're great in the snow...
'74 Bug - Gone
'69 Westy - Gone
'74 Westy - Gone
'78 Transporter - Gone
'69 Baja - Gone
'91 Vanagon Carat - Gone
71 Bus - Gone
Current: 74 Westy
72 Harley sportster
2011 Jeep JKU
j_dirge
j_dirge is offline
PostPosted: Mon Feb 23, 2009 4:14 pm    Post subject: Reply with quote
Because even snow tires will slip and slide as conditions get icy.
And braking downhill.. flatout dangerous.
Here in California, Caltrans closes most HWYs before conditions require
"4WD AND chains".. but that does not mean the conditions do not exist.
In fact, Park Rangers turned me back from the road to Badger Pass (Yosemite) a few winters ago... I had 4WD and M&S tires.. but had left the chains at home.. OOPS!
They were letting 2WD with chains thru. (No. I did not successfully argue thier logic.)
Try getting up a 10-15% icy grade (like a curvy county road into a cabin, as an example).
The worst winter roads I've ever driven were back county roads after snowfall that had partially melted and refrozen.
PS.. don't know if chains will fit the well with that tire size, but I'd sure like to know since I've been toying with the idea of 16" Hydroedges for my 2WD.
markmc90
markmc90 is offline
PostPosted: Mon Feb 23, 2009 4:15 pm    Post subject: Reply with quote
They are great but even a snow plow needs chains sometimes. I would just like to be able to if needed.
87 Syncro
agreendaya
PostPosted: Mon Feb 23, 2009 4:27 pm    Post subject: Reply with quote
Aha, good to know. I've driven over Donner pass a couple times in gnarly weather in my '74 Westy with chains on, no problem, and our family's Suburban with snow tires, but hadn't had any experience with it being that bad.
'74 Bug - Gone
'69 Westy - Gone
'74 Westy - Gone
'69 Baja - Gone
71 Bus - Gone
Current: 74 Westy
72 Harley sportster
2011 Jeep JKU
markmc90
markmc90 is offline
PostPosted: Mon Feb 23, 2009 4:34 pm    Post subject: Reply with quote
Even in Portland this year chains were required on all highways for a couple of days due to ice. I'm planning on just using AT tires year round and selling my snow tires as well.
87 Syncro
WestyBob
WestyBob is offline
PostPosted: Mon Feb 23, 2009 4:49 pm    Post subject: Reply with quote
I'm interested in hearing about too. I know clearance to the trailing arms is close using 215/75 sidewalls on 15" steelies.
Never had to use chains on the syncro yet but could have used them on solid road ice last year in Northern Idaho.
About four years ago .... headed west from Susanville got caught in a major snowstorm at the pass - @ 1.5 feet of snow .... syncro pulled through ok. Then headed north to the Siskyous .... mandatory chains .... I drove straight up to the nearest standing cop, said I have mountain rated nokians, he just waved me through. The whole way up and over only about an inch of snow and no ice. But I always carry chains in winter anyway just in case the next cop isn't so nice or they're 'really' needed.
insyncro
Banned
insyncro is offline
PostPosted: Tue Feb 24, 2009 8:45 am    Post subject: Reply with quote
I have owned so many Syncro vans I have lost track.
I have driven them all over the US during the snowiest of conditions.
I have only used Nokian studded snow tires and I have been able to drive these vans without issue.
I pull allot of people out while on my journeys.
Chains are for low speed only and have a nasty habit of banging up your fender wells if not kept tight.
A diff. lock is a much better option IMHO.
dylan
sunshine_norway
sunshine_norway is offline
PostPosted: Tue Feb 24, 2009 2:59 pm    Post subject: Reply with quote
For winter and snow there`s only one thing! Studded tires...!
I`m in LOVE with my Cooper wheatermaster tires.
215/75-15
Not many cars have overtaken me this winter. I just love the way they connect my syncro to the road....! Smile
In the curves I easily hold 50 mph, where others are down to 35-40 mph....
View user's profile Send private message Visit poster's website MSN Messenger Classifieds Feedback
vwsyncroguy
vwsyncroguy is offline
PostPosted: Tue Feb 24, 2009 3:28 pm    Post subject: Reply with quote
And now for your question.....
I rarely drive in the snow...so I'm only speculating here...and do not have experience with your size tire w/ chains.....that being said.....
You didn't say what make tire you have...but BFGs are the most common....so lets start there...
The largest tire you can get on a Syncro without custom rear trailing arms is 29.5" tall. This size only leaves about 1/4" of clearance to the rear trailing arm. You cannot fit chains on this tall a tire.
BFG says a 215/70-16 is 28" tall...so you should have 3/4" (half the total height difference) additional room for chains with your tire.....however, that to the real trailing arm. The danger is in the front......I have used 215/75-15" tires which are about 27 3/4" tall and they rubbed the rear of the front wheel well if you hit a dip with the wheels turned....a friend of mine has this size BFG on his Syncro and has even crumpled his fender lip a bit.
So the chains....particularly cable chains...should go on...OK...but I think you're in real danger of some sheet metal damage to your rear front wheel well if a chain catches the lip. If you watch what you're doing and creep over any bumps or dips when turning....you might be OK.
Warren C.
ThorAlex
ThorAlex is offline
PostPosted: Tue Feb 24, 2009 3:35 pm    Post subject: Reply with quote
You know, sometimes chains can be good to have rapid. Especially for poor students like me that cant afford 15" rims and good tires. I've got stuck twice since i got the syncro, both times in deep snow, no use for studs there. Would have gotten out in 15 minutes if i had chains, instead of 30-45. But i agree, you don't need chains for road use, only for emergency and offroad. And that applies to 2wd cars to, just drive according to conditions and you can get trough pretty rough weather and road conditions
View user's profile Send private message MSN Messenger Classifieds Feedback
vwsyncroguy
PostPosted: Tue Feb 24, 2009 4:00 pm    Post subject: Snow can trip up a Syncro Reply with quote
Riding with a friend, offroad, about 20 miles outside Bishop, CA in Syncro with 215/75-15 BFGs, ...no chains.
Road was 98% dirt...except for this north facing ravine
A long afternoon and a painful towing bill.
Warren C
markmc90
markmc90 is offline
PostPosted: Tue Feb 24, 2009 4:10 pm    Post subject: Reply with quote
I know that studded snow tires are great, however there are some situations where you just need chains. Not to mention when Johny law says you do, I dont want to argue with him about my locking diff, just the peace of mind that I have the chains and can use them.
87 Syncro
gator70
gator70 is offline
PostPosted: Tue Feb 24, 2009 8:47 pm    Post subject: Reply with quote
I would not put chains on those 16's. I think you will have rear trailing arm clearance issues.
Jon_slider
Jon_slider is offline
PostPosted: Sun Mar 01, 2009 10:27 am    Post subject: Reply with quote
lessons learned may include carrying a recovery kit, or did you have one with you that failed to extract the vehicle?
and maybe carrying a bicycle when offroading alone would be good insurance in case the vehicle is disabled and you have to walk out..
Here are the chains Bill Burke recommends
http://www.bb4wa.com/articles/Chains.htm
here is a review of a recovery kit based on either the HiLift Jack or Magnum Hand winch:
http://www.thesamba.com/vw/forum/viewtopic.php?t=343910
and from
http://www.bb4wa.com/articles/Accessories.htm
"Say you are exploring a back country trail and you slide into a deep rut and get stuck. Yes, it's that easy! Do you:
a) throw your hands up, walk out and try to find a tow truck (for about $400);
b) grab any old blanket and bush and throw them under the tires hoping it'll work;
c) get your partner/wife/husband/kids to push on the bumper, spinning the tires, furiously slinging mud all over the place; or
d) have a plan and equipment to easily get unstuck and merrily on your way?"
tencentlife
tencentlife is offline
PostPosted: Sun Mar 01, 2009 1:14 pm    Post subject: Reply with quote
Ummmmmm.....let's see........
d!!
How'd I do?
See innovative Vanagon accessories at the Vanistan shop:
I don't use The Samba Private Messaging. Please use the contact link at www.intrepidoverland.com
"Official" IntrepidOverland thread for news and discussion:
kurt vonnagon
kurt vonnagon is offline
PostPosted: Fri Jan 20, 2012 9:29 am    Post subject: Reply with quote
On syncro tire size must match for the all wheel drive. Doe's that mean you must use chains on all four tire's. I have 215/75/15 on audi rims so i have only about 1/2 " clearance on rear trailing arm how are the cable compared to the chain. Thanks
WestyBob
WestyBob is offline
PostPosted: Fri Jan 20, 2012 10:47 am    Post subject: Reply with quote
Ideally on longer road trips, yes, or disengage (decoupler) the VC and drive in 2wd with rear chains and dif-lock (lower speeds) engaged where needed. On short runs it's not as critical, can go awd with chains on back (or front) only.
The main thing about front/rear tire match thing is allegedly not over-heating the VC material which is far more probable on sustained high speed drives when unmatched.
Chains/studs are primarily best for ice and dirt traction .... don't do a whole lot for snow, sand and gooey mud where your tire tread and material shedding matter more.
r.e.wing_fc3s
r.e.wing_fc3s is offline
PostPosted: Fri Jan 20, 2012 11:03 am    Post subject: Reply with quote
i have chains the same design as the RUD grip series. made by laclede. i have a 2wd and therefore put more stress on the chains when im offroading in the snow up steep hills. Almost every time ive gone out the side links on that style of chain mentioned above has failed. i started carrying around extra links to field repair but last time the the tension chain(red) which holds everything together broke. there not really designed for off road use according to the RUD catalog. easy to mount though. for my application ill be getting something with welded side links like the pewag austro super v.
Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com
Oceanpro907
Oceanpro907 is offline
PostPosted: Fri Jan 20, 2012 11:11 am    Post subject: Reply with quote
I think you will have plenty of clearance but personally, now driving on ice and snow for the last 4 months straight, there is no need unless the law says you have to. Our roads here in Seward Alaska have been completely covered for 4 months. The one time is warmed up and rained, it was rain ON TOP of snow and ice and the Syncro still was great.
I think the weight distribution on these things make them perfect in the snow.
