of coarse i looked first 70' square pop outs
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Sat Feb 21, 2009 11:30 pm    Post subject: of coarse i looked first 70' square pop outs Reply with quote
i have the pop outs but i have NO hardware for them
i have 2 slots and 2 holes for the hinging side and 3 holes that hold the latch in
WHAT are the sizes
are they bolts int a threaded plate or just screws
and what the best to use around the tabs
one has black rubberish stuff on it
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
DHanna
DHanna is offline
PostPosted: Sun Feb 22, 2009 2:48 am    Post subject: Re: of coarse i looked first 70' square pop outs Reply with quote
WHAT are the sizes
There may be a similar article here on The Samba but here is one from our Australian site in answer to a similar question. The info here is for Notches as well. The Squares have the latches held by self tapper screws rather than metal thread screws. The slots in OZ built Notches and later model Squares must also have the hinges fitted into the B pillar. The 2 holes are jig holes for alignment of the hinges in the B pillar. The link should take you to the post on Aussieveedubbers.
http://forums.aussieveedubbers.com/viewtopic.php?tid=60859#pid579020
DH
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Feb 22, 2009 9:42 am    Post subject: Reply with quote
The factory originally had a welded in nut plate that the latch machine screws went into.
Sheet metal screws into the C pillar will not hold in the long run. The sheet metal by itself is not strong enough.
There is info in this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=339593&highlight=pop+outs
Gary: OK. Ima poop.
mktooslow
mktooslow is offline
PostPosted: Wed Mar 04, 2009 11:03 pm    Post subject: Re: of coarse i looked first 70' square pop outs Reply with quote
WHAT are the sizes
I am in the same boat with my '72. I have the pop outs and new seals but can not seem to locate or get a straight answer about the front hinges from anyone. I think I am about to bust out some sothern enginuity and build some myself. Now if only I knew what they were supposed to look like.....
