Should I go with half pans or patch together quarter pans? |
Patch together some quarter pans and whatever else you have laying around and keep as much original metal as you can! |
21% |
[ 3 ] |
Use half pans and make it pretty. Who cares that the half pans have that weird curved groove. |
78% |
[ 11 ] |
Total Votes : 14 |
noexit Samba Member
Joined: September 18, 2006 Posts: 329 Location: Tacoma, WA
Posted: Wed Mar 11, 2009 2:49 pm Post subject: Half Pans vs Quarter Pans |
I've been asking around, and there seems to be different schools of thought on pan replacement. I originally bought 3 quarter pans, thinking that's all I needed. But as I've ground rust off, I've found that I need all four quarters, plus the pan rails have some holes through them. The quarter pans I have are Tabco, from House of Ghia, and seem sturdy. Maybe 16 gauge? Currently available pan halves KGPR are 19 gauge, Dansk pans.
My pan rails are rusted through near the jack points and near the dog legs. I've received two opinions, one from a local custom/restoration shop owner, and one from a supplier. One said go with the pan halves since patching everything together will look like crap, and 19 gauge will do fine, and one said it's better to patch everything together with the thicker quarter pieces. (As I type this I'm thinking that quarters are going to be a PITA) I'm kind of leaning towards half pans from KGPR. What do ya'll think? It's a '62. _________________ Rusty '62 L360 seeblau, L289 blauweiß Type 1 Karmann Ghia |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Wed Mar 11, 2009 3:42 pm Post subject: |
I've welded new 1/2 pans in before, fixing the mess someone made with the 1/4 pans. They look awful. Plus, they didn't seam seal it correctly and in the end it rusted much worse then it was originally. Properly welded 1/2 pans look like the were installed by the factory. Whenever I look at cars to buy now, I lower my price when I see 1/4 pans. I think, where else did they not spend the money to do it right? _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
CLKWRK Samba Member
Joined: October 02, 2001 Posts: 566 Location: Toronto
Posted: Wed Mar 11, 2009 4:16 pm Post subject: |
I beleive that weird grove is for 72 and later heater lever wires.
If I see them on a pre 72 I know they have been replaced, a bonus if done right.
However I did replaced quarter pans on my ghia and butt welded them in solid, you wouldnt be able to tell I changed them, I still say half pan unless you can make the seam disapear |
Posted: Wed Mar 11, 2009 4:19 pm Post subject: |
CLKWRK wrote: |
Oh, it can be done. But the level of skill to correctly replace a 1/4 instead a half is MUCH higher. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
74Ghia Samba Member
Joined: December 17, 2003 Posts: 2131 Location: Middle of Georgia
Posted: Wed Mar 11, 2009 4:21 pm Post subject: |
I'd go with pan halves. They may take a little more work to get installed but I think you'll be much happier with them. If by the weird groove you mean the one in the front half that runs from the tunnel towards the heater channel, that's the groove that the cable fits into for the front foot heater vent. It connects to the front end of the heater/defroster lever. _________________ Allen C.
2012 Silverado
53 FiberFab MG TD Replica (VW)
Life is hard and its harder if you're stupid. |
hosspowerinc Samba Member
Joined: December 12, 2005 Posts: 391 Location: Murphy NC
Posted: Wed Mar 11, 2009 5:40 pm Post subject: |
Id use pan halves as well. I put the patch panels in my car but it had very little rust. Yours sounds like it would take way too much work to fix with 1/4s |
dink911 Samba Member
Joined: September 25, 2008 Posts: 110 Location: Dallas, Tx
Posted: Wed Mar 11, 2009 8:16 pm Post subject: 1/2 pans |
1 vote for the 1/2 pans, It does look so much better
_________________ **********************************
Steven G.
71 Ghia
"When a defining moment comes along, you define the moment... or the moment defines you."
noexit Samba Member
Posted: Wed Mar 11, 2009 8:58 pm Post subject: |
I think 1/2 pans are what I've decided to do. After talking to two restorers, one near my office and one near my house today, it's the way to go. Both said that it's what they'd do. I've placed my order with KGPR. _________________ Rusty '62 L360 seeblau, L289 blauweiß Type 1 Karmann Ghia |
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Thu Mar 12, 2009 6:53 am Post subject: |
I did quarter pans on mine but i wish i had done the whole halvs. I ended up spending more time patching little crap that would have been delt with swiftly by just going to a whole piece. You will never know i put quarters in after paint but I spent alot of time grinding a welding to get it there.
I think you'll be happier in the end, good luck
Dustin _________________ 63 ghia coupe |
