beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Wed Mar 11, 2009 6:31 am Post subject: |
Ok
I have a 1950 25 hp case with a stock crank and rods
I'll fit bigger valves (33 inlet 30 exhaust I think) and do some small porting work to some 36 heads, and up the compression to about 7.5:1
Twin 28pci carbs, 383 dizzy, 6volt. unsure on cam, straight cut gears cos I love the sound
83mm barrels and pistons using 1500 remachined barrels
I don't want anything too mad, 50hp would be great, 60hp would be fantastic. Its running 1950 brakes . Something like my old stock but very well built (not by me) 1300sp would be good.
My Preferences are
Reliability
Rebuildability, if I break it I can buy it again!
Cost
Power
The 40hp big bore pistons are tempting but I can't get them in the UK. Are they abundent in the US? I know of several sources but will they all dry up in a few years?
Now back to these pistons.............
Cheers
Seb
Posted: Wed Mar 11, 2009 8:40 am Post subject: |
Whats the Compression height on a 36hp piston?
I'm away from home till the weekend so can't measure it.
its the centre of the wrist pin to the top of the piston if anyones got one about
Seb |
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Wed Mar 11, 2009 10:32 am Post subject: |
in my mind is 38mm |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Thu Mar 12, 2009 7:34 am Post subject: |
I'd like to go bigger on the next one but I think I'll need to run a counterweight crank too.
With a stock 64mm crank, I agree 83mm is as far as I'd go, I'd like to do a 87mm with a 74 or even 76mm crank, but thats a pipe dream for a while.
Seb |
grueni Samba Member
Posted: Fri Mar 13, 2009 4:47 am Post subject: |
counterweight is not really needed except you will run over 6000 rpm.
its more important to keep the moving mass low. balanced stock 64/74mm cranks will be the best way. 87mm bore is a real dream in a 36hp head and case too |
Posted: Fri Mar 13, 2009 7:14 am Post subject: |
The engine I'm doing now needs to be reliable and nippy. The other one just wants to be nuts and quick I don't even have a car lined up for it.
Anythings possable espesially with a big hammer
Seb |
Posted: Fri Mar 13, 2009 9:56 am Post subject: "H" Beam 36hp Con. Rods |
I have been reseaching the idea of having some "H" beam connecting rods made up for the 36hp engine. As bigger pistons and longer stroke crankshaft are being used nowadays, the need for a stronger link is necessary to prevent the little beast from blowing itself up! I have taken apart engines that were built by "experts/Bozo's" and found bent conn. rods?!?! I will post more info. as progess continues....Cheers! Mr. Okrasa
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
Posted: Fri Mar 13, 2009 2:40 pm Post subject: Re: "H" Beam 36hp Con. Rods |
Mr. Okrasa wrote: |
Your Not the only one I've been measuring up 2" chevy rods with overseized bushes for the 50mm journals of the 36hp. You could do something similar on the porsche crank
Seb |
tommy-turtle Samba Member
Joined: March 07, 2002 Posts: 165 Location: roseville
Posted: Mon Mar 23, 2009 10:42 pm Post subject: |
Julio Iniguez wrote: |
grueni wrote: |
changing the 36hp rods from 20mm pin bearing to 22mm work and up to 100HP I wouldn't think about problems.
but there are a1ot aftermarket pistons with 83,5mm or 83mm with 20mm pin diameter. |
You are correct, that's how Mark H. found the ones for my motor. Hint, you can check out pistons for late '80's early '90's Japanese.
Julio |
Give it away why don't you
henry roberts wrote: |
possibly nissan CA18DET ?
getting close? |
Wrong Manufacture
Another HINT look for piston for stock motors.
Hastings still makes rings for these pistons.
Running with a Porsche rod is not a problem |
Posted: Tue Mar 24, 2009 1:46 am Post subject: |
I'm still stuck
Mahle has a good search on their website but I can't find anything jap.
The Peaugot 205gti pistons are close and are the way I may go
But someone PM me the answer, please!
Seb |
Posted: Tue Mar 24, 2009 10:08 pm Post subject: |
beetleseb wrote: |
I'm still stuck
The Peugeot 205gti pistons are close and are the way I may go
Seb |
What Cam?
You are still running 64 stroke? You say you want to run this in a 25hp case
I would not use the 25hp case because you are going to have to change the studs if you run 36 heads, and good one are not a euro a dozen The cylinder head tin for the heads have to be changed. Run what ever you want , just my suggestion.
It is not like you are doing a 1600 to a 1641 swap here. Each step is different. first you start with the 25hp non accelerator pump carb and swap that out and hone the venturi and you think you 25hp is a new car. then you swap the dist, and that car is even more alive. Then the next step what ever you do is a big step. The pistons that Julio has in his car might pop out of the top of your motor. And none of this stuff is at the corner speed shop. Actually the piston that he is using actually will not work in you car because he is using a different crank.
Here is another hint that will help you in your piston search
"TOTO, I don't think we are in Kansas any more"
Suck, Squeeze, Bang, Blow is some times the same as Intake, Compression, Power, and Exhaust , but some times it is not! |
Posted: Wed Mar 25, 2009 3:10 am Post subject: |
I've sussed the piston, just gotta buy some now. Looks like mk1/2 Mazda MX5 1800 8valve will do the job. (Now that really does give it away)
My cars a 50 so making it look like a 25hp is a non brainer to me. I'd have thought you where more worried about me full flowing and boring out the cylinder holes on my 25hp aluminium case. 36hp heads can be modded to use early tin etc.
The engine I have is made from parts and swaps. I started off with a free 36hp and by some generous swaps and blags I've got several 36 heads and cases, a 25hp longblock, 383 dizzy, split bug genny and reg etc and the project so far owes me nothing. The only stock bits I need are tinware. I'd not be doing this to a mint stock 25hper. The case I'm using is okay but the cam gear had started to rot away
I'm planning on running a mr okrassa cam, I have both 36 and 25hp heads. Yes its a 64mm crank, simply becouse I can. I do have a 356 crank on its way but I'll save that for the next one.
All hints and tips welcome
Seb |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Mon Sep 15, 2014 2:58 am Post subject: |
so what happened with this? did it get built? |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Wed Feb 01, 2017 4:14 am Post subject: Re: 1500 83mm barrels and pistons on a 36hp? |
I am wondering if there is a difference in the VW 1500 83mm piston & cilinders and in the 1385cc 40hp 83mm big bore kit for a 1200? Are the cilinders the same? Which will fit better?
I am able to buy a 1385 big bore kit for a 40hp motor but would like to fit that to my 36hp motor, icm with a 74 DPR crank,
What machining must be done and which challenges might be faced?
Currently running a 1192cc with WW Okrasa kit, with later 1200 domed pistons and some other mild modifications (WW okrasa camshaft, lightened flighwheel, lightened & balanced rods, carbs by Joe) |
