36hp cam gears
128vw
128vw is offline
PostPosted: Wed Mar 25, 2009 8:34 pm    Post subject: 36hp cam gears Reply with quote
Can I use later model, 40hp and newer, cam gears ina 36hp if I change both the gears? Maybe straight cut gears? They seem to be the same diameter and bore size and the spacing seems to be the same. Just have a different angle on the teeth. will they run OK with no cam thrust bearings? Thanks
krusher
krusher is offline
PostPosted: Thu Mar 26, 2009 1:20 am    Post subject: Reply with quote
You would be better putting this thread in the vintage speed forum.
(06:31:07) RoachGhia: "i drink dick way too fast"
128vw
128vw is offline
PostPosted: Thu Mar 26, 2009 6:51 am    Post subject: Reply with quote
I thought that this would be the right forum because its an engine question. As in engine rebuilding.
Alan_U
Alan_U is offline
PostPosted: Thu Mar 26, 2009 7:21 am    Post subject: Reply with quote
If your running straight cut gears you really dont require double thrust cam bearings. Some either use 2 sets of standard cam bearings to make 1 double thrust "kit" or just buy mahle red box double thrust.
I have a set of 36HP cam gears at my shop. You just have to get a machinist to spot face the cam gear for the bolts for the cam. The helical cut angle is aprox 1/2 of a 60HP cam gear.
In the grand scheme of things the 36HP should be quieter than straight cuts and make less thrust (compared to 60hp) even when using stiff valve springs.
If you all that concerned buy some good quality billet straight cut gears. If you buy cheaper cast ones you just asking for trouble.
11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's.......
krusher
krusher is offline
PostPosted: Thu Mar 26, 2009 2:37 pm    Post subject: Reply with quote
And if you go read the vintage speed forums you will find all they talk about is 36/40 hps
Here is mainly a 1600+ knowledge base
