schoonerman Samba Member
Posted: Mon Mar 30, 2009 1:47 pm Post subject: Rear brake drum removal???? |
All I wanna do is take the brake drums off my 87Westy to check the shoes and clean.....but they wont come off.
I don't have the pullers to remove the hub or the tool to remove the hub nut
I've searched and found.... 'don't hit or heat the drum.'
Any advice would be great
Thanks |
mr_vanagon Samba Member
Joined: March 31, 2005 Posts: 589 Location: Southern Illinois (GO SALUKIS)
Posted: Mon Mar 30, 2009 1:55 pm Post subject: |
You don't have to remove the hub and you don't need any special tools. First, be sure that all the wheels on the ground have a block on each side of them. Then be sure that the parking break is off. Third, back the shoes away from the drum by turning the star wheel from the back side by sticking a short screw driver through the inspection hole. A small mirror propped on the trailing arm has helped me with this many times. Whacking the edge of the drum gently with a rubber mallet has never been a problem for me. Usually the biggest issue is keeping the drum from falling on my toes as I tapped it with the mallet. _________________ '68 Autostick Bug Mom bought new
'89 Tintop Vanagon Dad bought new |
insyncro Banned
Posted: Mon Mar 30, 2009 1:56 pm Post subject: |
I use a 4x4 piece of pressure treat to wack the drum, spin and repeat, wack, spin repeat.
You can try to spray lube into the seam around the axel and at each stud.
I haven't needed to do that.
Becareful not to hit the backing plate, just the drum.
It will come off with some good wacks.
When you replace, coat all mating surfaces with antiseize.
dylan |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon Mar 30, 2009 1:59 pm Post subject: |
If you don't know when the last time they were taken off, they could be rusted on.
the first time I took mine off, I had to use pb blaser around the bolts and had to work them for a good hour each.
Now they come off real easy. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Mar 30, 2009 2:25 pm Post subject: |
Isn't there also a small bolt on the face of the drum that also needs to be removed? No one has mentioned it yet. |
markmc90 Samba Member
Joined: June 13, 2007 Posts: 295 Location: Portland, OR
Posted: Mon Mar 30, 2009 2:28 pm Post subject: |
Dont forget the small bolt on each rotor. 10mm I believe. _________________ 87 Syncro |
Posted: Mon Mar 30, 2009 2:41 pm Post subject: |
I kind of figured the two small bolts were a given. |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Mon Mar 30, 2009 2:42 pm Post subject: |
11 mm socket _________________ LEARN TO SELF RESCUE
.....................All Current.......................
Posted: Mon Mar 30, 2009 2:47 pm Post subject: |
mightyart wrote: |
Not if it's your first time. |
