K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Tue Jul 25, 2006 12:41 am Post subject: need water tank key for '84 Westy |
Steve's Lockshop in Texas wants me to send him my lock cylinder
Isn't there an easier way to get the lock re-keyed or a get a new key?
TIA |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Tue Jul 25, 2006 5:10 am Post subject: |
Give this a try. Otherwise I think any locksmith (not your local hardware store) is able to make a key. If they cant then try another, thats there job. No need to send it away. You will need to bring in the lock/core so if it is in the van that is another story. http://www.vanagon.com/problems/water-tank-key.html _________________ 82 Westy: Air is cool! |
Mr Brown Samba Member
Joined: January 30, 2006 Posts: 161 Location: Somewhere In Canada
Posted: Tue Jul 25, 2006 6:32 am Post subject: |
I had mine made at a local Locksmith. He claimed to have made many Westfalia water tank keys. Cost me $20 for the two keys, I guess he had to take the cylinder apart. I had to remove the filler assembly from the van, then disassemble the locking cap to get it out. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Tue Jul 25, 2006 6:37 am Post subject: |
deleted
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Jul 25, 2006 6:48 am Post subject: |
Is yours locked, and you don't have the key?
It's a very basic design, mine hasen't locked since I had it, but sits there real nice.
It was three months before I got the bright Idea to pull on it to see if it was locked. I just assumed it was since I bought the Westy.
Here's what it looks like.
here's a post on the westy plumping
http://www.thesamba.com/vw/forum/viewtopic.php?t=120652 |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Tue Jul 25, 2006 11:05 am Post subject: |
Any locksmith should be able to make one for next to nothing. Only problem I had was the key blank used was a little on the long side, so it's hard to get in and out if i put the plug in the wrong way (key cut part facing down).
Rich |
K58 Samba Member
Posted: Tue Jul 25, 2006 3:28 pm Post subject: |
mightyart wrote: |
now there's an idea...I'll see if it's locked
just got the van and been working non-stop on the nagging electrical issues
seems to me you could just pop in a lock cylinder of the same size and be done...why not?
BTW, thanks to all for the responses |
randywebb Samba Member
Posted: Tue Mar 31, 2009 6:25 pm Post subject: |
Suppose your newly bought Westy has a locked water fill lock and no key...
then what? can you remove the 4 screws on the square door and pull the whole thing out?
or does that just remove the surround and not the locked cap itself?
thx! |
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Wed Apr 01, 2009 5:01 pm Post subject: |
yes you can remove the lock from the outside of the van by removing the utility flap first. i can't remember the exact sequence, but it was easy. just remember to note the order that all the nuts, washers, etc. come off in, for reassembly.
i used steve for mine - he has one of every possible water tank key, so he just tries them in order until he finds yours, then sends you the lock and keys back. reasonable price too, if i recall from a year ago.... _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
Posted: Wed Apr 01, 2009 8:41 pm Post subject: |
thx - how do I contact "Steve"? |
Posted: Wed Apr 01, 2009 10:07 pm Post subject: |
ah yes, sorry - that would be the 'steve' of 'steves lock shoppe' mentioned previously in this thread, reachable at http://www.steveslockshop.com
and to clarify, to get your locks off (snicker) you need to remove the whole utility port thing via the 4 screws (not just the utility 'flap' as i said in my last post), then undo the hose clamp, then it gets obvious from there. good luck. _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power
85_Westy Samba Member
Joined: April 26, 2008 Posts: 109 Location: Houlton, Maine/Glade Spring, Virginia
Posted: Thu Apr 02, 2009 4:07 am Post subject: |
FWIW, I have the water tank keys for my '85 Westy and have never used them. I've had it for 7 years now. I always fill the tank from inside the van. I have to access the tank from inside in order to clean it anyway so filling it from there is a natural.
Mike |
Posted: Thu Apr 02, 2009 8:42 am Post subject: |
Any locksmith can make one. At worst they'll need a day or two to get a key blank, but may have one in stock. They could even pick it for you, if you pay a little more... _________________ Rich |
Posted: Thu Apr 02, 2009 12:39 pm Post subject: |
from my experience doing this a year ago, most local lock shops did not have the correct key blank
> ILCO DM31; ILCO 1092 C or Y12 can be shortened to work
and the couple of them that did wanted much more than steve did to make the key.
i'm guessing that the labor required to make the key based on the pins (much less pick the lock and find the blank) is far more than steve simply trying each of the 20+ keys and sending you duplicates he has in stock....
for me, it's easier to fill via the utility port, especially when the van is already packed and the water tank lid is covered with stuff. (not to mention the one time i did fill from the inside...and the cheapo plastic nozzle i was using popped off of the hose at fairly high pressure and blasted the inside of the van!) _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
Jon_slider Samba Member
Posted: Tue Sep 15, 2009 9:32 am Post subject: |
I tried 2 locksmiths, neither could make a key for my water tank lock, which currently has no key.
One of the locksmiths has an ILCO DM 31 keyblank for $20, that could be used to cut a spare key..
But, Steves price is only $13 to make the first key, and $4.50 for the second key.
Steve's Lock Shop current correct contact info is
Steve's Lock Shoppe
63A Summer Pl.
Huntsville, TX 77340
936.293.9362 (cell)
He informs me there are 34 possible key combinations (he has every key), and he also has a few OEM tumblers for sale. |
erdonline Samba Member
Posted: Thu Sep 17, 2009 11:35 am Post subject: Water tank key |
My new '85 Vanagon Westfalia came with the main key (which on mine also does the gas cap, the glove box key, and the key for the water tank lock (old style with a real lock under the flap, not the locking cover with the little plastic tab key.) I wanted to get some duplicates. I already had the main key blanks.
I looked at this and a few other threads about the ILCO key blanks that fit. The DM 31 was $10 at a nearby hardware store that could get it but had to order it. They did have the ILCO Y12, which is supposed to work if you shorten it a bit. The locksmith there shortened it and cut the key, but when I got it home and tried it, it didn't fit. Upon closer inspection, I saw that the groove is a little narrower on the Y12 than on the original. I'm going to try to widen it a bit with my Dremel, and go ahead and get the $10 key that is supposed to fit right.
Has anyone found that the Y12 works? How about the ILCO 1092? The shop didn't have that one. Hopefully the DM 31 will fit without alterations.
I'll report back if the mod to the Y12 works.
Ed in CT _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
Timwhy Samba Member
Posted: Thu Sep 17, 2009 3:12 pm Post subject: |
Ed, I don't think you should spend that $10 for a key that just might not work.
I had this same issue last week and I bought 3 of the dm31 keys thinking I'll have spares but that key was too big for my lock. The keys were from a locksmith and they were $1.50 each. I returned them and got my money back.
The key that I did get from a nice lady, that did work in my lock was much smaller. I have the locksmith trying to find out what the key is as the markings on it just said American.
I believe my key came from a 85 Westy and my Westy is an 87.
Check around some more locksmiths before you drop that $10 for a key that might work. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Fri Sep 18, 2009 9:03 am Post subject: Water tank key |
I tried using the Y12 keys, and they didn't go in at all. The key looks slightly thicker, and the grooves are not quite as wide. I used my Dremel to widen the groove and slim down the key. I tried this on the two that I had made (the locksmith who copied already shortened it- it was also a little too long.)
One key now works if I push it in really hard; the other one still doesn't go in. I'm having them order the correct DM31 ILCO equivalent. A bit pricey, but I'm willing to try one from my semi-local store. They're pretty helpful and friendly and willing to help me research)
Ed _________________ '85 Vanagon Westfalia
Timwhy Samba Member
