Rodknock Samba Member
Joined: April 06, 2006 Posts: 516 Location: Boulder CO
Posted: Wed Sep 17, 2008 5:40 am Post subject: |
I did exactly as Izzydog and installed the sureflo faucet (the orig Westy faucet was crap and it finally broke). This is the way to go. You will get more water volume out of the Sureflo than the orig faucet even with the orig Westy pump. The knob to turn on the water moves easily so you don't waste water, and the knob controls the water flow (variable). This is probably the best mod I've made to my Westy this year. Highly recommended. |
izzydog Samba Member
Posted: Wed Sep 17, 2008 9:39 am Post subject: |
Add a foot switch and you will have the ultimate Westy faucet! |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Wed Sep 17, 2008 10:01 am Post subject: |
Z Products out of Wilsonville Oregon has a similar setup as well.
Z Products Autosport
30625 Southwest Boones Fy Rdb
Wilsonville, Oregon, 97070
Phone: (503)682-1267, Fax: (503)682-3391
E-mail: [email protected]
I will try to get a better link when I have a chance. They also make some curtain kits and other neat westy stuff. _________________ Happiness=Portland, Oregon in the rearview mirror! |
madspaniard Samba Member
Posted: Fri Nov 07, 2008 9:23 pm Post subject: |
I went ahead and installed a Shurflo faucet and foot switch, very nice upgrade.
I'm just wondering if anybody tried to also connect the city water line using a T fitting and a check valve. problem I see is the size of the city water hose is different and you would also need to use city water hose from the T fitting to the Shurflo faucet single inlet. |
Dogpilot Samba Member
Posted: Sat Nov 08, 2008 9:53 am Post subject: |
I went for the Euro westy style faucet. It pulls out and can be used as a shower as well. I pull it out and lay it on the dish towel in the sink with the top down. It adjusts from stream to shower by twisting the end.
_________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Sat Nov 08, 2008 10:11 am Post subject: |
wow! where did you buy that faucet dogpilot? |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Sat Nov 08, 2008 10:41 am Post subject: |
How do you close the lid? |
Posted: Sat Nov 08, 2008 11:04 am Post subject: |
mightyart wrote: |
Hi mightyart,
the faucet rotates 360 in all directions so you can rotate it down into the sink
Posted: Sat Nov 08, 2008 11:14 am Post subject: |
Ah, I see, pretty cool.
Must just be the angle of the picture, is still looks like it's sticking up past the lip there. |
Posted: Sat Nov 08, 2008 11:15 am Post subject: |
to mount the Shurflo faucet I bought an antenna base like the one in the link below and modified it the following way: cut out the stickup, drill a bigger hole in the middle for the faucet, and install it upside down
It's almost a perfect fit, same number of screw holes and amost same distance between screw holes. I even used the same black screws and gasket that came with the original faucet
https://www.westmarine.com/west-marine-fixed-stubby-nylon-antenna-deck-mount-139685.html
Posted: Sat Nov 08, 2008 11:17 am Post subject: |
mightyart wrote: |
yeap! it's the angle of the pic, the faucet fits perfect under the cabinet lid |
Posted: Sat Nov 08, 2008 11:29 am Post subject: |
I bought the Eurostyle Faucet in Luxembourg via the internet.
I do think the Shureflow is defiantly cool, but is it just me, or when it is in the down position does it look like..... _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Sat Nov 08, 2008 11:33 am Post subject: |
Dogpilot wrote: |
but is it just me, or when it is in the down position does it look like..... |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Sat Nov 08, 2008 6:52 pm Post subject: shurflo faucet |
These look great, the misssus hates the slow poke std. set up in the '81. I have an inline pump, can the Shurflo be easily hooked up with this set-up? Is a new pump added to this faucet worth it? Thanks. |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Fri Feb 20, 2009 9:52 pm Post subject: |
Here is my little enhancement to the Shurflo Faucet upgrade. An optional foot switch. I wanted the option of either the faucet switch or a foot switch, which could be put away when not in use. Using a single pole switch I created a circuit that would allow one or the other to work. When the switch is closed, the faucet switch controls the flow, open the circuit, plug in the foot switch and the foot switch controls the flow. Although for the foot switch to work, you need to leave the faucet in an "on" position. I similarly used door stops from Home Cheapo as the base for the narrow necked Shurflo. Using my dremel, I cut the door stop into a smaller diameter circle. I got really lucky as my OE gasket was still usable. Using the gasket as a template I made the new base. Additionally, the gasket had the screw holes in it, making the placement of screw holes very easy. In the cabinet below, I put the switch in the wall behind the driver. I also mounted the coupler for the foot switch. This allows me to store the foot switch when not in use, etc.
The switch was bought at ProBass Shops, Shurflo at West Marine ($39), and single pole switch / coupler at Radio Shack $3 each.
Base of the faucet.
Back of single pole switch.
switch & coupler on side of cabinet
switch & coupler joined. Wire runs out to foot switch
switch on floor
foot model
_________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Sun Apr 05, 2009 8:48 pm Post subject: |
The knob on top our faucet is busted, so did a search here and learned a great deal with the discussions about pros/cons/fit.
I haven't yet ordered from Go Westy (I think they are expensive) but noted that they have this replacement faucet:
http://www.gowesty.com/ec_view_details.php?id=2429&category_id=128&category_parent_id=
Anyone try one of these and have an opinion?
Thanks! _________________ 1982 Westy, 2.0L AC CA emissions |
Posted: Sun Apr 05, 2009 8:53 pm Post subject: |
no idea about the GoWesty faucet, looks like the factory one. I know BusDepot sells the factory one. |
1621 Samba Member
Posted: Sun Apr 05, 2009 9:02 pm Post subject: |
Honestly, why go this route? The Shurflo is simple to install, and works extremely well. It is a far better faucet than the original, largely because of the flexibility (lifting, spinning, rotating) and the water flow control (a trickle to full force). Did I mention it's about $20 cheaper than the GW version (which they admit on the site is complicated and potentially problematic). Contact West Marine and get the Shurflo and the antenna base mount (see madspaniard's post above) and don't give your faucet a second's thought. _________________ '85 Westy |
Sheesh Samba Member
Posted: Sun Apr 05, 2009 9:08 pm Post subject: |
If I go the Shurflo route, doesn't that mean I lose the city water hookup?
Assuming I read, above, correctly.
I am interested in having both options available and why I am drawn to that from Go Westy. _________________ 1982 Westy, 2.0L AC CA emissions |
Posted: Sun Apr 05, 2009 9:19 pm Post subject: |
Yes you will lose the city hook-up. In my opinion, the better faucet far out weights the amount of times I used city hook-up, which was ZERO.
a shurflo is calling your name... _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
