RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Wed Apr 08, 2009 5:35 pm Post subject: Rear glass removal (with conditions) |
I've looked around a bit and haven't found any posts that seem to address this particular circumstance...
I'm looking for ideas on how to remove my rear glass and (hopefully) preserve the rubber seal in the process. Under conventional circumstances I could pull this off fairly easily (in fact, I did so originally), however I'm in the unexpected situation where I've already separated the pan from the body, so my body is sitting on top of a pair of sawhorses meaning I don't have any leverage to push out the glass and seal. I don't want to cut and replace the perfectly good seal unless I absolutely have to, so please let me know if you have any suggestions.
The back story for those who are interested: I bought my 69 about two years ago, drove it for about a year and then decided to do a full, pan-off restoration. However, when I bought the car, the rear window seal was leaking so I replaced it immediately to stem any further damage. About a year ago, I separated the pan and body to start the restoration; I didn't pull any of the glass because I was going to reuse the same body. The complicating factor came last week when I got my hands on a near-pristine body that will save me a ton of the body work I was expecting to have to do with the original body, hence the desire to pull the rear glass without damaging the seal while the body is up on sawhorses.
Cheers. _________________ Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Apr 08, 2009 6:07 pm Post subject: |
Just cut the seal and replace it with a new one. You're going so deep that it makes zero sense to cheap out on the seal. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
mschulze Samba Member
Joined: January 08, 2009 Posts: 427 Location: Hillsboro, OR
I'd say a friend (about 6'5", 250lb) on the outside pushing in on the body around the window while your are inside pushing out on the window at the same spot with the aid of a well padded stiff putty knife would get the job done. If the seals have only been on about a year and it sounds like they have probably been out of the weather, the would most likely be pretty supple yet for this. You could aid the operation by squirting some silicon spray under the lip on the inside of the car. Good Luck! _________________ 1971 Superbeetle
1963 Deluxe
My Car's Thread -- http://www.rosecityvolksters.com/smf/index.php/topic,2092.0.html |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Apr 09, 2009 2:21 pm Post subject: |
easy as...
just get a blade screw driver and lift one corner of the inside lip and apply a bit of pressure to the window
wont be enough to move the body and the rubber will start jumping the lip as you work your way around
even on old shitty rubbers that arent being reused i find this 100x quicker than cutting the rubber _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
puddle pirate Samba Member
Joined: October 29, 2008 Posts: 390 Location: Powhatan, VA
Posted: Thu Apr 09, 2009 6:05 pm Post subject: |
Personally I wouldn't risk breaking the glass. Then again I also have 2 extra rear windows. The new glass, if you break it, will cost a lot more than getting a new seal.
Yes, you can do the seal without the car being stable. I would spray silicone behind the seal. You will need help and a suction cup. That way the person on the outside can pull and brace themselves on the car as you pry put the seal from the inside. You will need several screwdrivers to do it without breaking the glass.
Good luck _________________ John
73 Super Beetle
87 Jeep Wrangler
99 Jeep Grand Cherokee |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Thu Apr 09, 2009 6:49 pm Post subject: |
Buggin_74 wrote: |
easy as...
even on old shitty rubbers that arent being reused i find this 100x quicker than cutting the rubber |
I agree, I just came in from doing this on a late Mexican car as they have a unique seal profile I didn't want to have to replace. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Thu Apr 09, 2009 6:55 pm Post subject: |
Screwdriver? No way. Perhaps a wide, sturdy wooden shim, but not a screwdriver. Too great of a chance to chip the glass (Been there, done that) when the rubber is very old. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
