coolant level sensor connection
techbot
techbot is offline
PostPosted: Sat Apr 18, 2009 10:37 am    Post subject: coolant level sensor connection Reply with quote
So recently I followed this thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=261685&highlight=blinking+led
And determined that my coolant level sensor was faulty. I bought a replacement from van cafe. Upon replacement my blinking light problem was gone.. success!!
However it started back up again a couple of days later. I discovered that the female connector to the level sensor had popped off. Putting it back on again made everything normal. However it popped off again today. The original sensor had a wire clip that helped lock the connection on but the replacement one does not has this feature. Does anyone have any tips for making this connection stay in place? Has anyone else run into this issue? Thanks!
1991 Westfalia Multivan
perrib
perrib is offline
PostPosted: Sat Apr 18, 2009 10:49 am    Post subject: Reply with quote
They sold you the early sensor. You could change the connector or I would make them give you the correct sensor.
JBange
JBange is offline
PostPosted: Sat Apr 18, 2009 1:47 pm    Post subject: Re: coolant level sensor connection Reply with quote
I have two 90's. One is an early model, the other late. Some dodo put an early sensor (no clip) in my late van so every four or five days I have to pop the cover and cram the connection back together because the light is blinking again. The funny part about it is the late sensor is only $7.50 while the early is over $20: http://www.van-cafe.com/home/van/smartlist_674/level_sensor.html
You should definitely swap it for the cheaper.
John Bange
'90 Vanagon non-GL
'90 Vanagon GL
techbot
techbot is offline
PostPosted: Sat Apr 18, 2009 4:33 pm    Post subject: Reply with quote
Thanks John and Perrib!
You know it's funny.. I paid for the cheaper sensor but looking at the van-cafe's pictures I think it's pretty clear that they gave me the more expensive one. I'll see if I can't swap it out next week. Thanks again!!
-larson
