Another Late 55 fender question
AlteWagen
Troll
AlteWagen is offline
PostPosted: Wed Apr 29, 2009 11:02 am    Post subject: Another Late 55 fender question Reply with quote
I have seen several "late" 55s (bullets, snowflakes) where the tail lights are very low, almost the same as hearts or eggs where the bottom of the taillight is at the same level as the rear bumper. What confuses me is there were no bumper guards (american) so maybe it is an earlier 55 with the turn signal option prior to it becoming standard? Somewhere I read progressive refinements lists the "snowflake" position is higher on the fender for 56 production year. Is this correct?
So is this fender the rarest of all if real?
Official Dual Carb Thread
water guy
water guy is offline
PostPosted: Wed Apr 29, 2009 8:02 pm    Post subject: Reply with quote
I had a July, 1st 1955 car, and the snowflakes were very low. If you stood behind the car you could hardy see the lights from behind the overiders. My VW letter stated that the car had U.S. spec bumpers as an option. I'm sure 56 cars had the lights raised. I took the fenders off and put them in my attic and put on repops so I would'nt get hit.
'55 Porsche Continental
'63 Firetruck
AlteWagen
Troll
PostPosted: Wed Apr 29, 2009 9:14 pm    Post subject: Reply with quote
If not too much trouble, could you take measurements or a pic to get an idea of placement??
thanks
David
David is offline
PostPosted: Wed Apr 29, 2009 10:21 pm    Post subject: Reply with quote
I think you're onto something.
Here's some examples of light placement.
1955 Three Fold w/ Bullets & Snowflakes:
1956:
1957 w/ Semaphores - no Bullets:
1957
Cheers,
Dave
*October '54 Ragtop
AlteWagen
Troll
PostPosted: Wed Apr 29, 2009 11:18 pm    Post subject: Reply with quote
how many of those rear fenders are original "dimple" type. The first two look like standard 55-61 export light placement. Are the second two original placement or repro fender?
The ones I have seen are euro bumper so the rear lights are LOWER than the first two but are not obstructed by the export overiders.
A few years back in HVWs mag there was a 60 euro vert in rock gray with the same Lower snowflake position. Is this just a euro thing?
Here are some pics from the gallery of heart/egg placement, imagine the bottom of the heart is the same as the bottom of the snowflake housing. The ones Ive see are closest to the egg placement
HerrrKafer
HerrrKafer is offline
PostPosted: Fri May 01, 2009 9:58 pm    Post subject: Reply with quote
The lights were moved up 60mm up for 56. So a good estimate of the early position would be 60mm lower than indicated on this chart.
Evan H.
In a perfect world, anyone running chromies would be shot.
thebucket
Samba Stockbroker
thebucket is offline
PostPosted: Tue May 05, 2009 3:14 pm    Post subject: Reply with quote
I'd love to see a pic of a OG car with the flakes mounted right. I have a 55 3 fold flake car. And always assumed I oughta mount them like a 56.
ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold
Mark Evans
Mark Evans is offline
PostPosted: Wed May 06, 2009 8:03 am    Post subject: Reply with quote
Ditto
'63 Ragtop
bally
bally is offline
PostPosted: Fri May 08, 2009 8:10 am    Post subject: Reply with quote
Very useful! Thank you Smile
Dave
thebucket
Samba Stockbroker
PostPosted: Tue May 19, 2009 9:30 pm    Post subject: Reply with quote
Here is a late 55 with ribbed doors, no semi's, etc. It is thought to be OG paint.
Notice the taillight height in the 56 position. And the single tip muffler without apron cutouts.
Embarassed Confused Discuss.......
ITMC-El Presidente
AlteWagen
Troll
PostPosted: Tue May 19, 2009 11:39 pm    Post subject: Reply with quote
maybe my monitor is off but is the left side lower than the right? Could you get a lower pic from behind?
Frostbyte
Frostbyte is offline
PostPosted: Wed Oct 14, 2009 5:24 pm    Post subject: Reply with quote
Greetings all....first time posting here. I've got a '55 Euro vert. Been doing a lot of research on the tail lights. Apparently the Euro models with Semis had the tail lights mounted lower than the export models. The export models initially had lower mounted tail lights that were slightly obstructed by the over-riders. Shortly afterwards the export models had them raised (DOT somehow got involved and raised the safety issue). So, as anyone who has a '55 already knows...it's pretty much a wierd or bastardized year model. A mish-mosh of '54 thru '56 stuff. You'll have the over-riders with low mounted tail lights if it is an early model year...it could have the hearts or the eggs. Then they were moved up for visual and safety reasons...Then late that year they went to the snowflakes.
It really all depends on the day it was made. If it was early '55 you'll see '54 items (such as the hearts) and lower mount tail lights. Then later that year you'll see them raised. Then you'll see the snowflakes. However, if you've got an early year '55 and they have low mounted snowflakes....it'd be incorrect. I'm no expert...just what I've researched and come to believe. If I'm wrong, by all means correct me.
Now, if you've got correct low mounted lights but it is a later model, then you've got a Euro model that didn't have the over-riders. If you have over-riders on it...then that would be incorrect.
Der6VoltFahrers
Der6VoltFahrers is offline
PostPosted: Wed Oct 14, 2009 5:49 pm    Post subject: Reply with quote
http://www.volkszone.com/VZi/showthread.php?t=336586
Wink
AlteWagen
Troll
PostPosted: Thu Oct 15, 2009 12:25 am    Post subject: Reply with quote
So back to my original question, if it is a 60 euro vert it would be correct to have low mounted snowflakes??
Are you also saying that all "Ram protection" euro or export (53-55) would have originally come with low mounted lights but had them raised once actually imported to the US??
Ive seen a few low mounted snowflake cars, all were euro spec. Maybe tourist delivery and got past DOT without raising the lights.
Frostbyte
PostPosted: Thu Oct 15, 2009 11:32 am    Post subject: Reply with quote
Good question. I don't know exactly when all models (both euro and US) went to high mount tail lights.
Bruce
Bruce is offline
PostPosted: Thu Oct 15, 2009 10:56 pm    Post subject: Reply with quote
Certainly, long before 1960, all tail lights were raised.
AlteWagen
Troll
PostPosted: Sun Jan 03, 2010 10:10 pm    Post subject: Reply with quote
Here is a pic from a bio diesel post for an original prototype that is in the Porsche museum.
http://www.thesamba.com/vw/forum/viewtopic.php?t=348121&start=40
looks like a 55 due to triangle flange for spring on decklid.
Snoflake lense and no over riders at all. Still pretty low..
Ram protection option would TOTALLY cover the lights.
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Jan 04, 2010 7:13 am    Post subject: Reply with quote
almost too low - the side shot shows the lenses angled downwards. I can't imagine the factory doing that.
1957 Beetle
1966 Bus
Ninamashr
Location: City of Round Rock in the Great State of Texas
Ninamashr is offline
PostPosted: Mon Jan 04, 2010 8:01 am    Post subject: Reply with quote
l'm sure they used the hole positions for hearts/eggs taillights and installed some snowflakes instead. I know because that's what the tailights on a friend of mine's 54' looks like. He didn't have the finances yet for hearts and ,rather than drill the correct position for snowflakes and have to later fill them in, we decided to drill the holes for hearts and install some snowflakes.
1957 Karmann Kabriolet "Franky"
1957 Allstate trailer
