bajorek Samba Member
Posted: Sun Jul 06, 2003 8:44 am Post subject: oil leaks- do any engines not leak? FAQ |
I know they don't leak- they mark their spot, but is there such a thing as an aircooled engine that doesn't leak? Does anyone have an engine that doesn't leak?
Is it pointless to try to stop evey leak- ones that aren't "bad"?
I was a jet mechanic in the Navy and all of the multi-million dollar planes leaked- especially when it was hot out. Any time planes were pulled into the hanger they had to have drip pans under them to catch the oil and hydraulic fluid. (just thought I'd relay a leaky story) |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Sun Jul 06, 2003 9:08 am Post subject: oil leaks- do any engines not leak? |
Unless they have been properly rebuilt with quality seals they all leak some degree. You'll even get a little bit of a leak (a drop of a film) on the bottom of the oil filter in the best case scenario unless you overtighten the filter.
Largely the leaks come from the valve covers and the push rod tubes and this can be cured with some attention. You need covers with flak surfaces, new gaskets, a smooth flat head surface and a sealing technique (100% dry, grease and sealing products that cure hard don't solve the problem). Where possible, purchase brown viton seals. They are the higher quality used on Porches and have a longer life that the VW seals.
Oil sump plate: use a new gasket
Oil pressure switch: is it tight?
Oil cooler: new seals
Dipstick: new gaskets, boot cracked?
Oil pump: is it on tight?
Distributor: is there an o-ring on the shaft?
It can leak in other places but you'd have low compression if you did. The harder ones include where the case halves meet. If it's leaking there your case has been mishandled.
There is also a seal between the crankshaft and the flywheel called the rear main seal. Many busses leak there because the seal was installed incorrectly or they used a cheap seal. This seal is a nuisance because it means dropping the engine and removing the flywheel.
Personally, I don't like oil leaks because I prefer to use synthetic oil to ensure the life of my engine and each drop costs more on top of making a mess in someone else's driveway. Unless the PO was nice to your engine and you can get away with a little maintenance you have to watch for the leaks and fix them one by one.
Even with good seals, overfilling the engine with oil will raise the crankcase pressure enough to force it out good seals it's better to be between the lines on the stick instead of slightly above it. |
blackchop65 Samba Member
Joined: May 23, 2003 Posts: 176 Location: phoenix, az
Posted: Sun Jul 06, 2003 11:29 am Post subject: oil leaks- do any engines not leak? |
no oil leak= no oil! lol.
j/k |
legato_bluesummers176@hot Samba Member
Posted: Sun Jul 06, 2003 11:11 pm Post subject: oil leaks- do any engines not leak? |
Hey, my oil leak is not normal when there is a puddle of it by the next morning |
Cook911411 Samba Member
Joined: March 25, 2003 Posts: 156 Location: Houston, TX
Posted: Sun Jul 06, 2003 11:44 pm Post subject: oil leaks- do any engines not leak? |
My motor doesn't leak and it was rebuilt in '84.
Well none of the oil hits the ground, I think it burns off faster than it leaks.
My tranny on the other hand...
Chris
74 Transporter |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Jul 07, 2003 8:56 am Post subject: oil leaks- do any engines not leak? |
I must be the exception to the rule. My 76 2L hasn't shown any sign of leaking yet and in just over 6000 miles I've had to add 1/3 litre. I think the motor is the strongest part of the whole damn bus. |
Posted: Mon Jul 07, 2003 12:25 pm Post subject: oil leaks- do any engines not leak? |
I don't leak either. Just a drop that clings to the bottom of the oil filter. |
spydermann Samba Member
Joined: November 15, 2008 Posts: 82 Location: Ogden, Utah
Posted: Tue Mar 24, 2009 10:00 pm Post subject: |
i bought a bus that didnt leak at all! but now that i've got tearing into it i noticed it had silicone substance all over the gasket, now that i've cleaned it off and just gone to grease-coated gaskets....the famous territorial markings have arrived! Kinda miss the leak-free jerry rig |
SGKent Samba Member
Posted: Tue Mar 24, 2009 10:26 pm Post subject: |
some people who have tried using elephant snot * to mate the case and as backup on seals to the case etc found they had no leaks but then they were never able to split the case again if something else when wrong. Once that stuff hardens you are in trouble. You can watch silicone or gasket cinch seep out over time and the leaks begin. I've never seen a motor that didn't lose a drop or two occasionally but the leaks should be like one drop a trip, not a puddle. Puddles mean something is wrong.
* 3M yellow heavy duty weatherstrip adhesive _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
gunnar89 Samba Member
Joined: April 28, 2008 Posts: 245 Location: Apple valley CA
Posted: Tue Mar 24, 2009 11:32 pm Post subject: |
mine doesn't leak as much ... hardly at all (after i fixed the oil cooler leak)
it gets wet on the left side of the engine were the valve cover is but i never left a drop no were (yet) |
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Tue Mar 24, 2009 11:42 pm Post subject: |
Cyril doesn't drip at all, though there is the light moistness on the lowest places. On a few long trips, I noticed that he doesn't burn any discernible amount either. _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Tue Mar 24, 2009 11:46 pm Post subject: |
my 77 westy didnt leak.
and it was a GEX motor with 80k miles.
but the pushrod seals were replaces once along the way |
jttosh Samba Member
Joined: May 16, 2004 Posts: 451 Location: Cuyahoga Falls,Ohio
Posted: Wed Mar 25, 2009 7:38 am Post subject: Re: oil leaks- do any engines not leak? |
ratwell wrote: |
Where is the oil pressure switch? _________________ "listening for the secret,searching for the sound" |
Randy in Maine Samba Member
LetsGoCamping Samba Member
Joined: February 26, 2008 Posts: 207 Location: Corona, CA
Posted: Wed Mar 25, 2009 8:17 am Post subject: |
Mine didn't leak for probably the first year I had it, now it's a couple of drops after each run. I haven't sourced the leak yet though. _________________ 1969 Westy Tin Top. |
Gr8tfulEd Samba Member
Joined: February 19, 2009 Posts: 125 Location: L.O., OR, USA
Posted: Wed Mar 25, 2009 9:06 am Post subject: |
Thanks to the nice people on this board and good suggestions, I believe my bus is now (at least, for now) leak free. It was the oil cooler seals. They were super squished and hard as rocks. I think Moses must of used them on his camel. _________________ ------------
1973 Kombi Riviera camper named "Belle"
1979 Super Beetle Convertible named "Otto"- daily driver |
Ghoti Samba Member
Joined: May 30, 2007 Posts: 760 Location: Rollin' in 541
Posted: Sun May 03, 2009 11:12 pm Post subject: |
My Tram-built motor didn't leak one drop ever.
The motor I have now? I can't keep oil in it. _________________ OH SNAP! |
jbbrown Samba Member
Joined: September 17, 2007 Posts: 442 Location: Newcastle
Posted: Mon May 04, 2009 5:30 am Post subject: |
Ghoti wrote: |
The motor I have now? I can't keep oil in it. |
Veee gonna um pimp za oil leak. _________________ "If it isn't leaking you should check your oil"
73 Super Beetle (sold),78 Triple White Vert, 74 Westy, 2008 City Jetta, 2008 Audi A4 2.0 T, 2009 Teardrop Trailer. 2009 Suzuki SV650A |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Mon May 04, 2009 5:41 am Post subject: |
None of my engines....that I have built....have ever leaked a drop. The exceptuion is the occasional part failure (rear main or oil pressure switch). Catch those parts quick, change them and be done. Of course my engines are type 4.
You have to pay attention when building. Use the right parts and correct sealants in the right places.
The theory/myth/legend that all ACVW's leak and are supposed to is a load of sh*t....designed to cover up poor habits and laziness IMHO. Ray |
Blaubus Samba Member
Posted: Mon May 04, 2009 8:44 pm Post subject: |
Raby engines dont leak |
