PFuni Samba Member
Posted: Wed May 06, 2009 2:19 pm Post subject: ? about onboard 13gal. water tank in Vanagons |
My question pertains to filling up the onboard 13gallon water tank from the little hatch door on the outside of the vanagon, next to the 110v plug outlet and direct water spigget hook-up to the sink.
I noticed that after looking inside the tank the hole in which the water comes into the tank, from the outer fill-up hatch... well the hole's location in the tank sits just past half-way up it. I want to know that when the water level is filling and reaches that hole and passes it to completely fill the tank, will the water back-up and spill back out of the water filling hatch on the outside of the vehicle? Any and all advice is welcome. Thanks again.
Paolo-
83'Vanagon |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Wed May 06, 2009 2:24 pm Post subject: |
From memory I think the outside fill up spigot is higher than the tank itself.
So it shouldn't back up out of the external spigot. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
madspaniard Samba Member
Posted: Wed May 06, 2009 2:29 pm Post subject: |
Mr. Electric Wizard wrote: |
So it shouldn't back up out of the external spigot. |
yes, the hookup filler box is higher, plus it has a one way membrane valve that avoids the water to come out through the filler box. |
tsombrero1 Samba Member
Joined: June 13, 2006 Posts: 288 Location: Seattle, WA
Posted: Wed May 06, 2009 10:10 pm Post subject: |
Yeah, iirc there's a little vinyl tubing to let the air out of the top of the tank.
But there are no guarantees the filler hose is on tight Mine leaked where it attaches to the tank until I replaced it. _________________ Tennessee Sombrero
1988 Westy, Syncro-nated
2003 Aprilia Caponord (now with Jif)
Atari 2600
1970 Earthbound Humanoid |
Jon_slider Samba Member
Posted: Thu May 07, 2009 6:55 am Post subject: |
Yes
Mine does overflow outside the van at the fill spout if I put in more water than it wants.
Let us know after you try it, if that is how yours works too.. |
larrytrk Samba Member
Joined: July 22, 2007 Posts: 377 Location: Central NJ & MA
Posted: Thu May 07, 2009 7:12 am Post subject: |
At 8lbs per gallon, why fill to the top, unless you intend to go into the Desert for a long while? _________________ It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world! |
Posted: Thu May 07, 2009 8:39 am Post subject: |
Jon_slider wrote: |
Yes
well, if you try to put more than 13 gallons of water from a hose into the tank pressure will build up and water will have to come out somehow so it will do so through the weakest point in the system, the attachment to the tank, the hookup box, the top opening...or maybe through the vent hose that goes from the tank back to the filler hookup box...
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Thu May 07, 2009 8:58 am Post subject: |
Last time I used mine I filled it from the inside, the outside is a big pain.
I would use the outside in a pinch, but I sure wouldn't try to fill it all the way. |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Thu May 07, 2009 9:24 am Post subject: |
I much prefer to fill the tank from the inside for many of the reasons listed above. So has anyone ever installed an inside filler hole w/cap that's more convenient than unpacking the cabinet and taking off the cover to access the tank?
Curious minds want to know. _________________ 1984 Westy with tencentlife power! |
ianstone Samba Member
Joined: September 14, 2005 Posts: 195 Location: San Francisco, CA
Posted: Thu May 07, 2009 12:06 pm Post subject: |
for some reason i cannot open the little door on the outside of the van, i always have to go in through the cabinet and fill it that way
i do have the little key, and when i try it i can't seem to get it to budge
any suggestions? |
Posted: Thu May 07, 2009 12:07 pm Post subject: |
ianstone wrote: |
any suggestions? |
Penetrating oil maybe? _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Thu May 07, 2009 8:45 pm Post subject: |
ianstone wrote: |
any suggestions? |
That's probably an aftermarket filler door that you have. It looks like it should open from the bottom, but only the center part of the door opens and it opens from the top. Look real close.
As for filling the tank, I always fill it from inside. I don't want the water level above the top seal in case it leaks. |
koolmoe Samba Member
Joined: November 15, 2008 Posts: 382 Location: Annapolis, MD
Posted: Thu May 07, 2009 9:02 pm Post subject: |
I fill from the inside too.
But I always spill a little and forget to rag the rim... I hate seeing that water drip down...
How do y'all fill it and ever, always, rarely spill?
I need a big funnel.
KM _________________ --
Current: 1990 Westy GL (Savannah. Good to be back!)
from '95 til 2008: 1995 Pathfinder (frame rusted out, charitable parts donation)
from '91-'95: 1982 Westy Diesel (Smokey. Traded in for far too little!)
from '87-'91: 1980 VW Rabbit (my econoPorsche - passed on) |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Thu May 07, 2009 9:16 pm Post subject: |
I just redid my interior, including the water system. I replaced all the hoses, clamps, and the "O" ring on the tank where the fill tube enters. No leaks.
That said, I think I'm going to fill the tank from the inside and haven't reinstalled the screws holding the metal plate in the cabinet. We're keeping the kid's art supplies in there in a box that fits nicely - only a single thing to take out when filling in the future.
To take another turn.....has anyone ever had leaks where the tank level sending wires connect? _________________ 1982 Westy, 2.0L AC CA emissions |
Posted: Fri May 08, 2009 6:01 am Post subject: |
koolmoe wrote: |
KM |
Get one of those shut-off adapters that fit on the end of a garden hose. Home Depot or a good hardware store will have several different types to choose from. |
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Mon May 18, 2009 12:40 am Post subject: |
can anyone tell me offhand if the filler hose that goes from the exterior utility flap to the water tank can be replaced without pulling the cabinets and/or the fridge?
i noticed that mine has a very slight leak where it joins the tank; i'd like to fix it with the least hassle possible, but then again it's a quarter-century old hose so if i can replace the hose also, so much better.... _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Mon May 18, 2009 5:17 am Post subject: |
iiigoiii wrote: |
i noticed that mine has a very slight leak where it joins the tank; i'd like to fix it with the least hassle possible, but then again it's a quarter-century old hose so if i can replace the hose also, so much better.... |
yes, no problem at all, I just did that this week (replaced all water hoses since they were very dirty inside). Just make sure that you unplug the old hose, tepe/join the new hose togethet with the old one, and pull from the old hose (lot easier than try to thread the new one). Did this for the 3 hoses that end up in the tank.
I could not find a true replacement for the filler hose (it has a weird thread along with the filler neck in the tank), and ended up using a very close replacement. Problem is, I found that now it leaks very slightly, so I'll have to remove it and try to seal it somehow. Any ideas ? Could I use Teflon or an o-ring somehow ?
Hugo _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Sheesh Samba Member
Posted: Mon May 18, 2009 7:06 am Post subject: |
iiigoiii: Get some new gaskets (van cafe / go westy) when you replace the plastic box. I also used shoe goo on top of that to seal it tightly to the van. This prevents water from leaking in between the panels when it rains or you wash your rig. One way for galley rust to start!
pnwkayaker: I did the same and had the same results when I redid my interior. I got a new O ring from my local hardware store (the old one was compressed and hard) and screw clamp (the old clamp was "bolt action" and didn't do the job), then tightened the hell out of it. Before putting the screw clamp on, I wrapped gorilla tape around the hose to protect it. That stopped my leak. If it continued to leak, I was going to wrap teflon tape around and around and around until it didn't (but, it didn't). _________________ 1982 Westy, 2.0L AC CA emissions |
