freebasedeathmonkey Samba Member
Posted: Sat Apr 25, 2009 10:40 am Post subject: 56 panel resto. Heater pipe????? |
Am restoring my 56 double door panel from the ground up and have come across some strange "upgrades" during the strip down. Does anyone have a pic of the centre heating pipe on a 56 that runs the length of the bus? Mine appears to have been codged and bodged to fit so think its the wrong pipe. |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Sun Apr 26, 2009 9:28 am Post subject: |
Klassic fab has the heater tube listed on their site, but no pictures. It says it's 1 piece if that helps any. You may want to contact them for some info since they reproduce everything. _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Sun Apr 26, 2009 10:14 am Post subject: |
Here's my '57 with the KF tube
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Sun Apr 26, 2009 10:49 am Post subject: |
I think both heater boxes hook up to the "Y" pipe in the back on a panel.
Posted: Sun Apr 26, 2009 11:43 am Post subject: |
Thanx everyone. Does anybody know what the differences are on these pipes from front to back over the years of production? Are there any or is it a case of them being all the same from start of production to end? Excluding barndoor era of course. |
Posted: Sun Apr 26, 2009 11:47 am Post subject: |
Particularly the jointed parts between the area where the belly pans finish and it goes through another cross plate and up into the cab? |
sandowner Samba Member
Joined: May 27, 2006 Posts: 38 Location: Pembrokeshire, UK
Posted: Thu May 07, 2009 11:21 am Post subject: |
Do you know anyone who supplies the original lagging (insulation) for the heater pipe?
Any advice much appreciated |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu May 07, 2009 11:28 am Post subject: |
I have never seen the insulation offered for sale. But you can have it sewn up at a local upholstery shop. For the early years it's just canvas with a few layers of fiberglass matting sewn inside and secured with twist clamps which you can buy from a forum user for cheap. You can get the fiberglass from any place that sells fiberglass supplies as it is the same stuff used for molding objects using resin etc. It has a very coarse weave.
For later buses it is gray vinyl from your local upholstery house, with the same fiberglass matting sewn inside. But the originals had a molded gray plastic snap channel (think zip-loc) that forms a seam on the bottom. I don't think that is available, so you would have to either do without, or very carefully remove it from an original set and sew it onto your new one (good luck with that as it gets VERY brittle with age). |
Posted: Thu May 07, 2009 11:54 am Post subject: |
Thanks for the advice. I have the original 'later' grey vinyl zip-loc insulation on the bus (63) but really need to take it off as part of a restoration. Just really worried that it will fall to pieces and I won't be able to replace it.
I will perhaps start with the short length under the cab floor and see what happens (and let you know!) |
Posted: Thu May 07, 2009 12:05 pm Post subject: |
Mine (plastic) did not do so well during disassembly. I left the long piece in place because I was able to. Smaller pieces I ruined one, one was already MIA, and one was sent to me used by a kind forum member.
Piece of advice--heat up the plastic with a heat gun during the removal/"unzipping" process. It will make the plastic much more pliable. |
Posted: Sun May 17, 2009 4:15 am Post subject: |
Managed to get all three pieces off with limited sucess. Most of it 'unzipped' but there was some splitting. Heatgun helped quite a bit so thanks for the tip!
Biggest problem was that the insulation was the only thing holding the heater pipe in place! It had rusted completely through between the main frames and just dropped out. New heater pipe on order.... |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun May 17, 2009 6:34 am Post subject: |
mintonman wrote: |
Klassic fab has the heater tube listed on their site, but no pictures. It says it's 1 piece if that helps any. You may want to contact them for some info since they reproduce everything. |
Do they have the Y pipe that goes into the rear cross member yet ?
When I bought Funky Green stuff for my Sc, they didn't have that Y pipe, I've found a used one, but...... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
