so42 rear facing seat
jeremy57ride
jeremy57ride is offline
PostPosted: Fri May 01, 2009 10:05 am    Post subject: so42 rear facing seat Reply with quote
I need the dimensions for the rear facing seat in a non-walk thru westy.
I have a bay closet and I'm planning on making one.
I have never seen one for sale...any help/pictures/ thank you!
"If you don't do it this year, you'll be one year older when you do." -Warren Miller
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Fri May 01, 2009 10:14 am    Post subject: Reply with quote
Jeremy, you are really going to need to make paper templates from an original one. There are many curved cuts on it to match the contour of the side of the bus, the back of the bulkhead, etc, and then there is the interior "map pocket" compartment with its bottom etc.
I'd suggest you find an upcoming show near you and then use the forums to find someone bringing their SO-42 westy. Try to link up for an opportunity to remove the seat and make those templates.
jeremy57ride
PostPosted: Fri May 01, 2009 11:19 am    Post subject: Reply with quote
Major Woody, it's funny you should reply. I'm getting ready to do the whole interior and your "baltic birch" stain recipe has been added to my archives. Thanks for the detailed information!
I've been to a few shows and continue to see the walk thru westys...I honestly have never seen a rear facing bench seat!
wudbuch
wudbuch is offline
PostPosted: Fri May 01, 2009 1:43 pm    Post subject: Reply with quote
I have a 66 so42 non walkthrough and am in northeast pa I have the interior out of the bus so I could take some pics for ya if needed shoot me a mail [email protected]
68 bug daily driver
66 westy non walkthrough velvet green
jeremy57ride
PostPosted: Fri May 01, 2009 1:56 pm    Post subject: Reply with quote
Thank you! Message sent.
If I get a decent one of these made, I'll be sure to share the info...
I haven't seen alot of topics on these.
nimbus
nimbus is offline
PostPosted: Fri May 01, 2009 5:14 pm    Post subject: Reply with quote
I am looking to make one of these, or buy one...they don't come up too often.
Notchback
Bug
Single Cab
jeremy57ride
PostPosted: Tue May 05, 2009 10:55 am    Post subject: Reply with quote
Thanks for the detailed pictures Matt.
Dimensions to follow...
jeremy57ride
PostPosted: Tue May 05, 2009 10:58 am    Post subject: Reply with quote
two more:
ekimikem
ekimikem is offline
PostPosted: Fri May 08, 2009 8:41 pm    Post subject: Reply with quote
This showed up in the classifieds if you didn't already see it. Not complete but it's a start.
http://www.thesamba.com/vw/classifieds/detail.php?id=783455
jeremy57ride
PostPosted: Sat May 09, 2009 8:52 am    Post subject: Reply with quote
Thanks...I would have been all over that!! Just talked to Ed, he already sold it!! Thanks anyway. Confused
jeremy57ride
PostPosted: Mon May 11, 2009 7:59 am    Post subject: Reply with quote
Ok, here are the dimensions I received. Thanks again Matt.
Sorry for the lame paint skills!
A 38 1/4 bottom and 39 3/8 on the top for the curve on the side
B 13 3/4
C 16 1/2
D 29 3/8 to the bottom of the top ply
E 6 wide and 8 3/4 with the pad 6 is the ply though
F 18 base
Map Pocket 15 across and 13 deep
I hope to find this seat as an original, but this may be a way to build your own. Feel free to add any build pictures or advice along the way. Wink
nimbus
nimbus is offline
PostPosted: Mon May 11, 2009 8:07 am    Post subject: Reply with quote
Thanks.
Notchback
Bug
Single Cab
my65vert
my65vert is offline
PostPosted: Mon May 11, 2009 8:31 am    Post subject: Reply with quote
will, I still have the bottom pedestal section and cushion here. I just do not have the back section or cushion.
But I do have an extra set of z-bed cushions that you could use to make the back piece.
OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment.
nimbus
nimbus is offline
PostPosted: Mon May 11, 2009 8:43 am    Post subject: Reply with quote
Thanks Mike, I have a bunch of foam from a mattress so I can use that for the back. I will get that bottom from you soon.
Notchback
Bug
Single Cab
nimbus
nimbus is offline
PostPosted: Tue Nov 03, 2009 2:43 pm    Post subject: Reply with quote
Ok, I finally got my hands on one. It had the back piece with cushion and shelf, and the seat bottom cushion. I had to make cut and attach the 3 wood pieces that the seat bottom rests on. Good for now..after seeing some originals, the front piece goes infront of the left side and is curved.
Notchback
Bug
Single Cab
jeremy57ride
PostPosted: Mon Mar 14, 2011 10:10 am    Post subject: Reply with quote
Just thought I'd update, thanks to Nate, (Jung Restoration) I now have an original seat! It is in remarkable shape!
xavi_242
xavi_242 is offline
PostPosted: Tue Mar 15, 2011 12:58 pm    Post subject: Reply with quote
nice!
1967 Split SO-42 Dormobile
nimbus
nimbus is offline
PostPosted: Tue Mar 15, 2011 1:45 pm    Post subject: Reply with quote
Dancing
Notchback
Bug
Single Cab
jpeters
jpeters is offline
PostPosted: Tue Aug 27, 2013 8:52 am    Post subject: Reply with quote
Any leads on parts for a rear facing seat? I have an old bay closet that I may use per the dimensions provided, but I figure any original parts that someone may be hoarding could certainly be helpful.
'73 Westy
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'66 Bug
'63 Bug (Big Bore 40hp)
@neverdnf on Instagram
Darth Wolfsburg
Darth Wolfsburg is offline
PostPosted: Wed Mar 11, 2015 11:27 pm    Post subject: Rear seat attaching Reply with quote
How does this seat install? I have a rear facing in pretty bad shape. I cut some plywood pieces and connected everything with metal brackets on the inside. It's actually lookin good now, but I have no idea how it gets installed in the bus.
The more details the better! Cool
