Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Thu May 14, 2009 6:12 pm Post subject: What is the reservoir on the driver side floor for? |
I know, I know, I need a bentley.
Is this for window washing fluid? I just noticed that there is some moisture under my carpet (only on the drivers side). I can't find any other place where moisture might be coming in. Any chance it would be coming from this reservoir?
_________________ PHOTO GALLERY |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Thu May 14, 2009 6:18 pm Post subject: |
Ha, I guess you haven't run out of windshield washer fluid yet, since that's the reservoir. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
?Waldo? Samba Member
Posted: Thu May 14, 2009 6:27 pm Post subject: |
Yes, that's the washer reservoir. The "moisture" on the driver's side is often brake fluid that has leaked from the clutch or brake hydraulics.
Andrew |
Posted: Thu May 14, 2009 6:34 pm Post subject: |
Andrew A. Libby wrote: |
Andrew |
Thanks for the quick responses!
Is there anything that I can do to remedy the moisture? I have been searching for the source but can't find anything. I don't want to start running into mold problems. _________________ PHOTO GALLERY |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Thu May 14, 2009 6:59 pm Post subject: |
Andrew has the best idea of what the "moisture" may be. Is it greasy feeling? Check your hydraulic fluid and see if it is low. If it is, then check both the brake and clutch masters for leakage. Again, if it is, replace the faulty part, get the carpet out of your van andbuy yourself new carpet. Not only will the carpet hold the fluid, but you will track it all over your van. Additionally, hydraulic fluid will eat away the floorboard paint, requiring additional work. _________________ 1982 Westy, 2.0L AC CA emissions |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Thu May 14, 2009 7:17 pm Post subject: |
Unlikely it's moisture coming from your washer reservoir, doesn't seem like you've filled that anytime lately, snce you didn't know what it was.
If the moisture isn't the hydraulic fluid that would be coming from your brake or clutch reservoir, it could be water leaking around the lower corner of your windshield. Had any rain lately or washed your van? If the seal is leaking around the lower corner of the windshield, it dribbles down the inside of the front sheetmetal, kinda behind the fusebox, and soaks into the carpet. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Thu May 14, 2009 8:42 pm Post subject: |
Should we tell him about the oil filler tube while we're at it? |
msinabottle Samba Member
Posted: Thu May 14, 2009 9:20 pm Post subject: That Which Leaks... |
Larry Blazer and I share an unprintable opinion about a very bad run of very bad brake light switches on brake and clutch fluid reservoirs of Chinese manufacture. I've had two go bad on me, one with devastating results as I was getting ready to take Winston up into the mountains above Ft. Collins as part of Rocky Mountain Westy's camping trip.
Thank goodness for those big rubber mats in the cab! The hexes hold the gunk and tell me what the problem is the moment I notice it.
One of the first things you learn upon exploring your vanagon is that things are in weird places that make sense upon further reflection.
Posted: Fri May 15, 2009 4:15 am Post subject: |
hiram6 wrote: |
If the moisture isn't the hydraulic fluid that would be coming from your brake or clutch reservoir, it could be water leaking around the lower corner of your windshield. Had any rain lately or washed your van? If the seal is leaking around the lower corner of the windshield, it dribbles down the inside of the front sheetmetal, kinda behind the fusebox, and soaks into the carpet. |
Could also be water leaking in through the antenna base...
FNGRUVN wrote: |
'85 GL
hiram6 Samba Member
Posted: Fri May 15, 2009 4:35 am Post subject: |
Well now you're just taking the fun out of it. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Fri May 15, 2009 6:18 am Post subject: |
The moisture under the carpet turned out to be a rust spot under the windshield rubber.
From the outside I didnt see any rust but the wetness continued.
Fast foward a year...I see a small bit of rust on the edge of the window.
As luck would have it my insurance company paid for a new windshield due to a crack. When the old glass and seal were removed.....I saw a much larger area of rust.
A hole about the size of a quarter had grown UNDER and allong the seal.
Only a small 1/8 inch area was showing above the seal but quite a bit under it.
Rust is sneaky and lives in the strangest of areas. |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Fri May 15, 2009 8:17 am Post subject: |
Good news? At least you found it. They can and forever will be Quirky LiL Bastards....But they just don't make cars like this anymore....
McVanagon wrote: |
hiram6 wrote: |
FNGRUVN wrote: |
Very nicely done. _________________ Happiness=Portland, Oregon in the rearview mirror! |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Fri May 15, 2009 11:49 am Post subject: |
hiram6 wrote: |
Well now you're just taking the fun out of it. |
Now you are confusing me, I thought that was the 710 filler tube. _________________ -- 1987 Westfalia automatic (Captain Vino) |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri May 15, 2009 12:17 pm Post subject: Re: What is the reservoir on the driver side floor for? |
edgood1 wrote: |
I thought this was where you pour the liquid schwartz
Now that is funny. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Fri May 15, 2009 12:23 pm Post subject: |
You mean that's not the spittoon????
Man, no wonder my winsheild looks so bad... |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Fri May 15, 2009 12:48 pm Post subject: |
mightyart wrote: |
And smells like piss too! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Fri May 15, 2009 1:17 pm Post subject: |
FNGRUVN wrote: |
Guess I am not part of the club, I don't have an oil filler tube as I have a tiico engine.
Since I don't use washer fluid, I am thinking of using it as a urinal. No more stopping on those long road trips. _________________ PHOTO GALLERY
Posted: Fri May 15, 2009 1:20 pm Post subject: |
On a serious note, thanks to everyone who gave insight as to where the moisture on the floor might be coming from. I am guessing it probably is a bad seal. I am going to dive into it this weekend and see what I can find out. _________________ PHOTO GALLERY |
Posted: Fri May 15, 2009 2:05 pm Post subject: |
1991VanagonCarat wrote: |
Guess I am not part of the club, I don't have an oil filler tube as I have a tiico engine. |
I thought the Tiico used the diesel vanagon oil pan along with the filler tube or do you have to open the engine lid to add oil? If you don't have any filler tube added, then you can certainly add the diesel vanagon version which does indeed have the tube extension.
Andrew |
