redcanoe Samba Member
Posted: Sat May 30, 2009 1:24 pm Post subject: Dash Plastic trim removal ?? |
There is a plastic trim piece from the dash area that sits directly in front of the gear shift lever. Can't, for the life of me, figure out how to remove it !!
I'm looking for a wire that may be in behind there.
Any suggestions would be gratefully received.
fairweather Samba Member
Joined: August 26, 2007 Posts: 663 Location: Aspen, CO
Posted: Sat May 30, 2009 1:35 pm Post subject: |
I believe you just grab it and pull hard, that's how mine works anyway. |
Posted: Sat May 30, 2009 3:03 pm Post subject: |
This plastic is attached just above the tranny tunnel, about 18" wide by 12" high. Can't see any fasteners or screws at all. Just pull hard you say ?? Temptation is to do so but ........... wish I knew more about what is holding it on then I might be alittle more forceful.
More input welcome.
Tx |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sat May 30, 2009 3:07 pm Post subject: |
I think you will find what you need here:
http://www.benplace.com/dash.htm _________________ -- 1987 Westfalia automatic (Captain Vino) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sat May 30, 2009 3:14 pm Post subject: |
Open the glove compartment and grab the plastic cover towards at the top on both sides and pull. That is where the clips hold onto the heater assembly. It takes a little faith but that is how it is done. |
ThorAlex Samba Member
Posted: Sat May 30, 2009 3:37 pm Post subject: |
And don't be afraid to brake the clips, they are broken on mine but it still sits pretty tight. |
Posted: Sat May 30, 2009 4:17 pm Post subject: |
I am not a fan of yarding on plastic when you aren't really sure whats holding things together. That said, I did, I got it off, but broke a couple of tabs in behind and cracked a couple of plastic channels on the removed piece. A straight back movement for removal of this was not possible because it seemed to be overlapped by the metal portion of the dash assembly that is just above. Seemed I could only rotate it out bottom first. Therefore cracked and some broken plastic but not the end of the world. I would not have rotated it had I known what is behind.
And nope, I did not find the missing wire I was looking for....... but now I know a bit more about the way these things are put together.
Thanks for the responses sambaland. |
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Sat May 30, 2009 4:59 pm Post subject: |
this what you're looking for?
there are two little plastic runners that slide on the ends of the left and right air ducts
you can clearly see one just to the right of the 'feathered end' of the left arrow
(with thanx to ben, as usual)
_________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
