Posted: Mon Mar 24, 2003 12:39 pm Post subject: tightening up turn assembly |
I have a 69 westy. My blinkers still work, the blinker handle spins though. The assembly attached to the steering column came loose. It spins so much I have to hang on tight to the assembly if I want to signal a turn.
I need some advice on tightening it. I've tried the screws they don't do it. |
chabanais Samba Member
Posted: Mon Mar 24, 2003 4:38 pm Post subject: tightening up turn assembly |
Yeah I've had the same problem. Basically you want to give the blinker assembly some "grip" where it attaches to your steering column. Now I don't know what the "NOS Approved" repair is but I basically just took the two halves apart and took some thing rubber pieces and stuck them on there and re-screwed the assembly to that. Mine holds perfectly. |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Mon Mar 24, 2003 5:22 pm Post subject: tightening up turn assembly |
You could make the rubber spacers with an old bike tire tube. Sounds like a good fix. Jeremy |
Posted: Mon Mar 24, 2003 7:08 pm Post subject: tightening up turn assembly |
Thanks I'll try it |
breadloafdeluxe Samba Member
Joined: February 12, 2002 Posts: 418 Location: Birthplace o Tx. Brazoria Co.
Posted: Thu Mar 27, 2003 5:59 am Post subject: tightening up turn assembly |
I did the bike tube trick on my 71.Works fine! |
Hella Bro Samba Member
Posted: Thu Mar 27, 2003 7:39 am Post subject: tightening up turn assembly |
I learned this technique a few years ago on my early buses... Take the signal halves and a Flat file. File down the edges of one or both halves evenly, this will make the ( )diam. smaller. The screws then will have something to clamp to.This should do the trick. Careful it does not take much. |
